Previous in Blog: Sarnoff researchers tout GPS fail-safe system   Next in Blog: Missile-Proofing Runways
Equipment & Gear: Knife and Sharpening Steel Hardness
Posted December 06, 2006 7:50 AM
From Cooking For Engineers:
Quick Analysis of Knife and Sharpening Steel Hardness Surface hardness of through hardened steel products is a quick test used for quality assurance to determine if the proper heat treatment properties have been attained. Surface hardness can also be used as a component of a reverse engineering process to determine relative quality compared to a known product and to determine steel grade and heat treatment. In this case we have tested eight knives by five manufacturers in carbon steel and stainless steel and four sharpening steels to compare the relative hardness and provide insight into the performance of the knives.
Re: Equipment & Gear: Knife and Sharpening Steel Hardness
12/06/2006 11:58 AM
This is an interesting article for a couple of reasons. First off the steels are not the same so the results of the hardness tests are likewise different. Carbon steels, stainless steels and forged steels all have different properties and different grain structures and as a result, different capabilities.
In addition, the types of knives tested are themselves different. The cleaver would be softer as it is intended to crack bones and separate sections of an animal carcass. Chef knives are mostly intended to slice or chop vegetables quickly into sizes for cooking. Carbon steel knives are softer to allow rapid re-sharpening with a steel. Stainless steel is used in knives mostly for cosmetics as they do not corrode and become dark like carbon steel, but are noted for being difficult to re-sharpen and they do not take as keen an edge as carbon steel.
Many of the differences in the study can be explained either by the nature of the material used or by the use of the tool in question. Thanks for an interesting article.
It is better to light a lamp than curse the darkness
You might be interested in: Hardness Testers, Knife Blades, Stainless Steel Alloys
