Previous in Blog: White Roofs Catch on as Energy Cost Cutters   Next in Blog: Dangerous: Crazy Russian Mach 2 Ejection
22 comments
The Citadel: The World's First Floating Apartment Complex
Posted July 30, 2009 12:25 PM
From Gizmodo:
Since Holland is mostly under sea level, keeping houses from flooding is a constant problem. This concept fixes that problem by just having an apartment complex that floats. The Citadel is the residential part of the "New Water" complex, which tries to embrace Holland's waterworld-ness instead of fighting it. It'll have a floating road to the mainland as well as plenty of boat docks for its 60 units. Apparently it'll also be 25% more energy-efficient than an equivalent complex on land by using the surrounding water for cooling. It looks kind of crazy, but the sort of crazy that could actually work.
Re: The Citadel: The World's First Floating Apartment Complex
07/30/2009 1:07 PM
we are just adapting to global warming. we need to invest into more of this and put them on the ocean.
the world is what you take from it, so take it all!
07/30/2009 2:32 PM
The real big money will be converting all the existing expensive seaside resorts to float once the seas start to rise around them!
07/31/2009 6:05 AM
Big problem with global warming and floating houses -they floats away!
Holland needs to worry about being below sea level too, so this sort of thing is handy for land based dwellings :-)
07/30/2009 3:16 PM
No Sleepwalking allowed...............splash!
07/31/2009 1:24 PM
What's the surest way to waken a sleeper? Pour water on him/her. With a house like this, you can pour him/her in the water, instead! What a novel idea!
07/31/2009 12:05 AM
"but the sort of crazy that could actually work"
Holland perhaps, New Orleans not so much.
Charlie don't surf.
07/31/2009 3:59 AM
Wonder if anyone's looked at tidal power generation for this?
A vertical rack fixed to the sea-bed could engage with a pinion on the appt. complex, geared up to turn an alternator as the tide rises & falls
Thoughts, anyone?
07/31/2009 8:57 AM
Wouldn't any resistance to the tide pushing the house up result in it flooding ? I guess it depend upon how buoyant the things are. Maybe they could have great big polystyrene basements.
The housing is to be built in polards, so maybe they could just stick a turbine in whatever sluice they use to control water level. Trouble with that is the tidal range probably isn't very much.
That all sounds a bit flippant, but it wasn't - honest ! The idea of getting energy from floating houses is cool, I'm sure that some quick calculations could be done with mass/height......
This link is a bit better than in the OP.
07/31/2009 9:31 AM
If there's little or no tidal range, my cunning plan is dead (in or out of the water ).
Could work in other places (with a decent tidal range), tho', maybe. As for flooding it by the resistance of the generator gear, I imagine this thing must have a displacement something like a battleship - and they take a bit of sinking!
07/31/2009 10:18 AM
Maybe it's not too late to suggest alternatives for the Severn Barrier
Some of the pictures of the housing look a bit like wooden huts on top of Mulberry harbours. Either way, them polders won't see much uppy-downy movement.
OK, the Belfast is still moored down on the Thames. Tide tables are probably easy to find.....go on, I dares you do work out the potential energy . I'd do it, but I'm off clubbin'
07/31/2009 10:31 AM
Maybe I'll do sum somes over the weekend.
Thought for a bit you were off clubbin'
07/31/2009 11:15 AM
....I could be tempted by a G&T on the veranda right now
08/02/2009 7:22 AM
HMS Belfast: 11,553 Tons = 11,737,848 kg
Tidal range at London Bridge ≈ 5 m
PE = M * g * h = 575,154,552 J ≈ 160 kWh
Two tides per day, and what goes down must have gone up, so that's 640 kWh.
No idea how efficiently it could be converted, but it's a fairly tidy sum for starters - not as much as I'd expected, tho' .
Anyone see any mistakes?
08/02/2009 8:50 AM
The calculations look good to me, though I still can't get my head around how you could extract the same energy going up as down.
If we used 3KWh per person, it looks like HMS Belfast could make for a nice little eco-village. Level it above the main deck, put up some yuppies style apartments....just for argument sake use 320 KWh/day......efficiency of recovery quite high, say 80% → 250 KWh/day......consumption of 3KWh/day for greeny peoples......about 80 yuppies on an area of about 180m x 20m...Yeah, I reckon it works. Shame to lose the Belfast, so.......
....lets solve the MP's housing issue here ! Nice hulk moored off Westminster, fully fitted apartments owned by Parliament and made available to our glorious representatives. Bye bye endless cheques for non-mortgages/toasters/duck houses.
08/02/2009 6:43 PM
" ... I still can't get my head around how you could extract the same energy going up as down ... "
Displacement, innit? Archimedes annat. The moon's doing the hard bit.
08/03/2009 3:30 AM
Yeah, but if you hook up a great big ratchet to harvest the upward movements energy, it's like adding more weight to the boat. The ratchet/generator will offer resistance to movement. If you experiment by putting weights on the float in your toilet cistern it will overflow because the float wont float (!). You can reap almost all the PE as the boat drops down, but not on the way up.
Now I'm very confused, and I'm going to cry . OK, you can harvest the buoyancy force on the way up, and the weight of the boat on the way down. The two are different, yes ? Please tell me 'yes', else I'll scweam and scweam !
SCWEAM !! Is HMS Belfast a boat or a ship ? You can usually tell by the windows, but I can't remember what it looks like.
08/03/2009 4:11 AM
"The two are different, yes ?"
Yes. Different, but the same .
Here she is:
Boat or ship? I dunno. Can't see the windows very well.
08/03/2009 4:18 AM
I was being silly - RN call submarines 'boats'
Went on board her once, but it was a very long time ago.
08/03/2009 4:21 AM
Ah, the windows ... (doh!).
Good Answers: 101
07/31/2009 6:13 PM
Well now... Thats not a half bad idea to implement into this sort of thing.
07/31/2009 11:27 AM
Great idea, but for me, I live a few miles inland in a low elevation area of south Mississippi. When the water rises, my property will become waterfront property and worth more money.
Mr.Ron from South Ms.
07/31/2009 6:13 PM
That's OK for a while - longer if you're on the side of a hill - but don't get too settled!
Anonymous Poster (1); CUTiger (1); Ice-Man (1); JohnDG (8); Kris (6); micahd02 (1); ronseto (1); RVZ717 (1); stevem (1); whatthef (1)
You might be interested in: Piers and Docks, Liquid Level Floats, Buoys and Floats
