Previous in Forum: Cavalier Joke   Next in Forum: Would You Buy A Replica Mustang?
70 comments
Any Dodge Pickup Drivers Out There?
03/24/2015 10:48 PM
I just bought a 2004 Dodge Ram 1500 for the kid.
The front disc brakes seem to be dragging. Wheels are hot and it's hard to turn the tires when jacked up.
I can't find any specs on this and I don't have factory service manuals.
I understand a little drag but this seems excessive.
Bad fluid/swollen piston seals seems likely culprits.
It drives and stops ok.
Anybody with direct experience with these trucks?
This just happened and now it's dark so I won't look at the fluid till tomorrow.
It may be time for new calipers and fluid, but not just yet.
Yes, I've Googled. And looked at on-line forums. The forums are a waste of time and this post may be as well.
Thanks for any real help that may come my way.
User-tagged by 5 users
Good Answers: 141
Re: Any Dodge Pickup Drivers Out There?
03/24/2015 11:11 PM
Seem to be dragging?
Time to jack the front wheels up to make sure if not your bearings are the culprit. Having no history, someone could have "adjusted" the tension a bit too high.
The brake pads should not be "pushing" after releasing the pedal. This would be the first check I'd do. Release the nut of the wheel bearing a little and spin the wheel by hand when free.
Plenty of room here
Good Answers: 70
03/24/2015 11:13 PM
You could also have a bad master cylinder, bad proportional valve or ABS problems. Being the OP didn't supply all the details, we can't ASSume if his truck has ABS or not
03/24/2015 11:23 PM
'04, of course it has ABS. No lights/alarms indicates it's not a sensor, maybe.
There's a lot I haven't said because I don't know. Just got it.
04/04/2015 12:04 PM
If u dont know then why u bought that and why u r wasting our time?get lost u begger.
Success is a wall made by bricks called failures.
03/24/2015 11:24 PM
Was this message supposed to be for Del?
Good Answers: 70
03/24/2015 11:46 PM
I was expecting Del to take a shot.
03/24/2015 11:35 PM
It sounds like you just need to bleed the brakes....probably some air in the line.....I would go ahead and change the brake fluid, check the brake lines(visual)....If it's a reoccurring problem then you will need to find the source....starting in the dark like this you just have to go by the numbers...
Good Answers: 141
03/25/2015 12:40 AM
Thought of this as my next guess too. GA
Plenty of room here
03/24/2015 11:46 PM
No direct experience with this particular model but lots of experience with brakes.
1. With wheel jacked up, try to spin the wheel. Note the drag.
2. Crack open the bleeder. If a very small shot of fluid squirts out as opposed to a very slow dribble or ooze, there may be excessive residual pressure due to a bad master cylinder or a collapsed brake line. The piston in the master cylinder may be sticky so it does not return the neutral position after releasing the brake resulting in the 'return' ports being blocked. With some flexible lines, there is (rarely, but it happens) the chance that an inner layer of the brake line becomes separated from the outer layers and it collapses in such a way that it acts like a check valve. High cylinder pressure pushes fluid past the blockage, but the much lower return pressure is not enough to overcome the blockage. (Or a bad ABS module $$$)
3. Try to spin the wheel again. If the drag is substantially reduced, then excessive residual pressure is the culprit.
4. If the drag is still more or less the same, then the caliper becomes suspect. Before running out and buying a new/re-built caliper, make sure the pins that allow the caliper to float on the caliper bracket are not corroded or otherwise damaged that would prevent movement of the caliper. Take a lead shot hammer or a sturdy rubber mallet and beat hell on the caliper. Sometimes that will break up any stickiness.
5. There is the possibility that there is a problem with the ABS module, but I have yet to have to repair or replace any of those, and unfortunately, I am not familiar with the ABS set up on this truck.
Good luck with your quest.
03/25/2015 12:00 AM
Things looked OK, but I didn't do anything in the way of diagnostics. All pads were worn evenly, at least.
Kid had to go see his girlfriend tonight.
This may go to the shop.
