Previous in Forum: How To Building Animation?   Next in Forum: Calculate the probability
15 comments
Hot to the Touch - Really? How Hot?
03/20/2015 9:49 AM
Anyone know a rough rule of thumb for how hot the interior of a 10 Ga metal cabinet might be if it the exterior is warm, but not uncomfortably so to the touch? Google didn't help me here.
I have a circuit in a box that will get to 30° F above ambient. So my ambient can be as high as 110° F and stiil be safe for the rating of my circuit devices. It is going inside another enclosure used for heating water that the enclosure owners tell me, on occasions, as this is not a continual process, gets warm to the touch. (no - they are not going to measure this temperature for me) I will eventually be able to measure this temperature, but want to prepare for the worst now (buy a cooling fan for the larger enclosure) if necessary, before my enclosure is installed.
Good Answers: 76
Re: Hot to the Touch - Really? How Hot?
03/20/2015 10:29 AM
The sensation of 'pain' usually begins around 110-degreees F. For me, any design that has the potential to have a surface reach 100-degrees F or higher will include some type of cooling, guarding, or warning.
Here is an older, but decent, paper on the subject:
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20100020960.pdf
03/20/2015 10:39 AM
Thank you - NASA says pain threshold is reached around 110°F, and this is apparently way below that, as it is described as warm - not painful. Therefore, I am betting a cooling fan will not be needed to keep my circuit devices from frying. This will be labeled as a hot surface, of course, but that is later - the cooling issue was forefront for now, as warning signs are in stock - fans and flow required calculations -no.
Good Answers: 102
03/21/2015 5:52 AM
110F is about 43C..hardly painful.
My skin doesn't hurt on a hot day in the shade.
Good Answers: 97
03/20/2015 10:35 AM
Phys,
I downloaded a NSAA white paper "
A New Approach to Defining Human Touch Temperature Standards Eugene Ungar
Kenneth Stroud NASA/Johnson Space Center Houston, TX 77062"
I don't have the foggiest on how I would attach the document.
Never mind, JavaHead has it!
CRTL-Z
Good Answers: 76
03/20/2015 10:41 AM
A link to that paper is in reply 1... I've had that one bookmarked for years - it's a great resource.
Good Answers: 122
03/20/2015 10:41 AM
Temperature sensitivity is subjective in humans so determining "warm to the touch" values is nigh to impossible.
Also; The enclosure may be insulated which depending on insulation type and thickness will mask the actual interior temperature where your device will be installed.
The maximum temperature allowed for any domestic water heating device that a human can come into contact with is: 120F
If the device is for use other than domestic water heating there is no way to accurately guess what the temperature will be inside the enclosure.
The risk & liability associated with working on equipment without knowing "real" operating limits is very high.
I would insist on a declaration of operating characteristics including maximum temperature exposure before designing and supplying any electrical devices or equipment that could be subjected to temperatures and conditions beyond their safe operating limit.
If for any reason someone were to be injured or killed due to the failure of your device, there will not be any way to escape the civil and criminal liability from you end of the arrangement.
03/20/2015 10:55 AM
No - we know what the cabinet is and no insulation - water tank is however. I'll trust NASA white paper that says 110°F is painful, and no-one has reported pain from this, just a pleasant warm feeling, as this is an existing design produced before and now has been re-designed to protect circuitry from water spray should any piping leak. So for now, I'll assume no cooling fan to protect my circuit. We'll have the full operating device, enclosure and our circuitry mounted in it, heater, water tank and all, here to test. I want to be ready for now.
03/26/2015 4:03 PM
Probably if it is "warm" now, when there is additional layers of metal between the heat source and outside air, it will be "hot" then. Is there any way to install a Peltier cooler to just the key components inside the box, with the reject heat sink bonded to the box wall? Apparently, the only option you have is to keep things dry, and only electrical power is available on the pass-through.
You could even hold off on that option since there is no hard data telling you that your equipment will in fact fail during initial run. If it fails, then you have a fall back position, if that works for management.
03/20/2015 10:42 AM
If it gets "warm to the touch" now with the "water heating" source inside, I would think you might want to invest in the fan. "Warm to the touch" could be 110 F on the outside, and it would be hotter still inside. When you add your circuit to the heat generation, it will be still higher. Better safe than sorry.
03/20/2015 1:24 PM
If only there was a source of compressed air where this will be used.
03/20/2015 1:49 PM
Now that's how CR4 is supposed to work. Quick answer with some support and helpful suggestions - no fighting - no bickering - done in a few hours.
Thank You All.
03/20/2015 11:36 PM
03/23/2015 8:36 AM
We already got one Lyn. The issue here is I can't do the heat calculations on a custom built insulated water heater. Until the darn thing is fully assembled, I've not a clue as to how much heat the tank will release to the main enclosure. Typically, once a project is built, I'll have a day to finish the electrical and go to QC for testing. A tad bit short of time to figure cooling and get a fan installed. The customer, who has built these before, obviously has not bothered to measure the heat from one of these. That's who told me "pleasantly warm to the touch". As I know my circuit is going to get to 30°F above ambient in its little water proofing enclosure, which is our added modification for use here in the USA, I'd like to know now some measure of temperature in the main enclosure to assure myself I'm not going to cook my circuit. If I have to cool the main enclosure, that will involve the customer and his ultimate end customer, and take who knows how long to get approval.
I am going with the NASA white paper for now, as they describe 110°F as painful - not warm. Sounds like my circuit should be okay at ambient temperatures.
03/21/2015 5:18 AM
Try a Wireless BBQ Alarm. The Senor is small enough to Place practically anywhere. The Probe Sensor is connected to a wire that is small enough to sneak it's way out of the cabinet quite easily. The batteries (4-AA) seem to last forever. It's probe that's be inside Your Cabinet, connected to a wire that's typically have a 3' length. It's read down to a Tenth of a degree, in either C, or F. The receiver unit will read the Sensor at least 50' in My house. I love Mine, and it's a well built, and recognized across the World. Amazon has a variety of Brand, and Models, and here's My great thermostat: http://smile.amazon.com/Oregon-Scientific-AW131-Wireless-Thermometer/dp/B000RL2ZGO/ref=sr_1_18?ie=UTF8&qid=1426927762&sr=8-18&keywords=bbq+thermometer
It's $40!!!! It'll work inside of a closed cabinet, when Others I seen pictured of this link will not!!!
P.S. If You're going to place it in a cabinet, either closed, or open, be sure not to have the Probe touching anything, especially Bone, or Metal. The 3 ft. long, thin Wire is w/o a casing, and can touch literally anything, including being slammed through a Grill, or in Your case, a cabinet door. It MIGHT even allow an A/C Adapter as an Extra??? The Batts. last so ling, I never bothered to look into it.
I readily rely on Mine w/o fail, and couldn't be happier!!!
Good Answers: 19
03/22/2015 10:56 PM
I don't know a rule of thumb.
How many watts does the circuit use? How many square feet or square meters is the enclosure? From that you might be able to develop a semi-educated buess on the skin temp of the box.
Register to Reply 15 comments
James Stewart (1); JavaHead (2); lyn (1); Phys (5); Ried (1); Rixter (1); SHOCKHISCAN (1); SRCASTK (1); Unredundant (1); Wal (1)
