Previous in Blog: Cylinder Load: Newsletter Challenge (07/01/08)   Next in Blog: Eyes of the Submariner: CR4 Challenge (07/15/08)
80 comments
Electrons In A Circuit: CR4 Challenge (07/08/08)
Posted July 07, 2008 5:01 PM
As you well know, when you close the switch in the following circuit, electrons start migrating from the negative terminal of the battery to the positive terminal
If the circuit is made of silver wires and its length is 10 meters, how long do you estimate that it will take for electrons starting at the negative terminal of the battery to reach the positive terminal? Almost instantaneously? Less than one second? Minutes? More than one hour?
And the Answer is...(updated July 15, 2008 - 8:46 AM EST)
The answer is it will take one electron several hours. We know that real electron speed inside a conductor is close to the speed of light. However, the electronics do not move in a straight direction. Inside the conductor they move back and forth as they approach the positive terminal of the battery, because as they move they collide with fixed atoms. Every collision sets them back (opposite to the field that moves them toward the positive terminal of the battery). After a collision they move again toward the battery. Their speed between collisions is close to the speed of light, but their actual migration speed (drift) is much less. In fact, the net migration speed (toward the positive terminal of the battery) is extremely low. Depending on the size and type of conductor they move at a small fraction of a centimeter per second.
This means that for an electron to move a distance of 10 meters will require some hours for the trajectory. Just for the sake of this question, let's assume that for the problem at hand (silver wires, 10 m long) the electrons move at a speed of 0.1 cm/s (not unreasonable). For this case the time to move a 10 m distance will be
Re: Electrons In A Circuit: CR4 Challenge (07/08/08)
07/08/2008 8:45 AM
Finger-in-the-wind, about half an hour.
07/08/2008 9:05 AM
In a solid the drift speed is in the order of millimeters per second ... so to estimate say five millimeters a second.
10 * 1000 / 5 = 2000 seconds
so ... 33 minutes and 20 seconds .... ish
07/08/2008 9:09 AM
More than one hour, probably closer to a day. Off the top of my head.
Charlie don't surf.
07/08/2008 12:16 PM
Taking a classical approach for now, I would expect "more than an hour":
If we assume that the significant movement is due to uniform drift of electrons along the wire, the relevant parameter is the total charge in the free electrons in the wire. Assuming one free electron per silver atom, that is about 6.1022 electrons/cc, or 9.4 k-Coulomb/cc.
Thus, if we assume the wire has a cross-sectional area of 0.1-sq-mm, the total charge in the wire will be 9.4 k-Coloumb. With a current of 12-mA as shown, that would correspond to about 217 hours, or 9 days.
Notes:
a) For extremely fine wire, less than 25-um [or one (US) mil] in diameter, it would take less than an hour.
b) For a), I've assumed the volume of the resistor is small. That needn't be the case compared with 25-um wire
c) I haven't checked whether diffusion would intermix the electrons rapidly enough to make drift irrelevant (I doubt it, but...).
d) Do electrons in a cloud maintain sufficient individual identity to make this meaningful?
07/08/2008 1:03 PM
I checked on diffusion - sort of:
In an hour electrons in silver might diffuse about 10-cm, so not as wildly far away from the challenge's distance as you might expect.
But I don't have the proper tools or data to hand, so it's using data that is very indirect - and may indeed be wildly out for some of the non-fundamental data.
07/08/2008 1:43 PM
Almost instantaneously.
The uniform drift theory is a swell theory, and the movement of the "charge cloud" has, I'm sure some valuable uses, but it is relative to averages. Some electrons are booking along, some will be stable, and some are going to be involved in traffic accidents.
Now, as was already mentioned by other, the time decreases proportionally to decrease in cross section of the wire. [In the uniform, or cloud theory]
So, Suppose we have a silver wire one atom in diameter [and also that we could keep it cool enough not to burst into flame instantaneously]. How fast then? Darn near instantaneous!
Now transpose this to [say] 18AWG silver wire. There is inside the 18 AWG wire a [an abstract] wire one atom thick that the luckiest lil electron is going to take to make it to the positive post on the battery in [relatively] no time at all.
Add a bit of lateral movement as the path is not likely to be straight, and a compensation for the under-defined resistor and we still get
tom
07/08/2008 4:56 PM
Too much arm-waving for my taste. Sure, the electrons don't simply travel in a tight group, but we can put numbers to this - and they don't stack up with what you write.
