Hemmings Motor News Blog Blog
Previous in Blog: These AMC Pacers Aren't Just Ugly - They're Electric   Next in Blog: Restoring a 1932 Ford Speedster
22 comments
Repairing a 1970 Land Rover
Posted November 12, 2008 6:00 AM by dstrohl
So I've been having this issue with my 1970 Land Rover Series IIa. It only runs with the choke wide open. McGean thought it might be a vacuum leak, but I sprayed all kinds of carb cleaner around the base of the carburetor and every vacuum port to no avail. Alert reader Dave Murrell sent me what he thinks is the issue. He's right. I've got the Weber carb. We'll give it a shot this weekend and see how it turns out!
Read the Whole Article
Good Answers: 97
Re: Repairing a 1970 Land Rover
11/13/2008 2:21 AM
It's supposed to run with the choke wide open. A fully or partially closed choke is used to aid when starting and then to remain fully open when engine reaches operating temperature.
Cheer up
11/13/2008 4:37 AM
Plug main jet in the Carb,Low fuel level (foat setting) or a odd one Low spark voltage.
11/13/2008 4:39 AM
PS Nice ride.
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
11/13/2008 7:37 AM
What's carb cleaner gonna do for a vacuum leak?
Prophet Freddy has the answer!
11/13/2008 8:08 AM
If there is a leak Carb cleaner adds "fuel" & the engine typically speeds up. An old trick but worth knowing
Good Answers: 27
11/13/2008 8:44 AM
Makes sense. Good to know. Thanks.
United Kingdom - Member - Not a new member!
Good Answers: 68
11/13/2008 8:04 PM
Hello Biomass Nut:
I would like to say thank you for the insite on 'carb-cleaner'.
Take care...........
Take it easy, bb. >"HEAR & you FORGET<>SEE & you REMEMBER<>DO & you UNDERSTAND"<=$=|O|=$=>"Common Sense is Genius dressed in its Working Clothes"<>[Ralph Waldo Emerson]
Good Answers: 68
11/13/2008 7:29 PM
I was trying to figure that out myself!
I do not know if this Land Rover uses a rubber diaphragm in the carb'?
I had a car with a tiny hole in the 'vacuum' operated rubber diaphragm. It would cut out usually at Early morning or night when I could hardly see what I was doing. I took the diaphragm out and, stretched it, as it does get stretched in use, then held it up to the torch. A hole there, which had not been obvious, but enough to stop the engine work at more than walking pace!
Now, if I had some of that magic vacuum sprat mention, it would have mended itself, silly me eh?..............No insult intended, OK?
Good luck
Good Answers: 68
11/13/2008 7:52 PM
Hello dstrohl:
This is only if you have a Zenith Carberetter OK? It works!
Even if you go and get a new Zenith, these inbuilt problems where the top and bottom faces are not dead flat will like let the vacuum degrade. It takes very little time. Actually more time to remove than to Lap each half flay! Just be sure to rinse to remove any grit, or you will be needing more than a new carberetter
The Infamous Zenith Fix - and a Valuable Metalworking Technique Original Author: Alan Richer (OVLR)
As we all know, the poor heat treatment and insecure design of Zenith carburetors often causes the body halves to warp and twist - leading to air leaks, poor mileage and even worse running characteristics.
The classic symptom of the warped-body problem is an inability to adjust a rich idle mixture using the mixture adjust screw on the side of the carburetor base. If the engine won't stall with the screw wound all the way in, likely it's siphoning fuel past a bad gasket and seal between the halves.
The cure for this problem is simple and is called lapping - and the technique is in itself a very useful metalworking skill to acquire. In short, we need to restore the mating surfaces to a high level of flatness to eliminate the air leaks that the warping causes. We'll do this by hand grinding down the surfaces with abrasive on a known-flat base. This is an old machinist's trick for creating finely-finished gas-tight seals with a minimum of finicky measuring and tool work.
The supplies we will need are simple, and consist of:
  • A small sheet of plate glass (1/4" is better, but windowpane will do). At a minimum the piece should be the size of a sheet of paper, though larger is good as well. No specific dimensions here - anything you can persuade away from the gentlemen at the local glass shop will do.
  • Sheets of emery cloth - one of 120 grit or so, one of 220 or slightly finer. These are the cutting medium that we'll use to hand-grind the carburetor parts flat.
  • Oil - just about any light oil (not motor oil) will do here. We'll be using it to hold the sheets of emery to the glass and as a lubricant during the grinding process.
Process:
The technique here is simple. What we'll be doing is a backwards grinding process - we're going to be moving the part to be ground over a stationary abrasive on a known-flat surface. This way, the abrasive will remove any bumps or protrusions on the surface we want to flatten - leaving it smooth and as flat as the reference surface (the plate glass).
First off, disassemble the carburetor completely. When you're done, you should have just the carburetor casting halves in hand - each piece with all the jets, linkages, venturi parts and the rest removed.
Next, let's prepare the grinding workspace. Cover your work surface with paper (to keep the mess minimized) and place on that the sheet of glass. Wet the surface of the glass with the oil and smear it to a thin covering - this will hold the emery paper down and keep it from sliding around. Lay the coarse emery down on the glass, pressing it down to make sure it has even contact with the glass.
Now we're ready to start lapping - but first a word or two on what to look for. If you look at the gasket sealing surface on the carburetor top you'll see it's a uniform grayish color. This is going to change as we grind it flat - the surfaces will become bright and show a uniform pattern of scratches from the action of the emery. This is what we want - when the bright pattern and color covers the whole sealing surface then the part is as flat as the plate glass.
