Previous in Blog: Heat Blankets, Diesel Engines, and Tier 4 Compliance   Next in Blog: Vibration Damping Materials and Acoustic Insulation
7 comments
Plastic Thermoforming | Plastic Contract Manufacturing 101
Posted November 12, 2016 8:42 AM by Doug Sharpe
Plastic thermoforming pre-heats a flat plastic sheet to a pliable temperature. Using either suction from a vacuum (vacuum forming) or both suction and pressure (pressure forming), the plastic sheet is then molded to the tool’s shape. These plastic sheets come in various material types, colors, finishes, and thicknesses.
Thermoformed parts don’t exhibit the sink or gate marks, porosity, and other undesirable surface conditions that are associated with injection molding. Instead, thermoforming provides a blemish-free finish along with fine details.
For example, pressure forming creates sharp, crisp lines and details; textured surfaces; and formed-in-undercuts. Zero degree draft on sidewalls is possible, too. Twin sheet forming produces hollow plastic parts with details on both sides.
Thermoforming also supports the use of CNC or robotic routing to cut or trim your plastic parts so that they meet your precise dimensional specifications. CNC and robotic routing remove excess or unwanted materials, and create clean edges that are free of burrs.
Advantages of Plastic Thermoforming
Custom thermoforming provides lower tooling costs and shorter lead times than other plastic parts manufacturing processes. In addition to machined and cast aluminum, thermoforming tools can be made of wood, epoxy, and other low-cost materials. Tool modifications are cost-effective, and on-the-fly changes support prototyping, short runs, and medium-volume production.
Types of Plastic Thermoforming
There are three type of plastic thermoforming.
  • Vacuum forming supports quick start-ups and efficient prototyping.
  • Pressure forming creates sharp, crisp lines and details; textured surfaces; and formed-in undercuts. Zero degree draft on sidewalls is possible.
  • Twin sheet forming produces hollow parts with details on both sides. Twin sheet parts are strong and lightweight, and can consist of dissimilar materials.
Plastic Thermoforming Materials
Custom thermoformed parts are made from plastics such as ABS, acrylic/PVC, HIPS, HDPE, LDPE, PP, PETG, and polycarbonate. Thermoplastics are a broad category of plastics that can be heated and cooled, and then melted and cooled again.
For product designers, choosing the right thermoplastic material means asking and answering a series of questions.
  • What is the application?
  • Do any regulatory requirements apply?
  • Does the part require a specific finish, color, or texture?
Plastic Thermoforming Production
Thermoforming equipment includes shuttle machines and three- and four-station rotaries.
  • Shuttle machines process one sheet at a time (single sheet thermoforming) and are ideal for lower-volume production runs.
  • Three- and four-station rotaries can hold multiple sheets (twin sheet thermoforming) and are faster and more cost-effective for higher-volume runs.
So whether you need quick-turn prototypes or high-volume production runs, heavy-gauge thermoformed parts can meet your needs.
Plastic Thermoforming vs. Injection Molding
Thermoforming and injection molding are manufacturing processes for creating plastic parts. Each process has its advantages, but thermoforming supports larger part sizes. Plus, product designers can consolidate multiple, smaller parts into a single, larger part. Plastic thermoforming also produces unpainted parts that are visually appealing, and is especially cost-effective with small-to-medium production runs.
Unlike thermoforming, injection molding uses plastic pellets instead of plastic sheets. The pellets are melted, then injected into a closed cavity via hydraulic pressures. Plastic pellets come in different material types and colors, but the only way to achieve a textured part is to use textured tooling.
This has implications for production costs. Complex tooling costs more to produce, and higher production volumes are then required to lower the per-part cost. For lower-volume runs then, thermoforming with textured sheets is a cost-effective alternative to injection molding.
The tooling that’s used for injection molding is also more expensive because of multiple actuating pieces and the strength that’s required under significant pressure. Thermoforming controls dimensions on one side – the tool side. By contrast, injection molding can control both sides and create walls with different thicknesses.
Re: Plastic Thermoforming | Plastic Contract Manufacturing 101
11/12/2016 10:42 AM
I'd just add that thermoforming will NOT yield a part with a consistent material cross section.
