Previous in Forum: Butterfly Control Valve   Next in Forum: Liquid Level Sensors
Expensive SCADA Based Pump Scheduler For Energy Savings
06/09/2015 2:54 AM
Large municipal water pumping, treatment and distribution pumping stations are audited for energy savings. Parallel pump operations with best efficiency point selection, pressure optimisation and pump-scheduling can be achieved only through expensive SCADA with algorithms as per many suppliers. However, site operators tend to overlook even these after sometime, making it difficult to sustain energy savings. Kindly share/advice with experiences Central SCADA and is this an inevitable/expensive option for energy savings on supply side of municipal water pumping systems.
Re: Expensive SCADA based pump scheduler for energy savings
06/09/2015 3:12 AM
Vapid jargon like that is unlikely to achieve energy savings, reliable operation, or anything else. Thank you for playing.
Re: Expensive SCADA Based Pump Scheduler For Energy Savings
06/09/2015 2:50 PM
Site operators tend to look at other factors in a complex system than just energy savings.
Service life, general upkeep and associated labor costs, misc service costs and in many cases is the damn thing able to be adjusted by the average person in 5 minutes or less when an unexpected operating condition or fault occurs.
My point is putting in a $10,000 control system that saves $5000 a year in energy costs but adds more than $5000 in costs in other areas of the systems operation and upkeep is not a savings of any kind and that's where too many managers and non service people fail at this sort of justification of additional 'energy efficiency savings 'control devices.
06/09/2015 7:49 PM
SCADA is what you make it.
If your organization is run by bean counters, then control and reporting is as important as efficient operation.
If site operators overlook these, they can be replaced.
Instructions are easy to follow if the operators buy in to the routine, and own the process.
SCADA is not an end all, save all. It's just a tool!
06/09/2015 8:11 PM
"SCADA is not an end all, save all. It's just a tool!"
But it's a tool with a 130+ page operators manual that requires a two year minimum degree in computer software science to use properly.
Good Answers: 122
06/10/2015 9:48 AM
The issue with total SCADA control is and always has been twofold.
1. Due to budget constraints and lack of technical hands-on knowledge, management often choose the lower cost, incomplete, and semi-functional version leaving operations with a system that sometimes maintains control that is acceptable but not optimal. This could be effective if the selection choice includes a detailed plan along with an adequate budget to expand the system in the future and also allow on-site tuning to improve the SCADA system through trial and error operational experience. (Fix the programming that is not correct and add what is needed.)
2. Lack of knowledgeable, competent operational and maintenance input during the drafting of equipment and SCADA control purchasing specifications. If the SCADA system programming is flawed and the operations personnel do not know how to operate the process system correctly in hand or cannot take control of the process way from automation then production, performance, and profit suffers.
I often see runaway conditions in our various processes that result in large production losses and/or equipment damage because the operators are totally dependent on the automation to control the process. If one of the instruments fail or get out of calibration the control loop is rendered non-functional and many of our operators do not understand the process system well enough or not at all so taking the control into "hand" operation usually does not work out well.
In our haste to maximize profit and reduce human error we have overlooked the simple fact that the dollars invested in proper selection and training of personnel pays back very high dividends over a long period of time.
As Lyn stated: "The SCADA is what you make of it."
06/10/2015 1:44 PM
Great experience shared by forum specialists, was quick and cool and thanx for inputs, even when jargons are eating away our capital in the name of software/advancements/ unmanned utilities. I enjoyed mention of ownership concept, simple/trained staff, who can master over the SCADA instead of dependence on 150 page control philosophy with 2 year advanced graduate teams spending their time on FB/Watt-app, unable to restore process during control/instrumentation failure.
Good Answers: 444
06/24/2015 10:50 AM
It's not the expense of the SCADA system that makes it viable, it's the knowledge and understanding of the underlying equipment and processes that makes it valuable. Pump scheduling is a relatively easy study to undertake, and the algorithms could be handled by a $100 Arduino μprocessor, but putting the two together is where the big bucks get spent. First figure out your savings goal, then see if you have the budget (and the stomach) to implement it.
Register to Reply 7 comments
lyn (1); RAMConsult (1); SHOCKHISCAN (1); srgovind (1); tcmtech (2); Tornado (1)
