Previous in Blog: Solving Solar System Quandaries is Simple: Just Flip-flop the Position of Uranus and Neptune   Next in Blog: w00t
4 comments
Litroenergy Promises 12+ Years Of Free Glowy
Posted December 12, 2007 5:18 PM
From OhGizmo!:
What happens if you stuff some tritium inside a phosphor-coated microsphere? According to a company called MPK, you get a substance that will glow continuously for over 12 years (half-life) without requiring any energy input. The tech is called betavoltaics, and unsurprisingly, it uses a radioactive gas (the aforementioned tritium) as a power source. But before you go running for your lead underpants (or one of these), you can be somewhat comforted by the fact that tritium radiation (beta particles) can be safely contained by the microspheres it lives inside. The Litrosphereâ„¢ materials (which can be in the form of paint or injection-molded plastics) are not affected by heat or cold, can emit just about any color (except white, I'm guessing), and can cover a standard sheet of paper for 35 cents. The inevitable downside (besides the radioactivity, I mean) after the jump. However, the general consensus seems to be that this technology will not get very far when it comes to replacing traditional lighting. According to some guy with a Ph.D., "The intensity is not very strong. This is good enough for night illumination of rifle scopes, watches, and emergency signs but it is not going to come anywhere close to matching the light output of or replace electric light bulbs (incandescent, flourescent, LED, etc.) or kerosene lanterns." That said, there's a big difference between no light and some light, and if it's cheap and requires no maintenance, why not put it all over the place? The thing to keep in mind, of course, is that you cannot physically turn the light off.
Good Answers: 230
Re: Litroenergy Promises 12+ Years Of Free Glowy
12/13/2007 2:42 AM
Thanks for the article.
I had a couple of these lights enclosed in small spheres.
They were used in "Trilux" rifle scopes:
http://www.amerisurp.net/scopes_trilux.htm
The light could be "turned off" by rotating a knobbed shutter - the light still glowing inside, but you could not see it any more.
Unfortunately the Tritium gas decays and the light output weakens then dies.
So you just reminded me to try and get some new spheres, but no point in buying in a bulk supply, because they all decay at the same rate and time.....
Good Answers: 94
12/14/2007 5:32 AM
I have some small tritium cylinders that were used as markers on avionic instruments when I was designing them in the late 1970s. The last time I looked, probably within the last 9 months, they were still glowing away. I'll have to check them over the weekend.
12/15/2007 10:48 AM
uhhh, is this free energy?
Good Answers: 230
12/15/2007 3:15 PM
Some may call it free, but is quite costly to make.
Normally made by background Cosmic Radiation, or from Nuclear Reactors.
Tritium gas is expensive, and you cannot keep bulk supplies, because of its radioactive decay.
There is a good reference page here:
http://www.physics.isu.edu/radinf/tritium.htm
Kind Regards.....
Anonymous Poster (1); Nigh (1); Sparkstation (2)
