Quality Control Blog
Quality Control
The Quality Control Blog is the place for conversation and discussion about product inspection technology, quality control methods & software, quality standards and compliance testing, defect prevention analysis. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Electronic ballast   Next in Blog: Communication with a computer
2 comments
Fire and Safety
Posted September 27, 2006 5:29 AM by nvmani
Pathfinder Tags: safety
User-tagged by 5 users
If you wish to conduct a training programme on "FIRE & SAFETY",in a Petoleum refinery or an hydrocarbon processing plant,coverage can be as listed below. 1) SAFETY CONSIDERATIONS IN OIL INDUSTRY 2) SAFETY ENGINEERING 3) CONCEPT AND EFFECTS OF FIRE AND EXPLOSION 4) CLASSIFICATION OF FIRES 5) HAZARD IDENTIFICATION AND CONTROL 6) HAZARDS OF MATERIALS 7) SOURCES OF HEAT ENERGY / OXIDANTS 8) FIRE AND EXPLOSION PROTECTION 9) FIRE FIGHTING FACILITIES 10) FIRE /EXPLOSION DETECTION AND ALARM SYSTEMS 11) ELECTRICAL SAFETY 12) DISASTER MANAGEMENT 13) CHEMICAL /OIL SPILLS 14) SAFETY IN CONSTRUCTION 15) SAFETY IN DESIGN OF PLANTS 16)MAINTENANCE INSPECTION BASIS 17)PRESERVATION OF IDLE EQUIPMENT 18) CODES AND STANDARDS - FACILITIES AND PROCEDURES 19) SAFETY AUDITS 20) ACCIDENT ANALYSIS 21) CASE STUDIES / DISCUSSIONS- INCIDENTS Contents shall be designed specific to plant.
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
Re: Fire and Safety
09/28/2006 6:55 AM
Mr.Mani
If you are based in india then you can refer Oil industries safety standards (OSTD)published by ministery of oil and Gas and National Fire protection association of US normally refered as NFPA specifies all aspects of fire safety (Detection and proctection) OSTD would give you all aspects of fire protection as applicable in india.
good luck
Run silent run deep
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Re: Fire and Safety
09/28/2006 9:18 AM
Information contained in your message is quite useful. Thank you very much.
nvmani
