Previous in Forum: Temperature & Pressure Compensation in Ultrasonic Flow Transmitter   Next in Forum: Meaning of Re-Transmission Output
Impulse Tapping for Process
04/10/2015 5:25 AM
Hi frnds, we use 3 types of Impulse tube tappings
1.corner tap
2.flange tap
3.D-D/2 tap
I want to know for which fluid state ( Gas, Liquid, Steam) these tapping are prefered.??
Do All 3 tappings can be used for all Fluid state..??? Any Specification or Guidliness available..
Re: Impulse Tapping for Process
04/10/2015 6:58 AM
You say, "Hi frnds, we use 3 types of Impulse tube tappings".
Well, if you use all three, why ask us?
Tell us how you use them presently and we may have an opinion about your use.
If you just want someone to explain how and when and why to use a certain tapping method, you may be disappointed.
04/10/2015 11:51 AM
The best thing to do is to speak to a control systems guru already at the <...we...> to go through in greater detail. After all, if <...we...> are using them, then the rest of the <...we...> would know what, where, when and why. That, surely, is the best place to ask.
Good Answers: 104
04/10/2015 2:48 PM
You left off pipe taps (2-1/2D up/8D down). In my 20+ years of U.S. petrochemical experience, I saw at least a gazillion orifice meters with flange taps, and one with pipe taps. It was in an off-site natural gas metering station. The reference above indicates that corner taps are used quite often in Europe, but I wouldn't know. Keep in mind that putting a 1/2D or 1D tap on a small line (or even fairly sizable) would require a fitting to be installed on the neck of a weld-neck flange, which would be frowned upon.
Register to Reply 3 comments
bigg (1); lyn (1); PWSlack (1)
