Previous in Blog: Have You Tried Flexible Honing?   Next in Blog: What is Plateau Honing?
2 comments
Slippery But Simple: How to Select Honing Lubricants
Posted March 16, 2009 8:00 AM by BrushResearch
What kind of lubricant should you use for flexible honing? The best answer is a simple one: a high-quality honing oil. Many honing companies have their own oils and lubricants, and many work very well with the Flex-Hone® tool.
When it comes to lubrication, just follow these simple rules.
  1. Water soluble oils, mineral oils, motor oils, and cutting and tapping fluids are all acceptable.
  2. Use of a lubricant keeps the tool from loading and insures exposure of fresh cutting particles.
  3. When working with finer surface tolerances, use better-quality honing fluids.
  4. Always make sure the hone is well-lubricated.
Read the Whole Article
Re: Slippery But Simple: How to Select Honing Lubricants
03/17/2009 8:12 AM
Ford automatic transmission fluid
Popular Science - Cosmology - New Member
Good Answers: 16
03/17/2009 11:20 AM
To my experience, motor and mineral oils will just load up your abrasive. Tranny fluid seems like a good, cheap alternative. Marvel Mystry oil, or a few drops of methyl salisalate (oil of wintergreen) added works well.
De gustibus non est dispudandum.