18 AWG wire has an area of about 0.8-sq-mm, enough for the average transit time to be in the order of 72-days. That is what will determine the accelerating field, and hence the acceleration of the electrons. The time between collisions is in the order of 0.1-pS, so the variance on this 72-days will be less than 1-ms, and the charatersitics close to Gaussian - so, the statistical variation due to variable collision times would result in all (yes, every single one) of the <1024 electrons arriving within 11-ms of the average time. As the variance decreases with decreasing average time, we can see that we cannot rely on statistical variation of drift distance to provide electrons within the hour.
. The other effect we might consider is thermally driven diffusion. Again the statistics are Gaussian, and the expected distance is 10-cm. Thus, the furthest that the fastest electron might travel along the wire is is 1.1-metres, and this does not depend on the diameter of the wire.
. OK, if you make the wire thin enough, it would become warm; but even if you heated it to the melting point, that would not increase the greatest distance travelled in the wire (i.e. by the fastest expected single electron) beyond 2-metres.
07/08/2008 7:30 PM
Looking at previous replies, can I ask everyone if we're allowed to tag each electron, so we know which is which ?
07/09/2008 4:31 AM
Quantum mechanics does not permit the labeling of individual electrons in a way that makes them all indistinguishable. This fact has a big influence on the statistical behaviour of multiple electron systems, but probably does not significantly influence the answer to this question or the observation by "Physicist?" that all the electrons take almost exactly the same time to travel along the wire.
Elroch
07/09/2008 5:22 AM
Supplementing Elroch's answer: electrons are distinguishable only by virtue of their states. That includes their kinetic energy and their location. In principle you could track one all the way along the wire - albeit the energy required to observe and identify it and the frequency of the required observations would at best significantly modify its temperature and reduce its drift velocity (so in this case the watched electron is indeed the last to boil).
07/09/2008 8:56 AM
To extend this diversionary discussion a little further, the point I was trying to make was that even when you have knowledge of the states of electrons, you cannot tell which is which in general. eg) you send two electrons down the wire, one with up spin and one with down spin. At the other end you detect two electrons, one with up spin and one with down spin at different times. There is no way in general to tell which electron is which - the spins may have swapped over. The only practical exception to this is when the two electrons are known to have remained out of range of interaction with each other (and any other particles which might have affected their spin to confuse the issue).
I have labeled this comment of mine "off-topic", as it has virtually no relevance to the original question, which has been well answered by BobD and Physicist.
Elroch
07/10/2008 6:07 AM
Agreed - I think that corresponds to my remark d) in post number 4 - and also the ridiculously high frequency of observation and observational energies required to maintain* the identity of individual electrons in a wire.
*I think I use that word advisedly - even though it is not strictly my area of expertise.
07/10/2008 7:43 PM
Hey, guys, didn't you see the smiley? Loosen up!
07/12/2008 3:32 PM
Don't get tetchy - sometimes the truest things a written in jest (should that be guest?) - gives us pedestrians the chance to clarify what passes for our thoughts.
[Speaking for myself - apologies, Elroch if you don't feel the same way].
07/12/2008 6:35 PM
I should clarify that the smiling face represented my happiness at seeing the question answered well, and should not be mistaken for an indication of lack of seriousness, or even jocularity. I support constructive, friendly discussion by anyone who wishes to exercise their brain.
Elroch
07/13/2008 7:18 AM
I could be wrong, my interpretation was that JohnDG was referring to his smiley, and disciplining us for allowing his posting to stimulate something approaching serious discussion.
07/08/2008 11:26 PM
I will assume that the silver wire has a circular cross section with a 1mm diameter which equals cross-sectional area of 0.8 X 10-6 m2
Current flowing in wire is (voltage/resistance) = 0.012 A
Atomic weight of silver = 108, Density of silver = 10.5 X 103 kg m-3, charge of electron = 1.6 X 10-19C, Avogadro's number = 6.023X1023
Avogadro's number indicates number of atoms in mass of substance equal to its atomic weight (in grams), ie, 108 grams of silver contains 6.023 X 1023 atoms
Since the valency of silver is 1, each atom of silver contributes one free electron.
Therefore number of free electrons per kg of silver = (6.023 X 1026)/108
And number of free electrons per unit volume of silver is:
(number of free electrons per kg) X (density of silver)
n = (((6.023 X 1026)/108) X 10.5 X 103) m-3
Current flowing through wire = (number of free electrons per unit volume of silver) X (charge per electron) X (crossectional area of wire) X (electron drift velocity Vd)
Therefore Vd = 0.012/(((6.023 X 1026)/108) X 10.5 X 103 X (1.6 X 10-19) X (0.8 X 10-6) )
Vd = 1.6 X 10-6 ms-1
To travel 10m would take 6,250,000 seconds = 72.3 days approximately
The drift rate will depend on the cross-sectional area of the silver wire. The smaller the wire the greater the drift velocity (assuming constant current flow). To get the drift velocity high enough to take 1 hour for electron to drift 10m = 2.77 X 10-3 ms-1 would require a wire cross-sectional area of approx 5 X 10-10 m2. This would have a significant resistance so would reduce the current flow in any case resulting in lower drift velocity.
