Previous in Forum: For Aviation Buffs and Air Travelers   Next in Forum: New Acronym for Your Vernacular
20 comments
1978 F150
06/15/2015 4:46 AM
How do I test engine heat when guage says cool?
Pathfinder Tags: auto mechanics
Good Answers: 19
Re: 1978 f150
06/15/2015 4:55 AM
A good analog temp probe installed in the cooling jacket through any number of orifices Ford drilled and tapped into the block/heads will generally produce good results.
Re: 1978 f150
06/15/2015 8:33 AM
Can you be a little more specific?
Re: 1978 f150
06/15/2015 4:58 AM
Try a Non-Contact Infrared Thermometer With Laser Targeting
They're pretty reasonable and accurate, I used my side by side with one that costs a couple of thousand and up to 900 degrees, it's within 2 degrees F.
http://t.harborfreight.com/non-contact-infrared-thermometer-with-laser-targeting-60725.html
Re: 1978 F150
06/15/2015 10:08 AM
Harbor Freight. $20.00 US.
Infrared Laser Thermometer
Item #93984
Re: 1978 F150
06/16/2015 1:05 AM
Dont you mean, 124.16 Yuan ?
Good Answers: 266
Re: 1978 F150
06/15/2015 12:40 PM
Unless it's boiling over and steams coming out I wouldn't worry about the engine temperature. Replace the sensor. It's a relatively inexspensive part. If that does not do it the thermostat could be bad. Running cool the cause was usually it's stuck open. With a cool engine open the radiator cap. Start the engine if you notice the coolant is circulating rapidly. The thermostat is stuck open. If it's not circulating rapidly wait until it does thens when you need a temperature gage. To tell if it regulating the temperaure properly.
Re: 1978 F150
06/15/2015 2:05 PM
Re: 1978 F150
06/15/2015 2:55 PM
that would be the replacement...... and if it accessible, only about 2 minute job to replace.
Re: 1978 F150
06/15/2015 5:35 PM
  • Place a smoker kipper (Google it) on the engine, and see how long it takes the neighbourhood cats to arrive?
  • Drop water on it and see if it turns to steam?
  • Grab hold of it and see how long it takes blisters to appear?
The possibilities are endless!
Good Answers: 123
Re: 1978 F150
06/15/2015 9:27 PM
As an extension of your answer, I offer this. Most people can hold onto something up till about 150 degrees F. And water will boil at 212 F. at sea level. Those two things should tell you how hot your engine is.
Is the temp gauge the only one not reading? If so, the issue is isolated to the temp gauge. If others are out, then look for a common power feed, or common ground.
The factory gauge was powered from the key, to a voltage reducer, to the gauge, and finally out to the sensor, searching for a ground. This ground was temperature variable, causing the gauge to move relative to coolant temperature.
One more tip for the OP, if the temp sensor came out of, or was designed for a vehicle with an overheat indicator light, it will be opeck.n between the wire connector, and the threaded part of it. In that case it will always show cold till it reaches the overheat temp. Then it will change to almost 0 resistance. Good lu
Bob
Re: 1978 F150
06/16/2015 1:12 AM
Smoked kippers are yummy with saltine crackers and grey poupon mustard.
Re: 1978 F150
06/16/2015 4:54 PM
Sssssssssssshhhhhhhhhhhhhhhh! Don't tell Del!!!!
Re: 1978 F150
06/16/2015 3:06 AM
You have generally 3 main possible error sources, though engine management systems can also cause such problems, some modern cars even have "controlled" thermostats, where the MMU opens and closes it with a tiny motor, not directly by water temperature....:-
1) Electric fan never switching off - never seen that one personally - but very easy to check.
2) Thermostat jammed open, this can even be due to the fact that it was wrongly installed, years before maybe, and eventually the little "bobble" got caught in the mouth opening. Place in boiling water to release and to check operation. If OK (as mine was on my then Volvo) simply replace with the "bobble" at the bottom, in my case that was 180° (angle) to how the idiot mechanic had put it in....Or replace it if is staying open all the time.....
