Nano Technology Blog Blog
The Nano Technology Blog is the place for conversation and discussion about materials and structured products, devices, manufacturing and commercialization, and R&D. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Nanotech Detects HIV   Next in Blog: Changing the Macroscopic Mindset
5 comments
True Black
Posted December 01, 2006 10:00 AM
Pathfinder Tags: black metal
By chance, a University of Rochester research team led by Professor Chunlei Guo has created a means of rendering metal "pitch black." An incredibly intense laser burst alters a metal's surface so that it can absorb virtually all the light that falls upon it. The number and variety of potential applications, says Guo, are surprising.
Re: True Black
12/17/2006 10:24 PM
What are the effects of such a laser burst on the fatigue failure bahaviour of the metal. this finding has implications in aerospace and defence applications , but what about the strength of the metal?
Re: True Black
01/13/2007 11:24 PM
True black is achievable by many processes, but using a laser is new to me. I like to expose soft silver to 60% nitric acid at 94 degrees F for 10 seconds and rinse. The surface becomes pitted with fine conical pits that readily absorb light. The material is used on solar panels. Some folks use hydrochloric acid to produce black silver powders used in clear panels that use fluid and silver black rather than carbon black as the thermal absorber in the fluid.
Your work is certainly impressive and I'm looking forward to reading those references. Apparently the quality of photo black is excellent. I think a car that would be very difficult to see at night were it photo black. But sensors could benefit for sure. How about antennas? So many applications, so little time.
Location: Bolingbrook Illinois, a southwest suburb of Chicago.
Re: True Black
01/21/2007 4:44 PM
I doubt that this enhances the corrosion resistance of the metal. Does it need to be vacuum encapsulated?
RichH
"People find it easier to forgive you for being wrong than for being right" J K Rawlings
Good Answers: 117
Re: True Black
01/25/2007 12:31 PM
This might be more useful for printing part numbers, assembly instructions and so forth on units when they are still in prodution.
Also, wasn't it Edison who wanted to photoengrave books onto thin sheets of nickel? This might be better. How about pictures which could last nearly forever? Warning tags and signs come to mind.
Engineering Fields - Marine Engineering - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Re: True Black
07/10/2007 9:08 AM
What! any good for stealth weapon skins and acoustic absorbtion?
Reset, Reset
davah (1); NoSciFi (1); sabo (1); sirius1845 (1); Yusef1 (1)
