Previous in Blog: Japan Sets Up a Sustainable Smart Town   Next in Blog: Microgrids – Nation’s Future towards Clean Energy
10 comments
Fuel Cells - Energy Empowering Technology
Posted February 19, 2015 12:00 AM by sanasyed24
An alternative, cleaner and more efficient solution to the combustion of fossil fuels and gasoline is an enabling technology of fuel cells. Fuel cells convert energy and utilize hydrogen power. They provide power in portable and stationary power applications. There is a potential of replacing internal combustion engines of vehicles by fuel cells because they are fuel flexible, clean and energy efficient.
Working of Fuel Cells
A fuel cell is an electro-chemical energy conversion device that generates electricity using chemical energy of hydrogen. It also produces heat and water as byproducts. The operation of fuel cells is similar to a battery, except that it takes chemicals from the outside and can generate power indefinitely. A fuel cell consists of two electrodes, i.e. the cathode and anode, where the chemical reaction takes place creating electric current.
Types of Fuel Cells
Primarily, fuel cells are classified by the kind of electrolyte used. This classification determines other factors, such as kind of catalysts, required fuel, kind of chemical reactions and temperature range. These factors affect the suitability of fuel cells in a particular application. Currently, many types of fuel cells are being developed including direct methanol, solid oxide, polymer electrolyte membrane, alkaline, molten carbonate, regenerative, and phosphoric fuel cells.
Benefits
Compared to conventional technologies based on combustion, fuel cells offer a wide variety of benefits. In terms of efficiency, fuel cells are two times more energy efficient than combustion engines. They improve our environment significantly and eliminate health hazards since they do not produce greenhouse gases, air pollutants, particles or toxins. Fuel cells offer flexibility since the types can operate on different fuels including methanol, hydrogen, biogas, ethanol, and natural gas. They are scalable providing power from milliwatts for small applications to megawatts for large applications. Also, they complement other technologies, such as solar panels, wind turbines, and batteries.
Applications
The potential applications of fuel cells vary widely that make them unique in the practical world. They can provide power to a small system, such as a laptop computer, and also to larger systems, such as a utility power station. Currently, fuels cells are used in passenger vehicles and power plants eliminating the dangers of health problems.
References
http://energy.gov/eere/fuelcells/fuel-cells
http://www.chfca.ca/education-centre/what-is-a-fuel-cell/
http://www.globalspec.com/learnmore/electrical_electronic_components/power_generation_storage/alternative_power_generators/fuel_cells
image - http://upload.wikimedia.org/wikipedia/commons/9/90/Solid_oxide_fuel_cell_protonic.svg
Good Answers: 61
Re: Fuel Cells - Energy Empowering Technology
02/19/2015 11:54 AM
Very old hat! Fuel Cells have been around for 170 years. Exactly why is this being posted?
02/20/2015 11:26 AM
There is still a lot to be discoovered. Can Brown's gas be used, allowing us to store water rather than compressed hydrogen? What would happen if the electrolyte were a nickel/lithium crystal similar to the LENR formulas that are creating excess heat?
Reply Score 2 for Off Topic
02/20/2015 11:40 AM
What a load of brown gas. Try Beano.
02/20/2015 12:42 PM
The whale industry had the same attitude when natural gas was discovered and commercialized.
02/20/2015 12:47 PM
"Brown's gas" as I understand it will contain the combined electrode gases from an electrolyzer, and cannot be directly employed without separating the hydrogen from the oxygen. Have any ideas how to do that?
You would be better off somehow coming up with a pre-mix burner design that would allow burning of this gas mixture (hopefully diluted with something to regulate the temperature, and help prevent flame velocity problems causing flashbacks?)
I am not sure at all the effect of having oxygen at the anode of a fuel cell. It might just catch fire easily. If one could get away with that, then it might be a simple matter to loop this gas flow in such a way as to clean up the stream using several anode passes, then send the now oxygen rich stream to the cathode.
Good Answers: 61
02/20/2015 2:15 PM
Oxygen at the anode would immediately react with hydrogen in the presence of the platinum catalyst, with the evolution of heat. I worked on hydrogen/air fuel cells for some years and this problem occurred a number of times in testing fuel cell stacks due to a phenomenon called "cell reversal," which can occur at start-up and causes oxygen to be generated from the H2O at the anode. This very quickly resulted in destruction of the anode.
02/20/2015 12:49 PM
Anyone know where I can buy a simple fuel cell (I don't care what class of fuel cell as long as it takes hydrogen and oxygen), or array of fuel cell plates?
02/20/2015 3:06 PM
02/20/2015 3:51 PM
I dunno yet. That link is loading at the speed of sap running in Maine during a blizzard.
02/20/2015 4:47 PM
energyconversion (2); James Stewart (3); SolarEagle (2); Tornado (1); WoodwardDL (2)