04/04/2015 12:07 PM
Hey u broker u set up a callgirl and named it as girl and sending for a night. There is no place for brokers in cr4. Try out in any dating site.
04/04/2015 12:17 PM
U fool , u broker, this cr4 is not a dating site. I think admin should look after this lyn.
Good Answers: 123
04/04/2015 9:34 PM
Your personality seems to have some peculiarities. If You are looking for a career path, might I suggest omitting the following: Crisis intervention phone dispatcher, hostage negotiator, phone representative for suicide hotline, 911 phone dispatcher, any religious representative that might need to give out advice, teacher or adviser, bartender, bus or cab driver,,,,, HELL, I don't think you should be allowed to have any contact with anyone other than convicted criminals. And even then, only the worst of the worst.
Just thought I might be able to offer some help in a career choice. Good luck.
Bob
Good Answers: 137
03/25/2015 7:28 AM
Same here. Perhaps I could add -
What are the rear brakes like? If the drag is due to a bad master cylinder it's likely to affect them as well.
If it's the hoses it seems unlikely it would affect both (front) wheels.
You can easily check that the pistons move OK by removing the calliper and pushing the pistons back with a piece of wood, as you do when fitting new pads (as I'm sure you know!). If it's a sliding-calliper type you can check it moves freely at the same time.
Ref #5, I don't see how air in the system would cause those symptoms.
03/25/2015 12:11 PM
....vapor lock...
Good Answers: 137
03/26/2015 5:13 AM
But if the master cylinder is OK, with foot off the brake the whole system is at atmospheric pressure via the ports to the reservoir. I don't see how air or vapour could cause drag. Also if there were much air in the system he would notice a spongy feel to the pedal.
03/27/2015 11:20 AM
If there is air in one side of the front brake line it will cause unequal pressure....one side with air will allow compression and the other side will not....with no maintenance history I would start with visual inspection, and changing the brake fluid....this would be the start of the troubleshooting procedure....for me anyway...and would eliminate 90%+ of the probable cause....If there is another problem, it would then become apparent....My first guess would be a wheel bearing going bad...but I've had both occur..
03/26/2015 7:40 AM
Air in the system does not cause pressure build up, just a spongy pedal, perhaps going to the floor.
If opening the bleeder release the disk; Check pedal-rod play, if OK look for fault in the master cylinder or if all brake fluid pass through a flexible rubber hose before it split to the front wheels.
Good Answers: 75
03/25/2015 11:50 PM
BSR's point 4 is where I'd start. I had the exact same problem on my old Dodge Diplomat (retired VA state police car). I unbolted the calipers (The pin end that the caliper slides on is also threaded, so that it can be both the bolt that holds and the pin the caliper slides on), took the pins both out, used some 600 grit wet-or-dry sanding paper to clean off the corrosion, soaked them with brake cleaner fluid and rubbed them dry. Put Molybdenum White Grease on them (High Temp stuff, doesn't need to be High Pressure, but IS water-proof) reinstalled the pins, and never had a problem with dragging brakes afterward. And it can happen on any wheel, because Dodge uses single-piston calipers, that rely on the piston to push the pad to the wheel on one side, pushing the whole caliper the other way, so that pressure is equalized via the slide-pin. If the pin corrodes, there is no "RETRACTION" of the caliper anyway, and the disc won't be able to push hard enough to cause the pad to regain the couple of thousands inch of play needed so it won't drag.
Take it apart, you'll see what I mean, and I'd bet that is the problem. I was a Dodge (almost exclusively) driver and mechanic for more than 30 years of my driving life, repaired ALL my own, and never had this problem reoccur after one fix. I also only ever had one master cylinder go bad, and NEVER had a collapsed brake line. One proportioning valve went bad, but that was on a later Chevy wagon I owned, so for this argument, it doesn't count
Good Answers: 70
03/25/2015 12:20 AM
II just showed my nephew how to change the rear end on his '01 Ram 1500, disc in front and standard in the rear. The brake system is pretty straight forward on them, even with ABS. How much brake pedal travel is there before and after you drive it? And is it "hard"? Like what Sir Robin said, you could have a caliper frozen, not floating like it should. The calipers are pretty much bomb proof, you'd see a leaking seal if you had a bad seal. And that's not to say that the brakes were properly reassemble during the last brake job. Found that on my nephew's truck rear brakes, someone swapped the secondary with the primary shoes, which lead to some over heating issuses and changing he rear end.