The process from here on is nothing more than simple hand work with a bit of attention to detail. Wet the surface of the emery with some of the oil - not a lot, but enough to give some slide to the part and float away the grinding debris. Place the part to be ground face-down on the emery sheet and move it about in a figure-8 pattern with even pressure for a half-dozen strokes - then pick it up and wipe the bottom face to remove the dust and oil from the sealing surface.
You'll notice that the bright areas are not covering the whole surface and are likely concentrated around the screw holes. This is what we're trying to correct and we're well on the way to doing so.
Continue the movement, making the figure-8 movement for a dozen or two strokes,wiping and inspecting. When the bright pattern completely covers the mating surfaces then this piece has been straightened and should be put aside for the next stage. Do both halves of the carburetor this way, then remove the coarse emery and clean the glass.
We have good flat surfaces now - but they still have the scratch patterns from the coarse paper. We can remove the scratch pattern with the fine paper, using the same technique as before.
Clean the parts of emery dust and oil thoroughly (I usually use carb cleaner in a spray can for this). Now, adhere the fine sheet of emery to the glass with oil. Using the same figure-8 motion and even pressure lap the carburetor halves on the fine emery, but just until the scratch pattern from the coarse paper is removed.
When the parts are evenly lapped, clean the carburetor parts thoroughly and reassemble the carburetor with new seals and gaskets. If assembled correctly and the lapping process was successful, you should now be able to adjust the mixture from rich to stalling using the mixture control screw on the side of the carburetor base.
The technique above (flattening metal objects by lapping) is a very handy technique that isn't simply applicable to carburetor parts. I've personally used this to flatten warped carburetor bodies as above, but also to remove wear from Range Rover oil-pump covers and straighten warped Land-Rover steering box covers.
It's a classic low-tech technique in model engineering for flattening up baseplates and other items that require a good surface for precise parts alignment.
In each case the technique was the same - even pressure and moving the object on an abrasive medium on a known flat reference surface. Plate glass is ideal for this type of work, as the process of its manufacture (floating on molten metal) leaves it with a very flat surface - ideal for our purposes.
To conclude, this is a good, inexpensive method for salvaging an otherwise unusable carburetor The materials are easily available, and doing so teaches a valuable skill that can be used on many items both on and off the car. Good luck...............
Good Answers: 97
11/13/2008 7:59 PM
Put a dab of silicone caulk over hole in diaphragm let set for 8 hours then put back into service
Good Answers: 68
11/13/2008 8:07 PM
Hello wire,
Are you OK? That sounds like a good short term idea. A 'get you home idea'?
Good Answers: 97
11/14/2008 9:25 PM
Yes on more than one occasion
Good Answers: 68
11/15/2008 9:30 AM
Hello wire,
did you see I sent in a long piece on how to 'Lap' a Zenith? On reading again I see he has changed it to a Webber! How stupid do I feel, on a scale 0-10....umm, 10!
Teach me to fully read the original thread right?
Take care..........
Good Answers: 97
11/15/2008 11:19 PM
Write 100 times
Good Answers: 68
11/16/2008 3:49 PM
Hello wire,
I have done already!!
I seem to get it pretty right, but, on accasion I screw up, I make a bloody good job of it!
I am just catching up after longer than usual off-line. I do not know if that thread writer has written a post to say how he is getting on............
Take care............
Good Answers: 97
11/16/2008 11:36 PM
Actually the post was information of how to fix and he already had an answer I think.
Good Answers: 68
11/17/2008 1:32 PM
Hello wire,
I sometimes have problems concentrating, and it is one of those times now. I thought the previous posts were about zenith carburettors. But, anyway, he has a Webber, and it is not relevant.
Take care my friend..........
PS. I was going to start my post "Hi wire", but thought if you had trouble concentrating up there you may fall off!...........Look I never said all my 'jokes' will be good. Actually, I never said all my jokes will be good either
Good Answers: 68
11/13/2008 7:55 PM
Hello dstrohl:
This is a very helpful Land Rover user site.
http://www.lrfaq.org/Series/Engine.html
http://www.lrfaq.org/Series/FAQ.S.carb.zenith.fix.html
11/15/2008 3:18 AM
Do you mean that the choke is active (on) or inactive (off)......? Wide open suggests the normal running condition, not the starting condition which is closed!!
Good Answers: 68
11/15/2008 9:26 AM
Hello dstrohl:
I want to apologise for sending that long piece on Zenith Carbs, when after a reread I see you have changed to a Webber.
I had a Webber on a Mini and I found it brilliant when it was adjust correctly. But doing that I found far from easy! But, once set, it stay that way!
let us know how you get on with working on it with your friend please?
Sorry again..........
11/20/2008 11:14 AM
The hole in the diaphragm is a possibility, but the leaky interfaces would have been found with the carb cleaner trick. One thing that hasn't been mentioned, and might not be relevant since I'm not familiar with Land Rovers, is the possibility of jumped timing if this engine or any engine has a timing chain or belt (newer vehicles). If the engine in question has a chain, it may have stretched and jumped a tooth. To check for this possibility without ripping the engine apart, grab the fan belt and check for rotational play in the crankshaft. 2 to 4 degrees is normal, much more than 4 is cause to plan on getting out the wrenches. Even if an engine hasn't yet jumped timing, with that amount of stretch, it's a problem waiting to happen at the worst possible time. Belts are a little tricky to check without checking timing itself. When a belt jumps, it's usually due to worn teeth and may be resiliant enough to not show loosness when checking externally.
If an engine has a gear driven camshaft, disregard the above.
Nothing exceeds like excess.
04/07/2010 11:38 AM
hello there.
is your Series II okay now?
Andy Germany (1); babybear (9); Biomass Nut (1); bwire (5); Duckinthepond (2); G.M. (1); Jaguar (1); ski (2)