Reply Good Answer (Score 4)
07/09/2008 12:42 AM
Hi BobD,
I see we are at least in the same ballpark with our figures.
I give you a GA as you pipped me to the post
07/09/2008 1:04 AM
Hi MFM,
I think we are more than in the same ballpark. If I substitute your wire cross-sectional diameter I get your answer of 90.3 days.
07/09/2008 12:55 AM
I finally manage to see why our answers differ, although in the same ballpark.
You assume the wire is 0.8 mm2 while I have assumed 1 mm2 which is why you have got a lesser number of days 72.3/90.3 = 0.8
07/09/2008 4:20 AM
Equivalent to mine too (#4), once you account for the factor of 10 area. But I can't for the life of me see why the pair of you want to go to the velocity and back again; surely you only need to know when a charge corresponding to the total valence electrons in the wire has flowed?
Incidentally, with regard to BobD's comment about the wire resistance: in the hypothetical limit of zero-thickness wire (or if you short-circuit the resistor), the time would still be as long as 20.7 minutes (at 20OC).
07/09/2008 6:29 AM
Yes you are right we did not have to calculate the drift velocity to determine the time for electron to travel the distance. I agree that your approach is quicker and simple, I just didn't think of it at the time.
07/09/2008 8:43 AM
Thanks
Fyz
07/09/2008 12:51 PM
The flow of electrons in the wire is somewhat analogous to water flowing in a pipe. The number of electrons is analogous to the number of water molecules or maybe cubic inches of water. The number of electrons per second (or amps) is analogous to the flow rate (as in gallons per minute) in the pipe. A larger wire diameter is analogous to a larger pipe diameter. The resistance of the wire is analogous to the pressure drop in the pipe. The larger the wire diameter, the lower the resistance. The larger the pipe diameter, the lower the pressure drop.
In the challenge, the resistance in the wire is likely much smaller than the 10 kohm resistor. If a pipe flow analogy, the resistor would become a restriction such as an almost closed valve. The vast majority of the voltage drop will be in the resistor and the vast majority of the pressure drop would be in the valve. Not knowing any better, I'm assuming the average time for an electron to cross the resistor is small because of my valve/resistor analogy. There just isn't much volume in the valve. I realize the material of the resistor is not the same as the wire but I'm not sure how else to treat that part.
Silver is a good conductor because it has a single electron in its outer shell. This is a relatively easy electron to displace but the rest are almost impossible to displace. Therefore, we have one movable electron per atom.
I am assuming a wire size of 0.010 inch diameter or 30 gauge. This has a cross sectional area of 1.22 x 10-5 cm2. Silver has an atomic weight of 107.8682 (grams/mole) and a density of 10.5 grams per cc. This gives 0.09734 moles/cc or 5.86 x 1022 free electrons per cc. This divided by the cross sectional area is 7.13 x 1017 electrons per cm.
At 12 volts and 1000 ohms, the current is 0.012 amps. One amp is 6.24 x 1018 electrons per second per amp. We have an electron flow rate of 7.49 x 1016 electrons per second. The average flow rate (7.49 x 1016 electrons per second)/( 5.86 x 1022 free electrons per cc) = 0.105 cm/sec or 2.6 hours per 10 meters.
If we vary the wire diameter (and the assumptions still hold), then we can get a time of one hour for a wire diameter of 0.00715 inches and a time of one minute for a wire diameter of 0.0008 inches.
However, if we include the resistance of the silver wire, there is a minimum time. As the wire gets smaller, the resistivity of the wire increases. The resistivity of silver is 15.87 nano ohms m. As the wire gets smaller, the resistance gets higher inversely proportional to the diameter. Since the flow rate of electrons (electrons per second) is also directly proportional to the area, at some point there is a minimum time for the electrons to flow the ten meters. As the wire diameter gets smaller and smaller, the 10 k resistor becomes less and less of the total resistance. I have calculated a minimum time of 0.345 hours or 20.7 minutes.
I'm not really that sure how good this answer is. It assumes that all of the outer shell electrons move as a steady flow. Kind of like plug flow in a pipe where everything moves together. In real pipe flow, the flow near the center is faster than the flow near the pipe wall. Maybe something similar occurs with the movement of electrons in a wire. I hope someone can give us a little more understanding of what really is happening with the electrons in the wire.
I've given BobD a good answer. He followed a similar approach but got there much sooner.