And I sure hope it's not a bad Oman that your thread follows that cavalier joke?
Good Answers: 70
03/25/2015 12:49 AM
Damn tablet and auto correct!! Meant to say, .... bad omen.
03/25/2015 7:55 AM
You may have a collapsed rubber brake line. It's really hard to diagnose but if you check the fluid be sure to see if there's any crap in it. The rubber lines will collapse on the inside and don't necessarily show any signs on the outside. You just have to replace them.
Good Answers: 266
03/25/2015 8:37 AM
First force the caliper piston to retract. I've used a large screw driver in the past. This way there is no drag at the pads and you can see if it's the wheel bearings.
It also maybe the pins the assembley slides on maybe rusted up. Not allowing an even release at the pads. Would cause uneven wear of the pads.
03/25/2015 9:00 AM
Ah, a pickup! Can the truck be turned into a coal roller?
I had a 1986, had it until 2010. First generation, yours is a third generation so I doubt there is much similarity. I had no trouble with brakes on mine; in fact, I got 170,000 out of the factory brakes. Sorry, no help.
Good Answers: 50
03/25/2015 9:31 AM
Lyn: I have a 1996 Dodge Dakota, I have this problem of front disk brake dragging also. I believe it was corrosion of the pad carrier with the holder on the spindle frame. (not sure of the correct names for these parts). I removed the bolts holding the pad carrier, and then filed the rough cast iron where they need to slide during brake application, then used some anti seize on those interfaces. This was last fall, and I have not had a problem again.
The other possibility is internal to the slave cylinder, where a phenolic disk thermal break part is getting hung up, this was per my neighbor mechanic thoughts. I'm not wanting to open the hydraulic fluid lines yet if the first fix works.
ignator -
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Project Managers & Project Engineers - New Member Australia - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
03/26/2015 6:39 AM
That brings back memories. Back in the mid 80's I had a 1982 model Jeep Renegade CJ7. It had a similar problem. The front brake calipers would not release fully causing some drag. The heat generated by the dragging could be felt on the hubs and wheels.
With the Jeep the caliper body was cast iron. One half of the caliper slides in the other half of the caliper in an abutment (basically a wedge on one caliper half slides in a groove on the other).
I disassembled the two halves and cleaned up the sliding surfaces with file and then some emery paper. I found that the cast iron would oxidise quite quickly especially after getting wet and the brake would bind again. So then I coated with some grease (I think I used jet lube but any high temp grease would do). Just put the grease on the surfaces not to excess. It was fine after that.
Peter
Good Answers: 145
03/25/2015 9:32 AM
I had a brake get cherry red and leak a lot of smoke once. Mechanic told me a story about a balancing valve in the brake line (well down stream of the master cylinder) getting stuck with one side open and the other side closed. I have never heard about these balancing valves in the lines before but since he didn't rip me off for more money than expected I don't see any reason for him to get creative. The root cause of the problem was one that I never would have come up with on my own.
Good Answers: 137
03/25/2015 9:54 AM
Did you notice pulling to one side when you braked?
Good Answers: 22
03/25/2015 10:54 PM
Since it is apparent that you bought the truck used and have no history on it, I will relate some brake problems I have encountered when buying trucks from used car dealers. (Most of the time, I try to buy vehicles used from the actual owners and have never had problems that way)
One truck had all the brakes dragging and a very stiff brake pedal about 30 days after purchase. Brake fluid smelled funny. Had a manufacturing plant I called on run a test on it in the chemical department. It was dot 3 and dot 4 brake fluid mixed. A big no-no. The two reacted together, with the moisture in the air, and with the rubber of the system to cause all rubber parts to swell. The truck stopped, although the pedal pressure required was high but would not fully release the pads and shoes. I replaced front calipers, rear cylinders, master cylinder, flushed the ABS and lines and installed fresh dot 3 fluid as specified by the manufacturer. Every thing was fine after that.
