Shock, Vibration and Noise Blog Blog
The Shock, Vibration and Noise Blog is the place for conversation and discussion about shock absorbers, dampers and gas springs; noise control and measurement; vibration/acceleration control systems; and machine mounts and vibration isolators process control tools, specialty chemicals and health and safety. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Building a Better Bridge?   Next in Blog: Does Vibration Test Give You the Shakes
Dragon Skin Debuts
Posted December 25, 2007 7:46 AM
When the military places soldiers in harm's way, it would seem logical that they be equipped with the best body armor that technology can provide. The new Dragon Skin design appears to garner the rave reviews. Can you think of any manufacturing applications for this shock-absorbing design?
The preceding article is a "sneak peek" from Shock, Vibration & Noise, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Shock, Vibration & Noise today.
Re: Dragon Skin Debuts
12/27/2007 1:27 PM
I think the next step is to enlarge segment and fill each cell with a pressurized reactive foam ingredient which when air activated is designed to prevent fire on the body, as well as protect against ammunition fire, but only where activated. A type of self sealing compound which helps to resist heat penetration, while being able to be individually replaced, as needed.
Now that ceramic individual cell armor plating is an option, each cell should be wired into a real time reaction impact sensor and then allowed to react to various levels of intense heat.
One project in mind, was to design an external fire shield / ballistic reactive skin, for foam and steel wall systems, which would react under direct impact.
The thought was, by keeping the contact point over 12" from the core portion of building to be shielded, and by containing a fire resistant safety foam for location based fire protection, the building would be able to resist regional assault by hand held grenade launchers or RPG's, while being serviceable.
A self contained personal fire extinguisher suite, for buildings, aircraft, bus and the like. I visualize your product in a thicker, more 3-D product with options for internal components and compounds.
Too bad you cannot use it for Turbine housings.
