Previous in Forum: Tools & Plants List Required Boiler Re-Tubing Job   Next in Forum: Naming Conventions for Mechanical Parts
18 comments
1/2 Inch Tubing Hydro Test Required?
04/06/2015 8:40 AM
1/2 inch stainless steel tubing is being used as a thermal relief line on a 30" Gate valve on Hydrcarbon service. Is this required to be Hydro tested?
Hobbies - CNC - New Member
Re: 1/2 Inch Tubing Hydro Test Required?
04/06/2015 9:03 AM
You give so little information that one can estimate that there is a homework question attached.
04/06/2015 9:10 AM
1/2 in O.D. X 0.035" W.T. 304/304L Seamless pipe is used. What more information would you need?
04/06/2015 9:45 AM
Just assume you need to hydro-test it.
Now don't ask how to do this but I have the feeling you will . .
04/06/2015 10:12 AM
"What more information would you need"
Customer specifications. Customer requirements.
Codes, regulations and specifications controlling the construction and testing of the pipeline.
An explanation as to why you don't already know the answer to this question???
04/06/2015 12:07 PM
  1. What pressure is the system operating at?
  2. What material is being pressurized? (water - oil - gas)?
04/07/2015 4:58 AM
Only the temperature, pressure and nature of the contents of the pipe, and access to the end Client's Piping Standards document. Is there some particular reason why these are not already available? They cannot be seen from here.
04/06/2015 9:10 AM
Is it open? How would you test it?
Is it under pressure and hydro carbons in it? Why would you not test it?
Good Answers: 34
04/06/2015 9:45 AM
Your information is vague and imprecise.
" on a 30" Gate valve"
Welded or threaded?
Is a flange valve or a weld valve?
If is a flange valve... Orifice flange?
What do you try to mean with "as a thermal relief line"
Please explain.
04/06/2015 12:03 PM
Dear Mr.ravinder4143,
½" Stainless Steel Pipe - Is it welded or screwed.
Gate Valve - What is the Material.? Is it Cast Steel or Cast Iron.? If the SS pipe is to be welded, to the valve, then correct choice of electrode is to be chosen or else the welding will be a problem, and leakage will occur. Hence hydro Testing is a must.
Thermal Relief - what exactly you mean.?
Pl. clarify.
The common logic calls for Hydraulic Testing of valve with the 30 Inch Valve.
DHAYANANDHAN.S
04/06/2015 12:05 PM
Sounds like a refinery spec application. Consult your QA/QC lead who will buy the customers QA/QC rep lunch and discuss common sense approaches wrapped in safety on what portions of the systems tests needs to be provided. You don't have a test "matrix" for the project?
Good Answers: 125
04/06/2015 1:36 PM
I assume your thermal relief line is not pressurized, in which case it does not need to be hydro-tested.
Otherwise you are mis-describing your tubing. Normally a relief line is a pathway from a "pop-off" valve which is placed between LNG valves that can be closed. The pop-off and relief line vent over-pressure from solar heating of the line.
Good Answers: 102
04/07/2015 1:56 AM
Only if you are venting into a closed collector would be my guess and that collector will then have some sort of relief as well....
This may steer you in the right direction......http://petrowiki.org/Relief_valves_and_relief_systems#Discharge_piping
If that is a standard pipe size then it's nominally 1/2" ID not OD, just saying....
04/07/2015 3:10 AM
If it were to leak, what would be the outcome?
How much energy is in the line when at its maximum pressure - in excess of 215bar-litres?
What does your leak indemnity insurance assessor say?
Yourball.
Good moaning!
04/07/2015 4:56 AM
Only the end facility's piping standards can determine the answer to the question.
04/07/2015 11:22 AM
ravinder4143
Where did you go. We miss you.
NOT!
Typical poster!
04/07/2015 12:29 PM
Please be patient. I am gathering all the information I can and will share it..
04/07/2015 3:43 PM
Will do!
Good Answers: 137
04/08/2015 5:48 AM
Is the tubing on the inlet to the thermal relief valve or the discharge? (hence at atmospheric or very close) If the latter my guess would be it does not need hydro testing, but it depends on the plant arrangement, and client's specs etc.
Register to Reply 18 comments
Codemaster (1); Crabtree (1); dhayanandhan (1); Goud4143 (2); IdeaSmith (2); lyn (1); Original_Macgyver (4); PWSlack (2); Steve Batey (1); Wal (1); Whitephone (1); WJMFIRE (1)