Another vehicle, a passenger car, had been sitting for a time before my purchase. Brakes grabbed, were inconsistent, and dragged a lot. Inspection showed rust where the calipers slide and rear brakes not automatically adjusting correctly. (they usually don't anyway) About 30 minutes with wire brush, lube, and adjusting tool solved the problems.
03/25/2015 10:57 PM
Unexpected heat and dragging indicate a dangerous operating condition.
Get the vehicle to dependable dealer, service shop or independent mechanic.
If possible, have the vehicle towed or transported on flat bed.
To attempt to examine or T/S any mechanical product without the manual(s) or prior formal training is the road leading to mistakes and possible disaster.
It's already past time to obtain the service manual. Before the next problem.. Is a good time to do so!
Do I have your attention?
GOOD.
03/26/2015 12:33 AM
Heat is not excessive, won't boil water, front is hotter than rear, but my Chevy 4WD had hot front hubs too.
Drag is relative and is not necessarily excessive, truck starts off at idle when put in drive.
No pulling, no hard pedal, no excessive wear, just my question, is this normal for a Dodge.
Thanks for your concern.
Good Answers: 70
03/26/2015 2:02 AM
If everything is as you say it is (I'm sure it is) and you have grease dripping out the seals, I say let-er buck. Disc brake pads have a tendency to rub some, just nature of the beast. Un-like conventional brakes, disc brakes don't have return springs for the pads and caliper pistons.
Good Answers: 70
03/26/2015 1:07 PM
SOB! This frigging tablet!! I meant to say, "if you don't have grease dripping out the seals ......"
03/26/2015 1:30 PM
He who kicks the butt of the person causing him the most problems, winds up with sore butt.
I think Lyn should beat hell out of the calipers, stomp on the brakes about 50-100 times, swear a bit, and then turn the kid loose with the truck. It is a Dodge. They are meant to be ridden hard and put up wet. Sitting around is hard on any vehicle, even ones sitting around in a barn in Arizona. Sooner you get the rust knocked off this ride the better.
On the other hand, if you are like me, you will spend $XX on fixing the brakes yourself, when you could have just gone to a brake shop for $X (factor of ten less).
04/04/2015 12:11 PM
Then go and ask a mechanic. Why u r wasting our time? Dont u have common sense.
03/26/2015 8:26 AM
I have not read every reply but if the flex lines to the front calipers have deteriorated such as swollen they will let fluid in to the calipers but not release. This is quite a common problem on older vehicles. I have experienced it several times.
03/26/2015 8:56 AM
Seized caliper from lack of use or rust!
03/26/2015 11:03 AM
Quick fix, Replace the Calipers.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
03/26/2015 1:40 PM
What pads are in the truck? Some organic pads(cheap) are thicker than semi-metalics(most OE pads today). They will show as a good cross reference but the extra thickness will cause the problem you are having.( cheaper isn't always better.)
Nothing is fool-proof to a talented fool
Good Answers: 27
03/26/2015 1:49 PM
Sorry meant to add I've run into this on multiple vehicles including Dodge p/u's. Putting in new pads seems to be a common thing when selling a car so the cheapest they can buy........
03/26/2015 2:06 PM
Pads are about 60% so thickness isn't an issue.
I'm not doing anything more till the weekend when we can park the kids truck on concrete and use the floor jack.
I'll try the bleeders first then pry a pad back from the rotor.
Like I said, this may be a quirk of Dodges for all I know.
03/26/2015 2:33 PM
"Like I said, this may be a quirk of Dodges for all I know." I doubt it. "The front disc brakes seem to be dragging. Wheels are hot and it's hard to turn the tires when jacked up." doesn't seem like the sort of thing that a design team would shoot for. I doubt this would be a design element of a Cavalier!
You're right to be concerned, this is a problem that will only get worse if ignored.
03/26/2015 3:21 PM
A 2015 Dodge pickup will have nice, new brakes.....