Location: City : Chandigarh, Country : India, Continent : Asia, Planet : Earth, Galaxy : Milky Way, Universe
07/08/2008 11:53 PM
If Switch is not closed : Electrons will never reach.
If Switch is closed : Electrons will reach Instantaneously.
Karma is Dharma
07/09/2008 12:25 AM
28 minutes
07/09/2008 12:32 AM
Current = 12/1000 = 12mA or Coulombs/second
Number of electrons per second=
(12 X 10-3 C/s) / ( 1.6 X 10-19 Coulombs/electron) = 7.5 x 1016 electrons/s
Now for Silver conductor the atomic weight is 107.8 grams/mole.
Divide this by the number of atoms in a mole (6 X 1023 ) to get
17.97 X 10-23 grams per atom
SG of silver is 10.5g/cm3 , therefore the number of atoms per cm3 =
(10.5 g/cm3 ) / ( 17.97 X 10-23 grams per atom ) = 5.84 X 1022 atoms/cm3
Assuming wire is about 1 mm2 ( 10-2 cm2 )in cross-section, one metre (100cm)
length has a volume of 1 cm3 .
Assuming 1 electron per atom involved in current flow, the average drift speed of the electrons will be:-
(7.5 X 1016 electrons/s) / (5.84 X 1022 atoms/m) = 1.28 X 10-6 m/s
Time for 10 metre trip = 10m / (1.28 X 10-6 m/s) = 7.8 X 106 seconds
= 2,166 hours = 90.3 days
Good Answers: 15
07/09/2008 12:40 AM
Propagation Delay: 85% speed of light
speed of light in a vacuum = 300,000,000 meters/ second
Therefore Speed in Silver wire = 255,000,000 m/s
So at 10 Meters, Propagation from terminal to terminal = (1/255,000,000)x10
3.921568627450980392156862745098e-8 or 39.22nS ?
Hmmm I think something wrong here, calc, been too long..
07/09/2008 1:08 AM
I think you may be confusing the speed of propagation of the electromagnetic field with the speed of drift of the electrons in the wire.
07/09/2008 2:33 AM
For explaining the difference between propagation speed and speed of each constituent part alone, consider a non-deformable pipe full of water. The pipe may be as long as you desire, but as soon as you switch on the tap on the one end, water will almost instantaneously appear at the other end. Nevertheless, you can make water in the pipe flow as slow as you wish...
Maybe BobD and Maths_Physics_Maniac answers seem at absurd, but indeed, electrons need not travel that fast to produce some good amount of electric current (even enough to kill you), as there are sooo many of them. Imagine Amazon river for instance. Its waters may seem still, but nevertheless the flow of water is enormous.
tkot
07/09/2008 4:55 AM
less than a secnd
07/09/2008 5:01 AM
wow, good question.
My answer is electrons never arrive at positive terminal from negative terminal forever !!!
electron can move only very tiny distance at very lower speed, only electric field can transmit instantially all circuit. even if the length is up to 10000km.
electric field speed is 300000km, as we all know.
07/09/2008 7:11 AM
But if they do move but they don't arrive at the end, as you claim, then they must be accumulated somewhere! (Unless they oscillate, of course...) Apparently this is not the case.
tkot
07/09/2008 6:26 PM
They'll drift at about walking pace...say 4miles per hour, so about 6000m/hour. So 100m/min.
That's 10m in 6 seconds
07/09/2008 7:47 PM
Does it really matter, they will get there & hopefully in time for dinner.
07/10/2008 6:32 AM
I always thought cats stopped for regular rests - that might get you closer to the minimum possible time.
Presumably the drift rate comes from some published figure that covers a different special case?
Hobbies - HAM Radio - CE3AM....4X4SW....CE3NSW
Good Answers: 7
07/09/2008 8:23 PM
  • If you would be able to "mark" a single electron, close the switch and wait until it arrives at the positive terminal, you will have to wait a very long time. as it may never arrive...Electrical conductivity is a series of electron movements within the molecular frame. They "bang" into each other in a polarized direction, but actually never migrate. I believe the question should be asked a little differently.
  • How long would it take from the first "bang" to the last? Sort of, how long will it take from the first Domino to move until the last one falls down...
My 5 cents...
Wangito.
Never trade luck for skill.
07/09/2008 8:51 PM
Where do you people come from? Electron flow has been the theory for many years:
http://en.wikipedia.org/wiki/Electric_current
07/09/2008 9:08 PM
what is the diameter of the wire?
07/10/2008 6:49 AM
I think we should assume that the information provided in the challenge defines the parameters; in this case, that the wire resistance is sufficiently low that the 1-k resistor sets the current to within about 30%.
07/10/2008 7:55 AM
Does the resistor limit the number of electrons or their speed?
