From Born Rich:
We have earlier told you about some innovative radiators
including Tubor Mirror Radiator with built-in digital clock and hi-tech
radiator with built-in AM/FM Radio. But, this LED Radiator by Aeon is second to
none. The leading radiator brand has added a whimsical approach to its radiators
line with the Speira LED Radiator. The helix-shaped design looks more like a
piece of art and is designed to be the focal point of your living room. Speira
is constructed from 120 individual satin finish brushed stainless steel blades
sited precisely at 90 degrees to the next and curving through 180 degrees from
top to bottom over the full 2,400 mm height of the design. LED lights are
housed in both the top and base of Speira to impart a subtle laser-like effect
across each blade. The suave structure not just radiates warmth but will
lighten-up your aesthetics, wonderfully.