03/26/2015 4:51 PM
I have owned Dodge trucks since 1971, and my dad owned them for years before that, but they were drum brakes intil my last one. The drag is not proper for disk brakes regardless of brand name. One time I put transmission fluid in by mistake. I recall symptoms similar to what you are describing after driving awile (drum brakes). I would recommend sucking out the brake fluid from the master cylinder with a turkey baster and replacing it, or having a garage remove it all and adding new fluid.
03/26/2015 6:47 PM
You could always let it drift off the 17 somewhere between mountaineer and munds park and then the problem would be solved.
Good Answers: 97
03/27/2015 11:55 PM
The first Harley's with front disk, gave riders a lesson on brake dynamics that was hard to forget, given the fact that lock-up due to the lack of any side to side "floating" action for the caliper, to compensate for run-out, caused the "flying W". This was an early version of the "Brake Dance".
CRTL-Z
03/31/2015 12:51 PM
Check for bad hoses to the front calipers. Briefly open the bleed valve, close it. if the wheel turns normally, and the truck runs normally until the brake pedal is pushed, new front hoses are needed. -- JHF
03/31/2015 2:07 PM
I opened a wheel cylinder bleeder and nothing came out. Still hard to turn, until I pushed a piston back a little and then it got easier.
The kid wants to R&R the calipers himself. We'll see, I may let him.
Haven't checked hoses, yet.
03/31/2015 2:23 PM
Check those flex hoses if they swell up they act like a check valve.
Good Answers: 137
03/31/2015 3:25 PM
Mm... interesting. Normally when you open a bleed screw fluid flows out, slowly, by gravity. If it doesn't, it sounds like either the flexible hose is closed up, or in the master cylinder the ports to the reservoir are covered, because the piston isn't fully retracted. The latter seems unlikely, unless somebody has messed about with the mechanism, but the fact that both front wheels are affected does point that way. Or possibly blocked breather in the reservoir cap, also unlikely. Is it the same on both front wheels (no flow from bleed screw)? What are the rear brakes like?
It wouldn't hurt to make sure the pads move fairly freely in the calliper (they're never going to slide easily and don't need to, there's plenty of force to help them along) and that the calliper moves freely on the slide pins. Gives the kid something to practise on.
Good Answers: 123
04/01/2015 1:05 AM
Sorry to be late to the party. (Some internet issues) #7 & 22 have covered most everything, but let me add this. For years Chrysler used resin pistons in their calipers. There were some conditions that would cause these to swell up just a little. Dragging brakes were the symptom. Not all Chryslers did it, but when a Chrysler came in with hot wheels, we looked. You did the test already. Pop open the bleeder, and then turn the wheel. If still tight, push the piston back in a hair, and then respin the wheel. Be sure to use the $120 brake caliper compressor to do the job. We don't want anyone to call us stupid for using the wrong tool do we? If that cures it, then remove the slide pins, clean and lube them and reinstall. Pump up the brakes, and start the testing again. Pop the bleeder, test, push in the piston, test. If still too much drag, suspect the pistons.
If the truck has been sitting for a while, the brake drag will be higher than a well driven truck, because the disc surface will become rough from rust. Minor rust like this will be worn off by the weekend, so it may self heal.
The only return in most disc brake systems, is the amount that the rubber seals in the calipers, that rub against the pistons, distort under pressure. The square cut "O" rings are trying to push their way out of the grooves that hold them in place when there is brake pressure. When pressure is released, the "O" ring goes back to its original shape, and that usually brings the piston back a few thousandths of an inch.
Bob
04/04/2015 12:18 PM
Tsk tsk. Don't I have to remove the caliper to use the $120.00 brake compressor?
It's going to the shop on Tuesday. There's just too many unknowns to start pulling off parts randomly, and the last Dodge I worked on was a 1961 Dart, 50 years ago with drums all around.
Sadly, I'm not physically able to do this type of work any more and to supervise the 16 YO while he pulls parts randomly off does not seem very smart either. Especially since brakes are pretty important and he hauls his little brothers around sometimes.
Thanks to all of you, except the loser who just posted.