The heated sheet is stretched over, or pulled into a forming tool which can (usually does) reduce the thickness of the sheet in those areas.
11/14/2016 1:27 PM
Agree.
This post made me think of the Vac-U-Form, marketed as a toy when I was a kid. I had a friend who had one & we made a couple of things - interesting!
11/14/2016 2:21 PM
I ran a captive vac form operation years ago. We had 4 36 x 36 inch machines, but we actually had Vac-U-Form machine that we used for small, quick prototyping.
When a customer would come in first time, we'd pull it out of the box and watch their eyes pop when we told them this was our biggest machine. Most of them saw the humor.
Good Answers: 40
11/14/2016 2:50 PM
re: "thermoforming will NOT yield a part with a consistent material cross section"
100% agreed ... though (to be fair), with MANY products that isn't an issue. Especially if it's going to be reinforced, as a spa shell from acrylic being beefed-up with fiberglass [sold an awful lot of those, in Florida, in a previous life] ~ even there, the 'glass will NOT be "uniform thickness" either....
Pretty incredible technology, which, IMHO, hasn't been utilized anywhere NEAR as much as it could be, if new home designers (etc.) learned to apply their imaginations more. ["Yes", I know such things HAVE been done ... but, I'm not thinking "hokey-ufo-kee"...]
Cheers ~ !
11/14/2016 3:28 PM
I've got a patent on an intricate baffle design that my designers said could never be made.
It was essentially a clam shell device folded over and installed between chemical process chambers.
6,235,114 B1 if you want to look at the patent attorney's rendition.
That, does NO justice the actual part, which was hollow and had slots for an air curtain isolation effect. It fit between inter-digitized roller shafts for transporting .002 inch thick Kapton.
Good Answers: 40
11/15/2016 3:36 PM
"Mind boggling"...()!
Reading-thru the Description ("the invention concerns apparatus for contacting a thin, pliant circuit board sheet with pressurized streams of fluid to form a liquid coating over the surface of the substrate"), I thought that I might have a grasp of how such a ("contraption") device might actually be efficiently/effectively utilized, in a manufacturing schema.
"Involute apparatus" ... (?) Indeed! (Though, from my own vocabulary, I might have been restricted to using "Convoluted"...(!)
When I got to "separation of an axle pair is not desirable when a thin pliable substrate is passing through the apparatus because the leading edge of the substrate can curl and “dive” down into the space between the disks on one axle and the disks on the next successive adjacent axle" (1st, I had to return to your post, above)... I then began to "believe" that I had a grasp as to why such intricacy in the mechanism was necessary, given (your ending) "for transporting .002 inch thick Kapton".
Getting to "method for separating a first portion of treatment apparatus from a second portion of treatment apparatus", and throughout the subsequent Pic# <> Description <> Pic# <> Description (etc), I couldn't help but wonder {more-and-MORE}, just exactly WHAT chemicals / coatings / what-have-you did YOU have in mind (what specific application), while coming-up with that...?(!)
{? wearable / sports-related solar-cell suits, for Iron-Man-like performance increase...?!}
11/15/2016 9:27 PM
This equipment was used to make flex harnesses and rigid flex layers among other things.
Set up properly we could transport a continuous reel of Kapton through a process that would remove the excess copper from both sides of a 1 or 2 mil thick continuous roll of Kapton. Develop, etch and strip the product to leave a flex harness layer.
These lines could be 75 feet long with multiple chemical chambers with incompatible chemistries in each one.
Until the invention was born, the isolation curtains could not go below the top plane of the rollers. They allowed almost total interchamber contamination prevention because we could use them as a air curtain as well as a barrier, between the wheels. So, the physical opening went from 1.5 inches down to 1/4 inch or less.
These lines were also used to coat credit card sized cards and the line had to transport groups of hundreds down the conveyor without them migrating into each other along the entire distance.
The verbiage came from our patent attorney, who used those words to mask the true design elements. We had many discussions about how I thought he was not conveying the function properly. He patted me on the head and told me to let him do his job and I could do mine.
Again, more than you want to know.
lyn (4); Mikerho (1); ndt-tom (2)