I asked a few but they just drifted on by humming to themselves...blue shiny bas*ards
07/10/2008 9:09 AM
The answer must be the speed, as the number of free electrons in the wire stays essentially the same, regardless of whether there is a resistance added to the circuit. The way it achieves this is by decreasing the voltage gradient in the wire (most of the voltage difference is across the resistor).
Elroch
07/10/2008 10:04 AM
Your answer doesn't make sense to me, maybe it's badly explained.. or I'm thick (which I know isn't true)
Any mention of the wire is irrelevant, we can consider it a perfect conductor with infinite free electrons if you like.
I was asking about the resistor....thus your statement
' as the number of free electrons in the wire stays essentially the same,' is no help.
...the thing about voltage gradient is obscure in the extreme...it's just a re-phrasing of ohms law and doesn't answer anything.
Forget the wire!
Back to my question.....
Does the resistor slow 'em down or limit their number?
07/10/2008 10:32 AM
I too didn't understand your question originally. But: the answer could be both - it depends how you look at things; but: if we assume linear resistors and conductors, the answer that the resistor determines the velocity at every point is certainly appropriate. On the other hand, what we are concerned about is the number crossing the boundary between the wire and the battery terminals - so you could say that the resistor also determines the number/second - but mainly by way of controlling the velocity in the wire.
So far as the original question is concerned, we are of course only interested in the time for all the electrons ahead of our chosen few to reach the battery terminal. So we don't actually need to know the velocity. All we need to know is the current (Coulombs/sec) and the total charge (Coulombs) available to be transferred ahead of the ones we are interested in.
07/11/2008 2:59 AM
The relevance is that since there is no build-up of charge anywhere, the same charge per unit time (i.e. the same number of electrons) passes through the resistor and the wire. You are right that we cannot infer from this that the number of charge carriers in the resistor remains constant as the voltage across it changes: this depends on the precise type of resistor and the range of voltages. For example in semiconductors, a rise in temperature (which could result from an increase in the current due resulting from an increase in the voltage) will increase the number of charge carriers. Note that your original question is not well defined. With chosen conditions there are a certain number of charge carriers in the resistor and they move at a certain speed. Which of them is "limited" by the resistor only makes sense if you compare two different scenarios (which you did not specify). This is why I was implicitly comparing the situation with a circuit with and without a resistor, to discuss its "limiting" effect on the current in the wire.
I hope this is a little clearer!
Elroch
07/11/2008 4:11 AM
Exactly the point I was trying to make earlier!... The implication of this is that they must travel slower in the resistor (else it is no different from the wire and doesn't 'resist')
The whole question is about the transit time ...therefore the resistor is the important thing...thus I wish everyone would stop rabbiting on about the silver wire
07/11/2008 4:49 AM
As a very off-topic observation, I grew up in Harlow, Essex myself. It's a small world.
Elroch
07/12/2008 4:22 PM
Yes, it's about time, not velocity. The only necessary assumption is that the total number of conducting electrons in the resistor is small compared with the total number in the wire. The electron velocity in the resistor may be fast or slow compared to the wire - that depends only on the relationship between the number of electrons per unit path length in the two media. If they are slow in the resistor and the total number of conducting electrons in the resistor is small, it simply follows that the path-length in the resistor is very small.
Think water flowing through a pipe under pressure, and the resistor as a constriction (or a vortex-generator) - you will easily see that total volume (charge) and flow rate (current) tell you all you need to know.
07/13/2008 7:41 AM
P.S. a water analogy for slow movement through the resistor would be if the high-resistance section of the was a wide porous filter. (That corresponds to lots of electrons in a medium with very low mobility).
However, if we take the example of a metal-film resistor, the effective cross-sectional area of the conductor would likely be substantially below 100-sq-um, so the constricted pipe is probably a better analogy - fewer-electrons per length, and also lower mobility than in the wire.
Good Answers: 15
07/16/2008 2:03 AM
And, would it depend on a chip resistor, or a wire wound, or metal film, as the distance for each component is different.
A chip resistor could be about 1mm long, and a wirewound resistor could be a meter long (unwound)
In reply to #72
07/16/2008 5:52 AM
I wrote to Del: "You'll be sorry you asked". Nevertheless, I'll do my best:
As stated elsewhere, so far as the free electrons in the silver wire is concerned, the construction of the resistor is irrelevant - it leaves their number unchanged and limits the field (and hence the average velocity).
If you are concerned with the number and/or velocity in the resistor, that of course depends on the construction of the resistor. Most resistors (thick film, thin film, carbon film...) have rather small active cross-sections, so the average velocity of the active electrons within these resistors is relatively high.
