Networking & Communications Blog
The Networking & Communications Blog is the place for conversation and discussion about power & apps, wireless technology, voice & internet, and network security as they relate to networking and communications fields. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: So You Have All This Data - Now What?   Next in Blog: Are We Ready for the Internet of Things?
6 comments
Norway Planning To Kill Analog FM
Posted April 27, 2015 12:00 AM by Hannes
On April 16, Norway's Ministry of Culture issued a press release stating it will be the first country to completely digitize radio broadcasting. The country is planning to deactivate all remaining FM stations by the end of 2017--any broadcasting done after this point will use Digital Audio Broadcasting (DAB) technology. There are numerous benefits to digital-only broadcasting, including space for dozens more channels and DAB's more robust transmitters, which are favorable in emergency conditions and allow tunnel reception. The switch will occur in a regional sequence, beginning with Nordland in January 2017 and concluding with Finnmark in December of that year.
Norway has been discussing a switch-off for years and developed absolute criteria for a 2015 decision to cease analog in 2017. As discussed in the announcement, criteria guaranteed added listener value for digital broadcasts and digital coverage that at least matches that of the largest national radio station, NRK P1.
While this announcement may come as a relative shock, Norway has always been ahead of the times in digital broadcasting. The country started Alltid Klassisk, the first digital radio station in the world to broadcast using DAB, in 1995. Norsk rikskringkasting (NRK), the government-owned broadcasting service that dominates radio, already has 99+% coverage on DAB, with commercial stations broadcasting using DAB over almost 93% of their spectrum. Community-run stations will be probably be the hardest-hit as far as conversion costs, as only 50% of their nationwide coverage is digital.
Most of the transition's burden will fall squarely on the shoulders of listeners for several reasons. First and foremost, analog radios simply can't receive digital signals, so the 44% of Norwegian listeners that only tune in to analog FM will either need a new digital rig or retrofit their old one with a DAB adapter or converter. More significantly, only 20% of private cars in Norway are currently equipped with DAB radio. As evidenced by recent national transitions from analog to digital television, digital and analog signals degrade in different ways. Whereas most analog signals gradually degrade and lose signal quality, digital ones retain perfect signal quality until they suddenly cut out, causing interruptions in the broadcast.
Other countries with a strong digital radio presence are following Norway's lead and establishing their own strict criteria for possible switchovers. Denmark, Germany, Belgium, Switzerland, and South Korea all have significant and growing listener bases and may see a switch in the future. The United Kingdom had originally set a switch-off date of 2015 but has struggled to meet criteria that mandates digital radio use by over 50% of total listeners, and the UK's digital listening stats have actually decreased while showing an increase in FM analog listening several times during the last few years. A changeover is highly unlikely in the US due to its much more commercial broadcasting structure (it lacks a dominant public broadcasting company like NRK or the BBC) and lack of support for digital and HD Radio service.
If Norway's radio transition is anything like the digital television transitions that've taken place worldwide, the country will soon be implementing equipment trade-in programs and spending millions if not billions of kroner to raise awareness and spur listener preparedness. The Ministry of Culture is probably wise to spread the transition over the course of 2017 to avoid the hundreds of thousands of daily support calls to the FCC witnessed by the 2009 US digital TV transition. If Norway plans as patiently and carefully as its previous studies on the digital switchover, they can likely expect a smooth, efficient transition with minimal fallout.
Image credit: brankomaster / CC-by-2.0
Re: Norway Planning To Kill Analog FM
04/27/2015 7:12 PM
You mean now we can have dozens of radio stations we don't want to listen to? The problem with commercial radio is the commercials. I don't mind commercials per se, but the current format of playing four or five songs, then 8 continuous minutes of ads and promotional spots is untenable. If I pick my commute time wrong, I might be lucky to hear one song. Of course, having a 10 minute commute is something to celebrate. Back in the old days, they would play one or two songs, then an advertisement. Having the ads spread thinner like that made them much easier to swallow. Commercial radio is getting to be their own worst enemy.
04/27/2015 8:12 PM
That's the whole point of having radio head units in vehicles that have USB ports. Invest a few dollars in one that has a few Gigs of memory and make your own music playlist that runs for hours and hours without commercials or repeats.
Thats what I do and unless I am with my wife I won't listen to over the air radio on purpose for months at a time.
04/27/2015 9:25 PM
Sounds like upgrading car radios might be a good job to get into.
04/28/2015 3:32 AM
Have you noticed that UK tv does not show the current time and have not done so for quite some time. This change occured during the transition between analogue and digital tv broadcasting. Changing to DAB will have one major disadvantage inasmuch the GMT (Greeeenwich Mean Time) signal also known as the pips, will be inaccurate due to the signal processing. I have noticed a time delay of about 2 seconds between FM and DAB. When and if DAB is introduced will there be no further accurate time checks?
Tony Aston
United Kingdom - Member - Olde Member!! Engineering Fields - Instrumentation Engineering - New Member
04/28/2015 12:06 PM
Good point Tony. Ever since TV went digital I've been amazed at some of the time delays possible, playing 'live' TV on a tablet with the channel shown on Sky TV has a difference of almost 30 seconds!!
Shouldn't this op be Norway and Europe Planning to kill Analogue FM?
The UK has stated that digital radio switch-over is due in a few years, that was years ago LOL
John.
A little knowledge is a dangerous thing - Googling is far worse!
04/28/2015 7:36 PM
Maybe you could tune into WWV? Probably would need a really good antenna.
http://en.wikipedia.org/wiki/WWV_%28radio_station%29
Brave Sir Robin (2); Electroman (1); Rixter (1); tcmtech (1); Tony Aston (1)
