Here are three of my favorite and most shared ideas to get the most from drills in your shop.
- Keep the drill short.
- Get the feed rate right.
- Replace the drill on schedule before it dulls.
Keep the drill short. Drills need a rigid
setup. Having extra length can lead to deflection and drill wander.
There is a reason that drills for screw machining applications are
short- we need the rigidity. I learned this while working as the
metallurgist for a steel bar company. I got a call from a customer that
my steel wouldn't drill straight. After a 3-1/2 hour drive to the
customer's shop out of state, I found a very narrow diameter drill
(maybe 3/16″) being held in a Jacobs chuck the size of my head, being
held on a Morse taper the length of my forearm. Or maybe a bit longer.
Add to that a very short cycle time, and the drill and chuck never got
to a repeatably steady location- they were vibrating until they entered
into the next workpiece. They could enter that workpiece at a number of
different locations based on that vibration and moment arm. We
shortened the setup considerably and suddenly the steel that we provided
was drilling straight, true and on center.
Get the feed rate right. When I was
learning machining, I was taught that the feed rate determines your
success in drilling. After years and years in shops like yours, I am
convinced that what I was taught is correct. Yes, the wrong speed can
burn up a drill. But getting the feed right assures that the chips break
up appropriately. that they will flow smoothly down the flutes. Proper
feed assures that the drill won't "chip out" on the cutting edge, and
also that the drill itself won't crack or split up the center from too
heavy of a feed.
Planned replacement of the drill before it
dulls will make you more parts per shift. This is an under- appreciated
way of thinking. In most companies, they have a purchasing culture and
want to get the most out of a tool before replacing it. In the most
profitable companies, they have a "respect the process" culture that
focusses on maintaining process control, not maximum tool life. By
replacingthe drill before it gets dull, they minimize downtime, They
minimize the production of defective parts. They minimize the creation
of workhardening in the parts produced prior to tool replacement. This
means less downtime, more trouble-free uptime, and more parts at the end
of the shift. Twenty extra minutes of production on a part with a ten
second cycle time is an extra 120 parts at the end of the shift.
Shippable, billable, no- anomaly parts.
There are other factors besides feed that influence drilling, I will grant you that.
Proper speed, proper coating, proper geometry, effective delivery of coolant- we could create quite a list.
But in my experience, the three factors that hold the secret to productive drilling in our precision machining shops are short rigid setups, proper feed, and planned or scheduled replacement. These three factors are the keys to getting more parts with less trouble out of your shop.
What do you think?
Photo credit: ENCO
