Previous in Forum: Quadratic Equation of Vessel Thickness   Next in Forum: IED's
8 comments
Methanol Dosing for Removal of Any Moisture
05/06/2015 3:53 PM
Hi All,
We have a critical problem of a cold box which has the diffrential temp of about 80C ,off course the temp is subzero.but the heat transfer get reduced and when we dosed the methanol the performance increased to it design but after some days it again detiriorate .again we dose the methanol but it again happen the same.after some days heat exchange deminises.Can anyone help me out the probable couses and its remedies.
Thanks
Good Answers: 104
Re: Methanol Dosing for Removal of Any Moisture
05/06/2015 5:37 PM
Come out of hiding behind the AP mask and you'll get better response. The semi-obvious solution is to dry your stream(s) before they enter the exchanger. Give more information and you may get a better solution.
05/06/2015 7:28 PM
Sounds like you have a leak....
05/06/2015 8:14 PM
this will rid you of both unwanted moisture and excess methanol
05/06/2015 11:26 PM
As well as a drying agent MeOH is used to break hydrates. You don't mention what sort of exchanger you have but if there is significant pressure drop, water content and low temps then hydrates may form and block flow paths. Dosing with MeOH causes the hydrates to break down freeing up the surface area.
I would think that this would be more of a problem with plate exchangers and the like
This still returns to:
Dry the streams before they go into the cold box
Or fix the leak so that the stream doesn't get wet in the first place
Or change the process so that water is not formed
there really is too much that we do not know about this process
05/07/2015 1:25 AM
You might use ethanol dosing for bribing a refrigeration technician to look at it.
05/07/2015 5:38 PM
Works for me! (hic) -- JHF
05/07/2015 1:59 PM
How does the equipment manufacturer respond when approached on this problem by telephone?
Good Answers: 102
05/18/2015 11:39 PM
Dr Who and Daleks + methanol....
Cold Tardis (police box) result..
bigg (1); Circuit Breaker (1); Fredski (1); PWSlack (1); simonsd (1); SolarEagle (1); Tornado (1); Wal (1)
