Previous in Forum: RTD's   Next in Forum: MV DG Sync. Issue
29 comments
Transistors and Lamps
05/18/2015 4:02 PM
How can you design the control of a lamp using your fingers? Such that when two of them touch (index finger and thumb) the lamp goes on. I want to use a transistor.
Pathfinder Tags: control lamps touch transistors
Good Answers: 122
Re: Transistors and lamps
05/18/2015 4:09 PM
By utilizing "Hall Affect" sensors. There are many lamps, water faucets (valves) and other gadgets on the market that already use this system.
05/18/2015 4:16 PM
Isn't there a way to do this without sensors? Just something really basic to understand the uses of transistors
05/18/2015 4:46 PM
In you quest to "... understand the uses of transistors.", what has led you to believe that a transistor is the appropriate component for this proposed circuit control?
05/18/2015 6:02 PM
One can use a FET transistor as a sensor to trigger a power transistor circuit. However, if the person touching the FET has the slightest amount of static charge in the wrong polarity then either no switching will happen, overly sensitive switching will happen or in the worst case the static charge could destroy the FET.
One can make circuits with transistors that are so sensitive to a person that one does not have to touch the device but just carefully move in the field around the circuitry. Because of this I would not recommend trying to teach transistor circuit theory with a circuit that a person touches the circuit.
If you wish to see how sensitive to a persons movement a circuit can be, watch Pamelia Kurstin play a Theremin. The only instrument a musician does not touch to make music. I particularly love the bass solo she plays in "Falling Leaves".
05/19/2015 9:22 AM
"Isn't there a way to do this without sensors? Just something really basic to understand the uses of transistors"
You are looking to make a touch-operated lamp to help you understand the uses of transistors? It would appear that you are a self-directed, self-motivated learner, and that is commendable. I always encourage people to learn more.
In your case, I would recommend you start with something a little more formal. Take a basic electronics course at the local community college, that will help you get the fundamental knowledge to allow you to explore the world of transistors more easily and more effectively.
05/19/2015 3:50 PM
http://www.amazon.com/Make-Electronics-Discovery-Charles-Platt/dp/0596153740
This is an awesome book. They sell complete electronics kits to go with the instruction. Very hands on.
05/19/2015 10:40 AM
Yes. It is called a lamp socket switch, and it only requires me to use two fingers - one thumb on the lamp base, the other on the switch, and it is one of the push through style, that easily turns lamp on and off. No fancy electronics to mess up in a lightning storm. These switches have apparently been around since Edison invented the light bulb.
OR - you could install an acoustically activated switch called the clapper (not the flapper), and on this one you merely clap your hands. Do not applaud your dancing girls too vigorously, or the lights will flicker on/off.
Good Answers: 122
05/20/2015 9:15 AM
Yes, but it is rather painful and I would not recommend it
No matter what type of sensor you choose there will be some transistor operation involved.
I would start here then perform more in-depth searches on the subject.
en.wikipedia.org/wiki/Field-effect_transistor
Good Answers: 444
05/18/2015 5:37 PM
Hall Effect devices sense the proximity of magnetic, not electrostatic, fields. The transistor in those "touch switches" is biased to conduct when the leakage capacitance of our bodies couples with the electrical noise fields surrounding our environment. Not a lot of current, but just enough to make a neon voltage tester (remember those things?) conduct when one side is attached to the "hot" side of a circuit.
05/18/2015 10:49 PM
GA. I remember back in the late seventies and early eighties when touch lamps were all the rage. You 'bout nailed it so I'll leave it at that. Cheers!
Hobbies - CNC - New Member
05/18/2015 4:34 PM
05/18/2015 6:02 PM
I'd let my fingers dial up a light store.
I don't think either of us is capable of doing this.
Good Answers: 804
05/18/2015 6:04 PM
  • Isn't there a way to do this without sensors? Just something really basic to understand the uses of transistors
Without sensors? So you want something that will read the mind of the person wanting to control the lamp when they touch their own fingers together? Are you looking for something like "the Force" from Star Wars?
"Turn on you will... or in the dark side you will stay."
Let us know when you succeed, I can think of a lot more valuable things to do with that kind of technology than controlling lamps.
05/18/2015 6:07 PM
05/18/2015 7:30 PM
You can use a phototransistor arranged so that when you bring your fingers together it blocks the light shining on the transistor.
