Industrial Processing Equipment Blog Blog
The Industrial Processing Equipment Blog is the place for conversation and discussion about fluid and gas handling equipment; thermal processing; solids handling; and filtration, separation and recycling. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Combating Combustible Dust   Next in Blog: Corporate Citizenship
Screening the Screens
Posted April 25, 2008 9:09 AM
The workhorse of any screening machine is the woven wire mesh. In different configurations, these screens are used to filter and separate all kinds of materials. To specify the right screen for the process, you must know four key components: mesh count, wire diameter, opening, and open area percentage. Other considerations include selecting the right material used to make the mesh, from stainless steel to polymer to nylon. (Select "Screening Bad Screening Methods" from the left-hand navigation menu.)
The preceding article is a "sneak peek" from Industrial Processing Equipment, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Industrial Processing Equipment today.
Re: Screening the Screens
04/27/2008 11:26 AM
Additionally, if you choose a stainless steel or oil quenched wire and want as much as 3-7 times additional life have the screen hard chrome plated with a minimum of .010" thickness. Hard chrome will not resolve damage issues but will reduce wear, provide anti stick surface and reduce corrosion on the coated surface.