Bulk carbon and wire-wound resistors have relatively large cross-sectional areas, and the average velocity of the active electrons within them is accordingly relatively low. For both nichrome and carbon film resistors there is another factor - the density of valence electrons that are involved in the conduction is much higher than for silver (about 6x for Nichrome, and 7x for graphite). Note that this is not in these cases identical to the number of free electrons**, which in Nichrome is about half the number for silver - but the free electrons interact with the lattice and the other valence electrons, and effectively all the valence electrons are at some point involved in the conduction. That means that the cross-sectional area of these resistors can be as small as 1/6th (1/7th) that of the silver wire, and still the average velocity within the resistor will be lower than in the wire.
**At least in Nichrome, the increase in the number of free electrons with increasing temperature is at least partially responsible for the anomalous temperature-characteristics.
Good Answers: 15
In reply to #73
07/16/2008 9:16 PM
So, the electrons in the silver wire would move faster than the ones in the (say wire wound) resistor?
If this was possible, then the electron flow would either spurt or the density would decrease once the free ones fell out the end before getting refilled by the ones fallung out of the resistor?
In reply to #77
07/17/2008 1:45 AM
??? we are talking about the over all transit time of an electron..!!!
Imagine a continuous column of soldiers marching, they come to a steep hill (resistor) and have to slow down. The hill slows down the transit time...it doesn't create any problem of varying soldier density*...missing soldiers or 'spurting' !
Alternatively imagine they are marching 5 abreast and come to a gate only wide enough for one...again this will slow down the transit time...
I don't see any problems... ok they aren't perfect analogies, maybe theres a gate and a hill ...with a bit of boggy ground too, and an army of marauding cats?
* actually you would get bunching which is an inrease in density...but it's not a 'problem'
Good Answers: 15
In reply to #78
07/17/2008 1:50 AM
So, as long as they are not French Electrons, they'll not get to a hill and give up?
In reply to #78
07/17/2008 6:00 AM
Nice analogy. Especially if they were from the middle ages and no-one in authority cared which was which...
07/10/2008 9:55 AM
Elroch gave the basic answer. Here's (too much) more detail, possibly not clearly enough** expressed:
One definition of a metal is that all the electrons in the valence band* are free to move within the crystal lattice, with changes to thermally-generated movement controlled largely by externally imposed electric and magnetic fields, and limited by lossy 'collisions' with the atomic lattice. Simple theories consider an electron's speed and direction to be modified towards random thermal values by each collision, and then to accelerate under the influence of the additional fields. As the time between collisions is quite short, the electrons don't generally reach a speed that is significantly greater than the thermal*** - so the time between collisions remains fixed and the average velocity over a large number of collisions is simply proportional to the (externally imposed) accelerating forces
*For silver, that means one electron for each atom.
**Perhaps someone can find an on-line article that does a better job?
***With times between randomisation in the sub pico-second region, the medium would melt within a nano-second if the little dears were losing that much energy in each collision.
07/10/2008 10:36 AM
errr....
So does the resistor limit the speed or number then?
Or is there an third alternative which I'm missing?
If the resistor is a piece of semiconductor, presumably the resistance will be controlled by the doping level, which implies it's the number of 'free' electrons or holes. What if it's carbon film? Or a piece of wood.
I wish people would stop talking about silver wires.... I'm asking about the resistor.
I'm happy with how the electrons will bumble Merrily along the silver...
07/10/2008 4:22 PM
As you say, resistivity in a semiconductor is largely set by doping level - this affects the number of carriers (more dopant of the same type => more carriers*); so, for a fixed resistor, more field increases average velocity, rather than changing the number of free carriers.
Now follows (more of the 'too much') detail on the other questions (I could have told you you would be sorry you asked)
Carbon films (really rather time-dependent squirrels, these) also have fixed numbers of carriers; however, the resistance of carbon films is mainly a result of the poor conduction between separate crystals that are stacked. I'm not knowledgeable in this area, so although I'm pretty certain that some of the resistance is likely to be due to the electron paths being squeezed through narrow contact regions, their well-known negative TCR leads me to suspect that a significant part of the resistance is also due to small potential barriers that separate the crystallites - if so, some of the resistance will indeed be due to different numbers of carriers crossing the barrier, the numbers depending on the field.
Be all that as it may, from the viewpoint of this challenge, we only need to know the current level and how many electrons are available to carry this current - even if we recognise that the odd electron may become separated from the crowd by so-called traps (in semiconductors), by surface effects, or even by finding its way into a previously emptied (e.g. by radiation) location in the non-mobile electron "shells".
*Not that you should expect the conductivity to be exactly proportional to doping - other side-effects of heavier doping tend to increase the effective mass and/or increase the effective collision rate, and so reduce the conductivity.
