Derivations Blog
Derivations
Previous in Blog: Is Your DNA Your Private Property?   Next in Blog: Lasers for Relativistic Propulsion (Eventually)
7 comments
Ultrathin Lens Has No Chromatic Aberrations
Posted February 23, 2016 8:44 AM by Bayes
For all the optics fans out there, I found this article pretty interesting...
Ultrathin lens is free of chromatic aberrations
A new type of flat, ultrathin lens designed to be free of chromatic aberrations has been developed by researchers in the US. The device has a variety of potential applications, from ultralight imaging systems for drone aircraft to more compact lenses for mobile-phone cameras.Lenses for cameras, eyeglasses and other applications are traditionally based on refractive optics, which involves using curved lenses to bend light rays. The "optical power" of a conventional lens - how strongly it bends light - is proportional to its thickness, which means that a conventional refractive lens cannot be very thin. Refractive lenses also suffer from chromatic dispersion, wherein blue light bends more than red, and therefore multiple images are produced over a range of focal lengths. Multiple lenses can cancel out this dispersion, but this adds further to the weight, thickness and cost of a lens system. Diffractive lenses offer a route to ultrathin lenses by redirecting light using the interference between light waves as they pass through a series of slits in a thin opaque material. Such lenses can be effectively flat, and therefore much lighter and thinner than refractive optics. However, diffractive lenses suffer from much larger dispersion. And to further complicate matters, this dispersion is anomalous with red light bending more than blue.
Thin metasurface
In 2015 Federico Capasso of Harvard University and colleagues showed that a flat lens can be made that focuses all of the colours of broadband light in the same plane. The team then unveiled a device that focused broadband infrared light onto a single line using a thin metasurface. This device used dielectric resonators that interact directly with the electromagnetic field of light waves to impart any desired phase shift. However, this new technology brings its own challenges. Making the metasurfaces requires precision engineering because the resonators have to be smaller than the wavelength of the focussed light. Metasurfaces are also inherently polarization-sensitive, whereas a general-purpose camera lens needs to focus unpolarized light. Now, Rajesh Menon of the University of Utah and colleagues have focused broadband visible light using a different approach that involves creating a series of grooves in a soda-lime glass surface. The height and width of each groove was selected using a computer algorithm that optimized focusing across the entire visible spectrum. This involved using the conventional dispersion of the glass material to compensate for the anomalous dispersion of the grating, such that waves would be focused on the same line irrespective of wavelength.
Article Continues Here
Re: Ultrathin Lens Has No Chromatic Aberrations
02/23/2016 11:07 AM
Wow! That is a significant breakthrough. Thank you, Bayes.
02/23/2016 11:54 AM
This is an interesting evelopment. For now, the description implies that it works mainly for focussing light at a point. It doesn't say what the off-axis aberrations are, nor does it give the size of 'sweet spot' in terms of aperture or f/ratio.It also doesn't say what the spectral response of the lens is, i.e., what total range of wavelengths it will focus to a point. -- I'm not being critical, just curious.
I can already image a number of applications for this. And I'm eager to see future developments.
02/23/2016 9:41 PM
My understanding from reading the article is that the dispersion of the glass is used to cancel out the diffraction angle so that the resultant angles for the different wavelengths come out almost the same.
I have a transmission diffraction grating and most of the light just passes straight through. A small portion of the light is refracted to either side, the angle, of course, being dependent on the wavelength (color).
I'm curious how this will work as a lens if only a portion of the light is "diffracted" to a focus while the bulk of the light passes straight through to wash out the image.
I'm sure there is just something that I am missing here.
02/23/2016 11:24 PM
How is this different from Fresnel Lens- which could also be thin? Can anyone please explain in what way this is different?
02/24/2016 5:18 AM
The Fresnel lens in cross-section is a series of triangular steps reproducing the outline of a conventional curved lens, and is capable of producing a recognisable full-colour image, albeit with some irregularities. This new device has a flat "metasurface", whatever that is, and does not seem guaranteed to produce a recognisable image.
02/24/2016 11:54 AM
Thank you for the response.So the light bending is different wave lengths!!!! As mentioned in the next response- it may split light waves and not reproduce faithfully in visible range- which is a must for applications in Cameras.
02/24/2016 5:11 AM
If you follow up the references, you will see the lack of chromatic aberration applies only for "three wavelengths in the near-infrared region (1300, 1550, and 1800nm)". This is far from being photographically useful as yet.
Anonymous Hero (1); phph001 (2); Rixter (1); Usbport (1); xyz (2)
