Previous in Blog: Great White Shark May Not Kill with Brute Force   Next in Blog: New Fuel-Efficient UPS Delivery Trucks are Smokin' Hot!
3 comments
Voyager Probes Celebrate 30 Years
Posted September 05, 2007 9:28 AM
From BBC News | Science/Nature | UK Edition:
The US space agency's venerable Voyager mission is celebrating its 30th anniversary. Its two probes were launched within weeks of each other in 1977 to make a detailed study of the outer planets. The probes were then sent on trajectories that will eventually take them out of the Solar System and into interstellar space. Three decades on, they continue to return data from distances more than three times farther away than Pluto. Currently, Voyager 1 is farthest away. Launched on 5 September 1977, it is about 15.5 billion km (9.7 billion miles) from the Sun.
Good Answers: 213
Re: Voyager Probes Celebrate 30 Years
09/06/2007 11:20 AM
Some time back, I don't remember how long ago, NASA was contemplating a termination of this program just as the data returning was getting interesting. I recall a report suggesting that the Voyagers were mysteriously slowing down as they approached the edge of the solar system; at that time, no one reported a theoretical explanation for this apparent phenomenon. Any new information about the status of the NASA program, or an explanation for the slowing effect?
Good Answers: 109
09/06/2007 1:56 PM
A big share of this unprecedented success is coming from the marvel of a gyro from Teledyne Sytems that is on board and securing the orientation of the spaceprobe:
A dry tuned gyro suspending the rotor in a triple two-axis angularly compliant flexure hinge that allowed to eliminate most of prior known errors.
And a shaft suspended in ballbearings with a permanent lubrication system designed to recirculate the oil with a rate of near 10 to 100 microgram per day so within the 30 years since the start only 100 milligramm to 1 gramm has been pumped through the bearing allowing the almost indefinite life.
And many other significant achievements that made possible the very accurate aiming of the antenna towards earth so that with very limited antenna power of only 80W a communication over this incredible distance is possible.
The unknown reasons that may be responsible for the unexplained slowing down is very likely caused by the shock front that forms when the solar ionic wind hits the interstellar very diluted gas. Inside this shock-front the voyager is now traveling.
RHABE
Good Answers: 213
09/06/2007 4:23 PM
Thanks for your explanation. Many years ago, I was involved with fiber gyros- no moving parts. I used to throw a bobbin on the floor, then show it still worked as a gyro...No lubrication needed. Electronic dithering instead of mechanical, a la the ring laser.
You might be interested in: Electrical Test Probes, CMM Probes, Fiber Optic Probes
