Robotic Systems Blog Blog
The Robotic Systems Blog is the place for conversation and discussion about industrial robots, programming and controls, sensors & tooling, and robotic safety. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Should Robots Require Our Help?   Next in Blog: Robot Farming
Wall Climbing Robots
Posted March 06, 2015 12:00 AM by CR4 Guest Author
As the name clearly suggests, we are talking about robots that can climb walls. The concept of robots is not new, but the real improvement in this field happened in the last decade when the scientists decided to go beyond making robots that can just shake their head, hands, and legs. They are making robots than can climb the walls and do what a machine can do i.e. minimizing the human efforts.
The climbing robot needs to be lightweight and it should easily adhere to the vertical surface. If it lacks either of the criteria it is going to fall down.
Many locomotive principles were proposed in order to make the vertical movement easy and fall-free, namely magnetic force, suction force, thrust force and gripping force type. But after a lot of research and mechanical findings, the vacuum type principle was found most suitable in which the legs/hands of a robot can act as vacuum ducts and they can stick to the walls easily.
So, what's the point of a wall climbing robot? It minimizes the human effort because of its small size and non-human body. It is designed to operate in those places where the direct access by a human being can be very dangerous and expensive.
Here are some areas of application:
  • Inspection of bridges.
  • Transportation of goods and loads inside the buildings.
  • Testing in industrial structures such as power plants and pipelines.
  • For security purpose like reconnaissance in anti-terrorist activities.
  • Cleaning operations in tall buildings, ship hulls and boiler walls.
If you don't want to give your job up to a robot just yet, you can always consider gecko gloves!
image credit
Good Answers: 26
Re: Wall Climbing Robots
03/06/2015 8:15 AM
  • They (and I) have been doing that for many years.
