Speaking of Precision Blog
Previous in Blog: Upset Testing--Steel in Compression   Next in Blog: Alternative Career Plans if College Doesn’t Come Through
Orders of Magnitude – Key to Process Problemsolving
Posted June 14, 2016 3:00 PM by Milo
If you have an intermittent or periodic problem, start counting frequency of occurrence, and then figure out what the order of magnitude is compared to your process.
In our shops, order of magnitude reflects the relative scale of our processes and helps us see what is and is not applicable to the problem at hand.
To solve periodic or intermittent problems in our shops, the first step after identifying the problem is collecting data about “When” and “How often” it occurs. Then, comparing it to the orders of magnitude that occur naturally in your shop can help you narrow down the likely causes.
Relative frequency can be a big help, when you figure out that the frequency has some relationship or equivalence to some aspect of your process. For example, if the frequency is about equal to two occurrences per bar, than it becomes relevant to look at bar ends first, With two ends per bar, or the fact that you might get just two parts out of the first bar end, this tying of frequency to an order of magnitude denominator saves a lot of thrashing about to try to identify root cause.
What are some orders of magnitude that occur in your shop that you should consider for your problemsolving efforts on intermittent or periodic problems?
Material Order of Magnitude
  • Per Piece
  • Per Bar
  • Per Bundle
  • Per Lot
  • Per Order
  • Per Heat
  • Per Supplier
Your shop processes have orders of magnitude too.
Per Machining Operation
  • Per Spindle
  • Per Stock Up
  • Per Machine
  • Per Shift
  • Per Release
  • Per Batch
  • Per Lot
  • Per Production Order
How does this work? In a prior life I had an intermittent customer complaint for a twisted square bar product. The customer was counting bad pieces cut from bars in bundles.The frequency was extremely low, it was not at one per bar or one per ten bars, nor one per twenty bars. It turned out to be approximately, slightly less than “one piece per bundle.” Knowing that the frequency was that low, we were able to eliminate most of our upstream of bundle process steps. They would have generated much higher frequencies – more on the order of multiple occurrences per bar.
Based on our frequency being an approximate order of magnitude of one per bundle, we focused our investigation on the product and process at and after the bundle stage. Which was where our problem occurred-when a single bar end was being twisted by the movement of the last strapping and clip installation as it was tightened for packaging. the balance of the bar was held securely by the prior installed starps, but the tensioning unit grabbed one corner of a bar as it secured the final band around the bars, creating a twist in the end of the bar held under the tension of the clip that locked in that last strap.
Without comparing frequency of occurrence to orders of magnitude in our process, we would probably still be trying to figure out where in our process we could twist just one 14″ segment out of 3,260 feet of bars. We’d be in denial, and eventually lose the customer.
If you have an intermittent or periodic problem with your products, start counting frequency of occurrence, and then figure out what the order of magnitude is compared to your process.
Image credit
Re: Orders of Magnitude – Key to Process Problemsolving
06/15/2016 9:03 AM
Interesting technique. It may not pinpoint the problem but can sure narrow down the search.