07/10/2008 1:53 PM
1)2*Pi*r*B=uo*I,(I=12mA)by ampere;E=v*B,(E=12volts/10m)by Lorentz.
2)v=(2*Pi*r*R)/(uo*L),L=10m,r=silver wire radius,uo=magn.perm.;by 1)
3)R=R1*L/Pi*r**2,by Ohm,so R=1000ohms by hypothesis,so you get "r".
4)t=L/v
07/10/2008 4:32 PM
Most of the 12-Volts is across the resistor, which is not the silver wire.
Even if it were the silver wire, the velocity is limited by factors other than B and μ.
What you need (to get started) is Ohm's law (for the current), plus
the Mole density of Silver, and Avogadro's number for the number of silver atoms, together with knowledge that (almost exactly) the single Valence electron is all that is involved in the conduction (for the number of electrons to be shifted before the relevant ones reach the terminal).
07/10/2008 7:51 PM
If those equation are wright and the hypo.too,the results must be wright too.I assume the resistor is the silver wire or may be have not solution for this problem.
Possibly i am wrong,but, i think you must point the wrong equation, hypothesis, calculation or etc.
07/10/2008 11:35 PM
I think most people are assuming that the silver wires are of a reasonable size and that the 1K resistance is an actual resistor of value 1k.
If you take the assumption that the 10 metres of silver wire provides the 1000 ohms, then the silver wire would need to be very, very, very, thin.
Resistivity of Silver is 1.59 X 10-8 Ω.m = (Resistance*Area)/length = 1000.A/10
Thus the cross-sectional Area of the silver wire would need to be:-
(1.59 X 10-8 X 10) / 1000 = 1.59 X 10-10 m2
This corresponds to a wire diameter of 7.1 microns
I cannot imagine this carrying a current of 12mA without melting like a fuse.
Australia - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member
Good Answers: 16
07/11/2008 12:11 AM
Imagine the fun of trying to solder the connections. You would want a very steady hand.
BAB
Make it so.
07/11/2008 11:05 AM
Even if i use d=1mm,(r=0.5mm) in v=2*R1/uo*r ,R1=silver resistivity ,i get a speed ten times the Bobd's value.Why's that?
Never thought before that speed could be so slow,now, how to explain the fast charge of a capacitor "R*C" ?
07/11/2008 12:07 PM
When you "push" electrons in one end of a wire, different electrons immediately come out of the other end, so the time it takes the electrons to travel along the wire does not have any influence on how long it takes a capacitor to charge. The analogy of a pipe leading from a reservoir to a tap is a good one. Water starts to fill the sink immediately you turn the tap on, even though it takes a very long time to travel along the pipe from one end to the other.
Elroch
07/12/2008 4:07 PM
Although I would agree that unsupported 7-um diameter silver wire would be very tricky to handle, I doubt it would get excessively hot.
If we assume the wire is uncoated and is lying an average of 10-cm above the ground in perfectly still air, (probably very worst case for such flimsy wire?), air conduction between the wire and the ground would give a thermal resistance in the order** of ln(0.1/(∏.r))/10/Κair, or 35OC/W. With 144-mW dissipation, we would only be looking at a 5OC temperature rise.
**The calculation is based on twice the thermal resistance between complete concentric cylinders
07/13/2008 11:03 PM
Wow, that is interesting.
Just shows you how intuition can let you down.
In reply to #70
07/14/2008 4:49 AM
Agreed - I probably wouldn't have thought about it, other than remembering the massive difference in spacing when moving from 75-Ohm to 300-Ohm two-wire transmission lines (for FM antenna connection)
07/12/2008 3:41 PM
Please show how your equations can lead to a meaningful result - including presenting it. {I may be blind, but I can't see anything usable in your equations}.
So far as I am concerned, Fyz and jim35848 already answered the question if the resistor is the (uniform thickness) silver wire (i.e. about 20.7 minutes at 20OC).
07/11/2008 6:33 AM
Instantly...
While we have Vsupply greater than total voltage drop We will have enough electrical field that force electrons to move.
Think of thermocouple applications. Even PtRh-Pt wires that has larger specific resistance than silver can send data instantly to receiver under a few millivolts potential (instead of 12V)!
I think so as Guest commented (#6).
07/12/2008 5:39 PM
By my knowledge the mobility factor is regarding semi-condustors and gases.
In our case medium is well conductive solid-metal-.
According to quantum mechanics if wavelength of an electron is greater than ion's radius it can move without collide any other ion.
Any charge will expands over the whole conductor acc. to:
ρ = ρ0e(-σ/ε)t => For silver the time will be ε0/σ = 8,054.10-12 seconds. (σ:conductivity, ε:dielectric constant = ε0)
mean instantly... wrong?
