Previous in Blog: Flex Fatigue Resistant Silicones: AA 59588 Class 3A and 3B Qualified   Next in Blog: Engine Compartment Insulation and Cab Insulation Samples
2 comments
How to Install Edge Trim
Posted July 20, 2019 10:03 AM by Doug Sharpe
Edge trim protects exposed edges and the people who come into contact with them. In addition to sealing and insulation, edge trim provides a finished appearance to surfaces such as the metal doors on vehicles, machinery, and equipment. Choosing the right type of edge trim for your application is important, but you’ll also need to install these seals with care. Otherwise, edge trim can buckle or separate.
In this article, you’ll learn how to select edge trim based on dimensions and material requirements. You’ll also learn some best practices for cutting trim seals, as edge trim is also known. You can buy lengths in bulk and cut them yourself, or you can buy edge trim that’s been cut-to-size for your application. Either way, you’ll need to install edge trim by pressing the seal onto the edge.
Learn More
Additional Information
Re: How to Install Edge Trim
07/22/2019 11:22 PM
I'm going to make a guess that edge trim is installed by placing the trim onto the edge?
07/29/2019 12:20 PM
You might be over-thinking this.
