Previous in Blog: GeoBulb LED light bulb uses just eight watts, rings up at $120   Next in Blog: Why Can't We Visualize More Than Three Dimensions?
6 comments
Wind-powered vehicle hits 126MPH, nabs world record
Posted March 30, 2009 11:30 AM
From Engadget:
Sorry Mr. Schumacher, but your ten year record just got obliterated (okay, "beat soundly") by a Briton. On the dry, dusty plains of Ivanpah Lake in Nevada, Sir Richard Jenkins managed to perfectly harness winds of 30MPH in his futuristic Ecotricity Greenbird in order to hit a ridiculously quick 126.1MPH. In all honestly, we can't even fathom how you hit that speed with just 30MPH of wind, but clearly we're not up to speed when it comes to physics and engineering. At any rate, the milestone is pretty important for Ecotricity, which is trying to make wind power the go-to alternative energy source within the next score. Now, if only we could figure out a cheap and easy way to generate wind on demand, we'd really be onto something.
Re: Wind-powered vehicle hits 126MPH, nabs world record
03/31/2009 2:47 AM
Excellent...
Presumably that has to be a crosswind ?
03/31/2009 8:36 AM
That's plain amazing. Videos and pics on their website:
http://www.greenbird.co.uk/
Similar to hydrofoil sailboats which can see speeds around 60MPH.
http://hydrofoilsailing.com/
United States - US - Statue of Liberty - Technical Fields - Education -
03/31/2009 10:39 AM
If you go to the article itself and check out the blog entries, someone did explain how it is possible:
http://www.engadget.com/2009/03/27/wind-powered-vehicle-hits-126mph-nabs-world-record/ Check out Tim's posting -- the fourth one.
The solution is tacking the vehicle. lets say the wind blows due north at 30 mph, and we know this car is going 126 mph. In an ideal world, this means that the final vector must be 126 mph (obviously) at a heading of 76.2 degrees ENE. Where does the 76.2 come from? The cosine of the record setting angle must equal the ratio of the wind divided by his speed. Hence; cos-1(30/126)=76.2. Considering losses due to friction, his tack must have been greater than 76.2 degrees off of the winds direction. More than likely, his approach started directly aligned with the wind. As he approached the winds 30 mph, he would have slowly turned his vehicle while keeping the sail perpendicular to the wind. Assuming a steady wind and gradual steering, his speed would have peaked at 126 mph. He would then make slight adjustments until he was at his percieved maximum velocity. (this heading, as stated above, would be >76.2 degrees, and less than 90 degrees for obvious reasons.)
It makes sense to me because I know nothing much about this sort of thing.
"Reality is merely an illusion, albeit a very persistent one." -- Albert Einstein
Good Answers: 247
04/01/2009 1:34 AM
Tim was not too far off, although all the details were wrong. The best heading is actually slightly more than 90 degrees to the true wind. Also tacking (changing direction of the craft) is not necessary. Instead, constant trimming to the sail (wing in this case) is required. And the boat would not start "directly aligned with the wind" unless by that Tim meant perpendicular to the wind.
Any very fast sailing craft (that can sail at multiples of wind speed) will sail fastest on a beam reach (or very close to one) meaning that the true wind is from the side.
The process goes like this:
1. You start with the wing's chord in line with the wind (0 degrees angle of attack). The craft is aligned perpendicular to the wind. As you increase the wing's angle of attack (by sheeting in, sailors say) the wing will start to develop some lift. (If you are on ice the small amount of lift might not be enough to overcome friction of the blades, so you may need a little push.) This lift is directed forward, perpendicular to the wind. In a 30 mph wind the craft should begin to move easily.
2. As the craft moves, the apparent wind (from the vector addition of the true wind and the motion of the boat) appears to move forward. You sheet in more to maintain a fairly constant angle of attack of the wing with the wind. (In this particular craft, the setting of angle of attack is somewhat automatic, by virtue of the tail foil.)
3. The craft continues to accelerate, moving the apparent wind further forward, and you continue to sheet in to maintain an angle of attack.
4. The lift on the wing (which is directed not up -- as in an airplane -- but partly forward and partly to the side) is increasing with the square of the apparent wind speed. So, if you are now going 100 mph (and the true wind is 30 mph) the apparent wind is 104 mph from about 17 degrees off the bow. The lift has gone from (for example) 100 lb with the boat standing still (in 30 mph wind) to 1202 lb. An impressive amount of force. Unfortunately, lift is always perpendicular to the apparent wind, meaning that the lift vector is not mainly ahead, as you'd like, but mainly to the side. Only 359 lb is pushing the boat forward, and 1150 pounds is pushing to the side. Depending on tires, surface, etc. the craft could be starting to drift to leeward, provided it has the right leverages to avoid capsizing.
5. An unfortunate consequence of the high apparent windspeed is that drag has increased just as quickly as lift. Also, because the apparent wind has moved forward, the drag vector (which always aligns with the apparent wind) is well positioned to help keep the boat from going fast. In an idealized world, the ratio of yacht speed to windspeed is then set by the ratio of lift to drag. With tires being pushed sideways, rolling friction, fuselage drag, etc. this is not an ideal world, but in the most efficient iceboats a ratio of 8:1 is possible, in true winds of about 10 mph. This team, back in its Windjet days, was claiming about that ratio.
It is interesting to note that the absolute greatest thrust (lift aligned with craft's motion) available at a standstill was 100 lbs in this example. After the boat has accelerated to 100 mph, 359 lb is available. This starts to sound like a perpetual motion machine, doesn't it?
A surprising peculiarity of a very fast boat (even fast water boats like my Windrocket, which could do about 3 times wind speed -- if everything worked perfectly... which it never did) is that you never jibe to change tacks going generally downwind. (In jibing, the wind comes around from one side of the boat to the other, from behind. In tacking, it comes around from the front.) In very fast sailing craft, the wind is always from in front of the boat even when zig zagging down wind... unless the tack is poorly done and the boat slows. A fast boat cannot be sailed fast straight downwind so is typically sailed about 45 degrees to either side of straight downwind. The distance travelled is about 1.414 times as far as straight downwind, but the speed is 3 times as fast as the wind.
Sailplanes have 60:1 L:D ratios so a slightly better that 4:1 speed ratio seems like it could be improved. However, there is a balancing act between wing length (promoting high L:D) and capsizing moment, which increases with wing length. Loads of compromising and optimizing has to be done, and it is really nice to see that it has worked out for this team.
Reply Good Answer (Score 4)
Good Answers: 247
03/31/2009 4:52 PM
WOOOO HOOOO! Good for these guys!
Good Answers: 93
03/31/2009 11:59 PM
Last I knew the modern age was fully dependent on sailing technology, windpower, starting in the 15th century.
Still it goes on.
Very cool.
Getting there with the cargo, or yourself is the goal, and I'm sure many a sailor wished they could have outrun the storm.
Blink (2); bp01 (1); Pretendgineer (1); Transcendian (1); user-deleted-1105 (1)
