Learn how hot splicing creates endless gaskets such as
O-rings, door seals, and window seals.
Hot
splicing or vulcanization is a cost-effective joining technique for creating continuous
seals or endless gaskets from cut lengths of rubber
products. First, a heat-activated adhesive is applied to the ends of
sponge or solid profiles. In addition to rectangular profiles, rubber products
such as round cords, industrial tubing, and irregularly-shaped rubber profiles
can be hot spliced, too.
Next,
the ends of the profiles are pressed together and placed in a hot mold or
vulcanizing press. The heat activates the rubber-based glue, and pressure from
the mold or press creates a reliable, attractive joint for continuous sealing. Proper
dwell time is important, and hot spliced gaskets should be stored under
controlled conditions in warehouse environments according to standards such as
DIN 776 or ISO
2230.
Advantages of Hot Splicing
Hot
splicing is one of several different joining
techniques that are used with rubber products such as seals, gaskets,
and O-Rings. Choosing the right splicing method involves multiple factors, so
product designers need to consider the run quantity, material type, and performance
considerations. Film splicing, cold bonding, and C-press injection molding all have
their strengths, but hot splicing also offers advantages.
For
example, hot splicing is a good choice for bonding rubber
profiles that do not have an internal cavity. By contrast, C-press
injection molding involves the flow of an uncured compound through a cavity
where the profiles are under heat and pressure. Vulcanizing is used mainly with
small quantities, but is versatile enough to support rubber seals ranging from
simple O-rings to multi-sided door gaskets.
Vulcanized Splice Types and Rubber Materials
Gasket fabricators can use hot splicing to create several
different types of joints. Butt splices bond two ends of a seal with only
limited stress at the splice. Bevel splices are used in cross-sectional areas
that don't allow for butt splicing. Step splices provide maximum bond strength
and allow nominal deformation in a static seal. Corner splices are also used in
static applications, but when the joint is not under strain.
Gasket fabricators can also produce spliced O-rings and other
vulcanized rubber seals from different elastomers. Examples include Buna-N
(nitrile), chloroprene, EPDM, fluorocarbon, and silicone. Each rubber compound has
specific properties, but also has limitations (such as maximum service
temperature). Therefore, it's important to consider not just the splicing
method, but compound selection.
Spliced O-Rings, Endless Gaskets, and Other
Sealing Applications
Here at Elasto Proxy, we typically use vulcanization to produce spliced
O-Rings. Additional applications for hot splicing can include door gaskets,
window gaskets, and frame and lid gaskets.
Do you have questions about spliced seals? Do you need
vulcanized gaskets that are ready right out-of-the-box for installation in the
field or on an assembly line? Please contact us for more information.
