Learn how extruded rubber profiles are
made, and how custom fabrication converts elastomeric stock materials into
specialty seals and custom gaskets.
Rubber extrusion
is a manufacturing process that creates stock materials or profiles with a
fixed cross-section such as a U-shaped channel. First, uncured elastomers are
pushed or drawn through a specialized metal tool called a die. Later, the
rubber compound is cured through vulcanization, a chemical conversion process
that uses heat and sulfur to impart durability and improve mechanical
properties.
Rubber extrusion
is used with many different types of elastomers, and this rubber manufacturing
method supports complex cross-sectional profiles with an excellent surface
finish. Because extrusion mixes and blends the raw materials, the cured rubber
offers consistent strength and a uniform appearance along the length of the
profile. Standards from the Rubber Manufacturers Association (RMA) define part
tolerances based on physical dimensions and an RMA class of high precision,
precision, or commercial.
Extruding Stock Materials
Extruded rubber can
be vulcanized through static or continuous methods involving hot air, an
autoclave or microwave, or a salt tank. Static vulcanization conveys extrusions
to a workstation where rubber is cut-to-length and then placed on a metal pan
for curing. By contrast, continuous vulcanization feeds the rubber extrusion
directly from the extruder to the vulcanizing equipment.
Suppliers of rubber
profiles offer products in fixed lengths, but these stock materials may be
longer than your application requires. By working with a custom fabricator, however,
you can source the part lengths you need. For example, water
jet cutting converts stock materials to size by making fine, fast, accurate
cuts. No tooling is required, and this
cost-effective cutting technique is ideal both for prototyping and
low-to-medium volume production.
Custom Fabrication: Cutting, Splicing, and Taping
As an
experienced custom fabricator of industrial rubber products, Elasto Proxy keeps
hundreds of extruded
profiles in stock and cuts them to size with Ingersoll-Hand heads that
direct water-jets of 50,000 pounds per square inch. Unlike saw or guillotine cuts, water jet
cutting won't create beveled edges either. Smooth edges are easier to bond, and
available joining techniques include film splicing, cold bonding, C-press
injection molding, and vulcanizing.
Elasto Proxy
also offers taping services for sealing solutions that are ready right
out-of-the-box. When our bonded gaskets or gluing gaskets arrive on your
factory floor, workers can simply read the part labels, remove the plastic
backing, and stick on the gasketing. There's no need to install screws, make
additional cuts, or slow down the assembly line. If you're serious about lean
manufacturing and eliminating muda (waste),
try taped gaskets for your next project.
Learn More
Custom
fabrication is critical, but technical buyers and product designers must first
select the type of rubber profile that's right for the application. So what's
the best way to get started? Download Elasto Proxy's catalog and find solid profiles
such as bumpers, C-channels, E-strips, glazing seals, J-seals, P-strips, quad,
square and round cords, tubing, U-channels, strips, locking and self-locking
channels, and zipper strips.
Elasto Proxy's
catalog of industrial rubber products also features sponge profiles
in a variety of elastomers and durometers. Depending on your application
requirements, choose accordion seals, bulb seals, door seals, D-strips, lip
seals, and sponge cord. Lengths of
industrial tubing can be cut into tube rings, and the air that's trapped inside
acts as a shock absorber to aid in recovery. To get started, download our catalog.
