Electronic Test Equipment Blog Blog
The Electronic Test Equipment Blog is the place for conversation and discussion about test instruments, board & assembly test, inspection & test, test equipment, and anything else related to the electronic testing field. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Do We Need a Revolution in Electronic Test?   Next in Blog: Would You Build Your Own Test Setup
Design for Compliance Testing
Posted January 18, 2008 8:00 AM
You've heard of Design for Manufacturing and Design for Test. But what about those compliance requirements? If you can clearly define what makes your product compliant, engineers can build both test and compliance into the design phase. What are you doing up front to make sure that PCBs pass all testing?
The preceding article is a "sneak peek" from Electronic Test Equipment, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Electronic Test Equipment today.
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
Re: Design for Compliance Testing
01/18/2008 11:33 PM
ANSI has published standards for design compliance on almost all fields of engineering in addition IEEE,IEC and ASHRAE have published documents on design compliance but you need lot of time to dig out these documents and it costs a lot to purchase these documents thats all.IEEE has wealth of documents on PCB design you need to refer the same.your institutation where you are working should become member of these above mentioned organisitions then you would get access to these documents.
crm
Run silent run deep