A standard bipolar transistor can work as a phototransistor if light can reach the transistor base. The light releases carriers on the base-collector junction the same way that forward biasing the base-emitter junction does, turning the transistor on.
I once carefully filed the top off of a transistor in a metal can and could turn it on and off by passing my hand over it.
Phototransistor
Good Answers: 141
05/19/2015 9:54 PM
Your image looks more like a LDR.
Light dependent resistor.
Plenty of room here
05/23/2015 12:26 PM
Actually a ThorLabs FGAP71 Gallium Phosphide photodiode. I grabbed the wrong image. Sorry, good catch.
https://www.thorlabs.com/thorproduct.cfm?partnumber=FGAP71
Re: Transistors and Lamps
05/19/2015 12:51 AM
"How can you design the control of a lamp using your fingers?" There are numerous ways, including:
1. While doing the design work, hold a pencil or pen between those fingers. It is quite helpful to make a drawing.
2. Use those fingers to turn the pages of one or more reference books.
3. Use those fingers on a mouse or trackpad to do a series of searches on the internet.
4. Hold solder between one pair of fingers (or a finger and a thumb) and the soldering pencil between others while assembling possible circuits to test.
Sorry! I couldn't resist answering the question as posed...
Good Answers: 102
05/19/2015 4:43 AM
That solves the 2 finger part of the problem.
Sensors can be eliminated by holding ice till your fingers lose sensation. This may have to be repeated. Burning your finger tips removes sensation for a few days, saves having to rechill, but needs to be done in advance.......
05/19/2015 7:44 AM
A Darlington triple should do it:-
Choose the resistor depending on your power supply.
Good Answers: 69
05/19/2015 9:04 AM
This is a toggle circuit, you operate it to turn it on, and touch again to turn it off; the second circuit is a transistor touch switch.
There's an author that I like very much, Forrest M. Mims III, you can find his engineer's mini notebooks at any Radio-Shack. I have built many of his circuits and found that they always work, and that they are very tolerant when you don't have the exact component, simply put a fairly aproximate and voila !.
I got his books at home, so I couldn't pass you a couple of circuits, but the ones above should do the trick as well.
05/19/2015 9:23 AM
Bill H.
Good Answers: 804
05/21/2015 2:23 PM
You guys are reading more into the OP's statement than he said.
"...when two of them touch (index finger and thumb) the lamp goes on."
He is not describing a touch lamp circuit there. He does not say he wants to touch the LAMP, he just wants to touch his FINGER AND THUMB TOGETHER and somehow, magically, the lamp will go on or off without the use of "sensors".
FM ...
05/21/2015 2:30 PM
That's why I suggested watching that TED talk where a Theremin was played. She's really good at it, too.
Good Answers: 444
05/21/2015 2:33 PM
So he wants to use a camera to capture an image of two fingers (which two?) touching each other then feed the image in realtime to a computer to decipher the information to output to a relay to close the lamp circuit...Can anybody spell "Rube Goldberg"?
05/21/2015 2:42 PM
Your point is made but sometimes it is better to give the customer what they need instead of what they asked for.
05/21/2015 2:42 PM
Correct!
Now when you touch your index finger to your thumb, you are closing a somewhat conductive, roughly circular, loop that includes a capacitance (the surfaces of the two digits separated by the dielectric of two layers of dead skin). I presume that loop would have a resonant frequency of low Q. It just might be possible to detect that loop. Of course that resonant frequency will vary from person to person, depending on such factors as orientation, size, shape, skin chemistry, recent skin history (such as wetness), etc.
05/21/2015 2:55 PM
Why can't we all just play nice, and make the other kid's toy work?
Radio Shack has conductive thread you can sew into clothing. That might make a really nice antenna for your Theramin circuit Q-Switch where you touch index finger and thumb together. Have a wireless tuned circuit at the lamp waiting breathlessly for your every command.
02/12/2021 5:02 AM
Register to Reply 29 comments
adreasler (1); Bill H. (1); Brave Sir Robin (1); dkwarner (2); Doorman (1); dvmdsc (1); James Stewart (2); Jeff24 (1); JRaef (2); lyn (1); Original_Macgyver (1); PWSlack (1); RAMConsult (2); Randall (1); redfred (3); Rixter (2); Sheek (1); SHOCKHISCAN (2); SolarEagle (1); Wal (1); Yahlasit (1)
