Semiconductor & MEMS Fabrication Blog
The Semiconductor Fabrication Blog is the place for conversation and discussion about manufacturing processing equipment, semiconductor test and measurement, products & services, and semiconductor materials. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Researchers Score Next-generation Semiconductor   Next in Blog: MEMS-based Microscope Shrinks Inspection Equipment Cost
3 comments
Still Searching for Breakthrough Battery Technology
Posted August 19, 2016 12:00 AM by Engineering360 eNewsletter
Industry news sources continue to report proposed alternatives to the lithium-ion batteries that power everything from laptops to electric cars. The latest candidate, lithium-sulfur batteries (Li-S), can store 4x the energy per unit mass of the Li-ion variety and can work at high temperatures without the slightly inconvenient side effect of catching fire. Nevertheless, no good deed ever goes unpunished. Li-S batteries can suffer sulfur depletion after a relatively short life, and polysulfides can contaminate the electrolyte. These researchers have alleviated such shortcomings using a coating technique called molecular layer deposition (MLD) that produces a stable battery up to 55° C.
Editor's Note: This news brief was brought to you by the Semiconductor & MEMS Fabrication eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Still Searching for Breakthrough Battery Technology
08/21/2016 6:54 PM
I always find these battery capacity issues to be lamely entertaining.
Years ago all there was was lead acid for high power applications and things ran fine on them but the cry was, "If only we had a battery that could hold 10 times ad much charge as a lead acid battery life would be great." and then the lithium based type came to be packing 10 - 15 times as much charge in the same physical space.
Now a guy would have thought that would have solved the problems and the want for a 10x capacity battery but no. Instead they decided to put lithium batteries that were 1/10 or less the physical size in to replace the lead acid units and started crying allover again about needing something with more charge capacity for the same volume.
Kinda makes yo wonder about how many engineers of time past that had nothing but LA to work with would feel if they knew what the Li guys of today have to work with?
I'd venture to say that reaching out from the great beyond and slapping them would be my guess.
08/21/2016 9:29 PM
I would venture to guess (not much of a guess) that making 10 times the power, with 1/10th the weight, and 1/10th the volume, was/is pretty standard for sending men to the moon (or wherever).
08/21/2016 10:57 PM
In a highly critical specialized application like that where there is no limit for costs it's possibly a somewhat justified application however if my Googling is correct they primarily used silver zinc batteries for the lunar missions which had a specific energy rating about about 1/3 - 1/2 of what a common lithium based battery has now.
For the average cellphone it's not a critical necessity being there are many cell phones out there that have outstanding run and standby times compared to the crap they push on the mass public.
The last company phone I had was an Android Comando model that had absolutely shitty runtime in its default setup. On a good day they couldn't make it through a 12 hour shift on one charge. After an extensive go through to shut down and or outrightly delete every non essential to work background app and setting most of us could get 15 - 18 hours run time on them but not always. In hotspot mode for getting online with our laptops out in the field they were good for maybe 2 - 3 hours.
My military spec Sonim however, right out of the box could go 8 - 12+ days in similar normal use and over 2 months in standby between charges.
