Previous in Forum: Relativity   Next in Forum: Any Experience in the Repair of Failed Double Pane Windows
23 comments
Good Answers: 97
Center Doorknob Handle Lock Set
04/19/2015 2:07 PM
I noticed the use of a door knob located in the center of the door on a few BBC shows, even versions with the knob below or above the latch and strike horizontal line. Does anyone have a diagram of the mechanics involved? I suspect it some sort of rack and pinion or similar linkage. Thanks
CRTL-Z
Pathfinder Tags: Central doorknob mechanism
Re: Center doorknob handle lock set
04/19/2015 2:40 PM
It must be a gas to approach such a door, wondering which side will open.
As for mechanism, pulleys and wires could also work.
Good Answers: 97
04/19/2015 5:22 PM
Wait....What? I thought they spun around in the center!
CRTL-Z
04/19/2015 5:27 PM
It seems the door would be harder to open with the handle closer to the hinged side.
04/19/2015 5:30 PM
My butler doesn't have any problems opening ours.
04/19/2015 5:36 PM
Who's your butler--Lurch, Riffraff, or Jeeves?
04/19/2015 2:48 PM
Good Answers: 97
04/19/2015 5:20 PM
That knob lends more emphasis to the term "Don't let the door hit you in the azz".
CRTL-Z
Good Answers: 18
04/19/2015 10:43 PM
That first picture gives a whole new meaning to the phrase: "Don't let the door knob hit you, where the good Lord Split ya!"
Technical Fields - Technical Writing - New Member Engineering Fields - Environmental Engineering - New Member
Location: The 'Hub of the South Pacific'; 18.15°S, 178.45°E
04/19/2015 10:59 PM
That hand looks creepy.... Care to shake?
VT
04/19/2015 2:54 PM
04/19/2015 3:04 PM
You live in a barn?
Good Answers: 97
04/19/2015 5:10 PM
I did, but I was arrested for leaving the barn door open.
CRTL-Z
Good Answers: 445
04/19/2015 4:49 PM
You're right, it's a rack and pinion double latching mechanism, also known by its trade name as the "Fox Police Lock".
http://www.nokey.com/foxstylpollo.html?utm_source=googlepepla&utm_medium=adwords&id=18283950120
04/20/2015 3:06 AM
I have fitted similar units here, but none had a knob, only a key cylinder....they are very safe and a good addition to preventing someone breaking in, preventing even the lock smith (ME!) some years ago.
Few know it here, but after I retired in 2006, life got a bit boring and I went back to school and learnt how to open locked doors, repair and install locking mechanisms and the like.
A customer called in as he had lost one of the two keys he needed to open his front door, the one for the "normal" cylinder. Even though I asked him several times if the Police lock was open (he did not want to give me the key to allow me to check it myself, he was very weird!), I believed that I had opened the normal lock several times, but the door remained closed...(I was simply pushing the deadbolt back with a wire tool)
Eventually I lost my "rag", I INSISTED that he tried that key and he then opened the door!!! It cost him an extra (expensive) hour of my labor!
Not my problem!!
I left the business completely after 7 months as I found it morally wrong in so many ways (I was working for a very suspect company! Most of them are it would seem....)
Though I really liked the work and still do it today for friends and neigbours when needed......for a bottle of whiskey or similar, not money.
Good Answers: 97
04/19/2015 5:17 PM
I swear I could not find it on Gaggle, I will punish myself. Anyway, thanks to everyone! (Genuflected out of scene, and cut).
CRTL-Z
04/19/2015 5:22 PM
Google "lock backset extension links."
04/19/2015 5:29 PM
What did you Google in order to turn up that phrase? [Catch-22 rides again....]
04/19/2015 5:42 PM
It's on page 8 of the Yale lock site posted by SE.
Good Answers: 97
04/19/2015 5:41 PM
I tried "central doorknob mechanism latch hardware handle set.."
CRTL-Z
Re: Center Doorknob Handle Lock Set
04/20/2015 5:06 AM
Maybe we need a stupid manual for Google search terms so that we can not look at it.
Good Answers: 97
04/20/2015 10:47 AM
I looked for that manual on Google and could not find it.
CRTL-Z
Good Answers: 266
04/20/2015 7:56 AM
04/20/2015 4:46 PM
Installed only one, originally made in the early 50's. Had to transfer from an old set doors to new ones, custom made out of solid mahogany, each 40" wide, by 7'6" tall, doubles. The receiver door held the dummy knob, and the active door latch was a circular gear assembly, with the notched (gear) rod passing through it. The lock was activated by turning the key an extra 25 degrees, or so. (Accounting for the extra length past the gear assy.) The hardest part (Besides lifting the damn things--They were HEAVY!!), was drilling a 25 inch , 1 inch bore, hole, straight, so the shaft mechanism would not bind at any point, and so that the drill bit did not "drift" and come out of the door panel midway. Solved that by making a "rifle bore " jig, that forced the bit to go straight 8" , to start, then finishing the bore by hand, with a brace and bit…Took a while to get them hung and tuned, but, they are beautiful. Outside of 4 foot wide Double Dutch doors, they were the hardest ones I ever had to deal with.
Register to Reply 23 comments
Andy Germany (1); C-Mac (1); JIMRAT (1); lyn (4); ozzb (1); RAMConsult (1); Rixter (1); SolarEagle (2); SWB123 (1); Tornado (3); Unredundant (6); VT (1)
