Caption This! Blog
Caption This!
Previous in Blog: Caption This 3/22/2019   Next in Blog: Caption This 04/05/2019
25 comments
Caption This for 03/29/2019
Posted March 29, 2019 4:45 PM by lmno24
Re: Caption This for 03/29/2019
03/29/2019 4:54 PM
The wet pink heat sink...
03/29/2019 9:42 PM
Another knee slapper from the book of dirty jokes for necrophiliacs.
03/29/2019 5:31 PM
Sid finally managed to transplant the first computer heart.
03/29/2019 7:35 PM
Looks like lmno24 has got a real cool computer?
03/29/2019 9:07 PM
I'm installing a refrigeration system in a couple of months....I'll beat that kid with this extra kick....
"You older gamer's are always looking for an edge."
03/29/2019 9:38 PM
A n'ice upgrade from the red Solo cup.
03/29/2019 11:06 PM
Hey! It works great! Now how do I scale this up for mass production and market it?
03/30/2019 12:34 AM
Must be an amateur crypto miner
Alienvisitor
03/30/2019 11:05 AM
PC illness's can be cured.
de-frag anti-virus dialysis
BEER ��
03/30/2019 2:14 PM
And it even makes a “pocketa-pocketa”sound when running.
03/30/2019 5:08 PM
I have finally reached the singularity.
After figuring out how to use oxygenated blood in my cpu cooling loop, I built the ultimate gaming computer using a gamers brain as the cpu.
Signed,
Dr. Frank N. Stein
03/30/2019 7:44 PM
I'll have Nirvana instead.
Much simpler.
03/30/2019 8:48 PM
I think we've found a memory leak in the new software build...
https://en.wikipedia.org/wiki/Memory_leak
03/31/2019 7:19 AM
"Flush Cache"
03/31/2019 8:37 AM
04/01/2019 7:10 AM
New revolutionary anti-virus kit for PCs: Domestos bleach kills all known germs dead.
04/01/2019 1:32 PM
After watching the youtube video where a guy hooked up his desktop water cooling system to an old-school hot water radiator and used it to heat a room, it's hard to come up with something to say about this.
I've seen crazier.
04/01/2019 8:48 PM
04/12/2019 11:57 AM
Well, the "room" was an enclosed closet, it was a rather high-end PC set to run benchmarking tests on continuous loop, and the amount of heat generated was comparable to the control setting, where the PC was sitting in the room with the normal water cooling system and running the benchmarking tests.
To be precise, the starting room temperature and the ending room temperature were identical between the tests to a few degrees,however, using the cast-iron radiator showed significant lag at the beginning, due to the increased amount of water and "heat sink material" that needed to be warmed to radiate into the room.
The bottom line was "It's possible, however, it's a bad idea, since the internal rust and scale buildup in the radiator cannot be fully flushed out, and that crud will mess up your pump over time."
Also, it was a YouTube video, when do they have to make sense to be posted?
04/01/2019 3:43 PM
Digital Kool-aid?
04/01/2019 8:39 PM
a warm kool-aid on a cool day..
this dudes got class up the ass.
04/12/2019 12:06 PM
Yes, this computer is portable.
04/13/2019 11:52 AM
And potable?
04/13/2019 2:11 PM
Don't drink the Kool-Ade, no matter what Rev. Jones says.
04/15/2019 10:11 AM
I told him that I.V. antibiotics wouldn't work on a virus... but would he listen?
Reply to Blog Entry 25 comments
abotha (1); adreasler (2); Alienvisitor (1); Dennis R. Levesque (1); jdretired (1); JE in Chicago (4); jhowdy (1); JPool (1); Leonf (2); lyn (2); Randall (2); redfred (3); Rixter (3); SolarEagle (1)