In reply to #60
07/12/2008 6:51 PM
This invites really confusing the issue by going off a sharp tangent.
I think we agree the question is basically about the average speed of the free electrons (in a particular direction), which is simply calculated from the number of free electrons, the current in the wire and the charge on the electron. Feridun, are you talking about some sort of diffusion (which is non-directional)?
Anyhow here is my wild tangent. A fascinating fact is that when Dirac created a relativistic theory of quantum mechanics the natural way of defining the velocity of the electron only permitted values that had magnitude the same as the speed of light (for those who know about such things, these are the eigenstates). His interpretation was that the direction of movement of the electron kept changing (loosely like brownian motion), and the time averaged velocity of the electron had a magnitude less than the speed of light. This average verlocity was found to correspond exactly to the classical velocity of the electron.
As Michael Caine used to like to say, 'not many people know that'.
Elroch
07/12/2008 8:05 PM
okay,
Taking into account the resistor don't change my way. The resistor is neither a semiconductor nor gas. The parameter that will change is conductivity only!.
With the resistor the time will be 12,57.10-4 seconds.
Still instantly...
In reply to #63
07/13/2008 7:11 AM
I'm not certain how you are interpreting the question. I think the intention of the challenge is to imagine that we could tag an individual electron that started at the negative terminal and calculate how long it takes to reach the positive terminal. I also think that you are working on the basis that tagging is not possible, and that you have an electron cloud with no electron having any identity:
if we take that view the identity progresses from the switch to the positive terminal at the speed of light in the conductor - on the other hand, only a fraction of the electron that represents the proportion of the total conducting charge on that terminal will actually be at that terminal - which raises the question as to whether it was ever truly at the negative terminal - and equally whether it ever really reaches the positive terminal.
I think the best (still highly artificial) "way out" is to take the view that the silver wire is not a continuous silver crystal, so there are multiple electron clouds and the electrons transfer from one cloud to the next - still only probabilistic fractions, but we can assign a very high probability of individual transfer between crystallites at times that are short compared to the total transit time.
In reply to #64
07/13/2008 9:35 AM
Dear Guest,
I'm aware what you mean, thank you.
According to classical conductivity theory it is even impossible one electron can reach to the positive terminal. Namely we wait forever.
On the other hand the quantum mechanics talks about one electron can move along the lattice without hurdled using wave properties of electron. If this is possible this electron can fly over the following lattice since the electrical field is continuous along the wire, why not?
(By the way, i would not like to dig into schrödinger equations mere to prove this idea.)
thanks again
In reply to #64
07/13/2008 9:52 AM
Regardless of such considerations, doesn't the average speed of the electrons still have to be the answer derived from the known current, the number of free electrons per meter of wire, and the electron charge?
One question is whether electrons on the outside of the wire move at the same speed as those within the conductor. If the current was alternating, there would certainly be a difference, but I don't see why there should be much difference with direct current. In any case, I believe the diffusion of electrons would thoroughly mix those on the surface with those within the conductor over significant periods of time.
Elroch
07/13/2008 9:04 AM
Voltage / current is transmitted near instantaneously, but electron migration much slower. I've never seen a calculation of the time for migration. . . "who cares"?
Wait a minute, one could easily calculate electrons per second equivalent of a certain number of amps. . . but that doesn't give us the answer. I guess we would have to know the number of outer shell electrons in the wire? ? A very heavy wire would have the same amps, but much slower migration?
Peter E. McAlpine
In reply to #67
07/16/2008 10:12 AM
"I guess we would have to know the number of outer shell electrons in the wire?"
Silver has a valency of one; in metallic silver these form the conductive electron cloud.
07/16/2008 8:01 AM
Please! So you just assume .1 cm/sec? How about calculating it from amperes? This is no answer at all!
Peter E. McAlpine
In reply to #74
07/16/2008 10:08 AM
Agreed - totally arbitrary apparent guesswork - no better than the first three answers (whose authors presented them as first-cut finger-in-air exercises)
IMHO any of the four "Good Answers" did a much better job - assuming you accept the validity of the question.
Reply to Blog Entry 80 comments
Anonymous Poster (11); BlueAussieBoy (1); BobD (4); chhotu1990 (1); cnpower (1); Elroch (9); feridun (4); ferquiza (3); jim35848 (1); JohnDG (3); LP Ultima (1); Maths_Physics_Maniac (5); pemca (2); Physicist? (18); rajant_2001 (1); Snaketails (4); StandardsGuy (1); stevem (1); tkot (2); user-deleted-1105 (6); wangito (1)
You might be interested in: Battery Holders, Terminal Blocks
