Previous in Blog: Ancient Astronomical Calculator Had Olympic Run   Next in Blog: Volcanoes To Be Harnessed For Power
'iShoe' uses NASA tech to help prevent elderly falls
Posted July 31, 2008 10:59 AM
From USATODAY.com Tech - Top Stories:
Scientists working to help astronauts regain balance after extended flights in zero gravity say they've found a way to use the research to help elderly people avoid catastrophic falls. An "iShoe" insole contains sensors that read how well a person is balancing. The point is to gather information for doctors and to get people to a specialist — before they fall. Erez Lieberman, a graduate student who developed the technology while working as an intern at NASA, says a damaging fall is preceded by numerous warnings, similar to how high cholesterol and elevated blood pressure point to a coming heart attack. "You gradually get worse and worse at balancing," said Lieberman, who studies in a joint Harvard-Massachusetts Institute of Technology health science and technology program. "If you know the problem is there, you can start addressing the problem." The National Osteoporosis Foundation estimates 300,000 people annually suffer hip fractures, which are often caused by falls. An average of 24% of hip fracture patients age 50 and over die within a year of the fracture. Many fall victims who don't die within a year end up being disabled the rest of their lives. "It's a huge issue," said Elinor Ginzler of the AARP. "It significantly impairs your ability to stay independent, which is what people want." The idea for the iShoe came to Lieberman while he was working at NASA last summer on a project to help astronauts regain balance after months in zero gravity. The work is part of preparations for long space missions, such as trips to Mars, that require astronauts to perform complicated tasks on the terrain soon after landing. The balance research seemed to Lieberman to have obvious earthly applications for the elderly.
Good Answers: 230
Re: 'iShoe' uses NASA tech to help prevent elderly falls
07/31/2008 9:33 PM
That research looks promising to save thousands of broken hips in the elderly.
Kind Regards....