Good Answers: 75
04/04/2015 4:52 PM
Sorry for MY mistake Lyn. I forgot you were the OP here. I've reported Lokeshoki's attacks. I suspect strongly they are in retaliation for something you may have said to him in the past. I'll point that out to the admins, also. I have seen many people complain about "your prickly personality", but in truth, I take it in stride when I don't agree with you, which is in fact less than 30% of the time. And Anonymous Posters, homework leeches, idiots, and trolls account for the other 70%.
Illegitimi Non Carborundum.
I suspect you've seen this before.
Keep the faith, bro.
Micahd
04/04/2015 6:12 PM
Not to worry.
Spoiled children are easily offended.
Yes, I admonished him to do some research before asking the forum to explain simple concepts to him.
He claims to be a student, but none of his posts show any promise.
Good Answers: 70
04/04/2015 6:01 PM
Yup, I think you PO'd Lokeshloki All joking aside, he maybe affiliated with ISIS, so I won't post any more targets!
oh yeah, take a look at this
04/04/2015 6:36 PM
That's a great link.
Probably wasted on Lokesh Loki, who claims to be a, "2nd year b.tech in ece".
That's electronics and communication engineering, I guess.
I think he has a way to go in both electronics and communication.
Good Answers: 75
04/04/2015 8:52 PM
And in personality.
And in intelligence.
And in veracity.
And in ....
Anyone?
04/04/2015 11:58 AM
Dont you have money for doing repair for that at a servicing centre or workshop?why are you begging money indirectly?ask directly that you want some money. Anybody please help this begger.
04/06/2015 3:29 AM
Stay where you are; You would not be welcome in South Africa with such an attitude!
04/07/2015 9:19 PM
Went to the shop today.
I'm prepared to bend over.
Good Answers: 137
In reply to #60
04/08/2015 4:49 AM
Let us know what they find, will you?
04/08/2015 9:43 AM
Sure.
Anonymous Poster #2
In reply to #60
04/08/2015 10:11 AM
I know you use the expression "Bend over" in jest, but in some countries like Lokestan, it is a common form of barter.
Good Answers: 123
In reply to #63
04/08/2015 6:38 PM
WOW! I'll bet that is a real pain in the..........Well whatever, seems expensive.
Bob
04/09/2015 8:57 PM
So, here we are two weeks later.
New pads and rotors all around, a front end alignment (new tires last month) and some other unrelated work.
Everything cleaned and lubed and guaranteed for two years.
The shop owner assured me that everything was as new.
Time will tell.
Thanks for the advice.
Good Answers: 137
In reply to #65
04/10/2015 4:26 AM
Thanks for the feedback. Did they say what the cause of the problem was? Have you checked that the brake dragging is cured?
Good Answers: 123
In reply to #66
04/10/2015 11:39 PM
(It was me. I had put a few dabs of epoxy on the rotors. I thought if I could knock off Lyn, I could expand my stock in Lyn-Door Enterprises.)
Bob
In reply to #66
04/10/2015 11:54 PM
Haven't checked anything yet. I'm giving it a few days.
I'm busy sending the Fort Lauderdale cops to bobc's house right now.
Good Answers: 137
In reply to #68
04/11/2015 11:03 AM
Good Answers: 123
In reply to #68
04/14/2015 3:56 PM
No officer, I don't know who put that epoxy in my toolbox. It wasn't locked. It could have been the Doorman.
Bob
Register to Reply 70 comments
4wsilver (1); Anonymous Poster (2); bob c (5); Bongo Man (1); Brave Sir Robin (2); BruceFlorida (1); Calnet42 (1); Circuit Breaker (1); Codemaster (7); dj95401 (7); Doorman (2); dvmdsc (2); ignator (1); James Stewart (1); JEFFSKI (1); jurie sa (2); Lokeshloki (4); lonster (2); lyn (12); micahd02 (3); MidnightCowboy (1); ozzb (1); roy hammy (2); SolarEagle (3); StandardsGuy (1); Tom_Consulting (1); tonyhemet (1); Unredundant (1); zedex_niner (1)