Some have a simple mechanism to hold it open IF THE ENGINE HAS OVERHEATED, WATER MISSING FOR EXAMPLE, TO DEMONSTRATE THAT THE THERMOSTAT WAS NOT THE REASON....
3) Sender for the thermometer is defective, already covered in some detail by others.
I personally like the idea of buying a cheap IR remote thermometer that some here have mentioned to read the temp off the motor block.
Such a unit can be a good addition to any household/workshop, one simply needs a reason to buy it, now you have that!!!
Remember that with some engines, not only will a cool engine increase fuel consumption, but it may even increase oil dilution and or wear on the engine, so it does need to be fixed.
Best of luck..You should be able to fix it yourself!!
Re: 1978 F150
06/16/2015 3:16 AM
when you put your finger on the top of the rad and it hurts is a cheap way otherwise laser thermal temp guns are quite cheap
Torque is not cheap
Re: 1978 F150
06/16/2015 9:54 AM
My money is on your thermostat stuck open. Especially with an older vehicle. It's located where top hose from radiator meets the intake manifold--two bolts hold the bell-shaped housing onto the manifold. A new one will cost you maybe $10. Scrape the old gasket remains clean. Use gasket shellac/cement--and install the thermostat correctly. Eyeball the old one--if it's stuck open, you will see space through which water can flow. If it's closed, check by immersing in a pot of boiling water. If it opens (it's a subtle thing) as the water approaches boiling temperature, then it's working.
Read it again. Now think about it.
Re: 1978 F150
06/16/2015 3:26 PM
You don't mention if there has been a deviation from the normal temperature indication. The gauge is merely an indicator and may be reading correctly. Did you replace the wire from the gauge to the sensor? This wire is calibrated for a specific length and type of wire (usually Iron and Constantine).
If this is an OEM gauge, wire, and sensor, there have been may responses regarding stuck thermostat. If you installed an aftermarket temperature gauge, you may have placed the thermocouple sensor on the radiator output (cool side) or in the fan airstream (also cool).
Look at the exhaust pipe to see if it is carbonized. A cool engine will be rich in carbon.
United States - Member - U.S.A. Hobbies - Fishing - New Member
Re: 1978 F150
06/16/2015 3:44 PM
Aslo one other item. There are at times a voltage regulator on the back of the dash. If this is faulty it will give you a false reading. If it's changing rapidly from cool to hot and visa versa, this could be the issue. I had a '88 T Bird that drove me crazy. replaced everything including recore of the radiator. Turns out this $50 item on the back of the dash panel was all I needed to correct the problem. Never had a heat problem again... wonder why that was.
There are always others less fortunate than you, be happy, to them you are Mr. Jones.
Re: 1978 F150
07/21/2015 2:24 AM
Aimed lazer tester at thermostat housing after 1/2 hour idleing. read 180. Guage didn't come off first mark. Seems like it should read higher.
Re: 1978 F150
07/21/2015 3:33 AM
That is possible. You have a further 32°F till boiling. Most cars I have driven may JUST start to register a temperature at that point....
What temperature (usually stamped on) is the thermostat supposed to be ? Is it the right one for the vehicle?
In a worst case, the thermostat is stuck open, which will usually increase fuel consumption slightly, but in the short term should not damage your engine....
My personal take is that generally, running temperature will be somewhere between 190°F and 200°F.
Also, some vehicles use a fully pressurized system and can run at boiling point quite safely.....
So there is quite a degree of variance.....
You need to open it up an have a good look at the thermostat...or simply replace it....it could be quite old and now as good as useless.....
Best of luck.
Good Answers: 123
Re: 1978 F150
07/31/2015 1:49 AM
OK, this thread seems to be going nowhere. Your factory gauge setup has been calibrated at the factory The marks on the gauge correspond to an exact ohm reading on the temperature sensor. For the cold line, the hot line, and possibly a their line in the middle, there is a published ohm reading the sensor should be at. The fi find it. Let me know.ne people at Ford have this information. Auto parts stores MAY have this information. And I have this information. It is located in my storage unit, and will retrieve it if you can not.
Bob
Register to Reply 20 comments
Andy Germany (2); AWSCWI(RETIRED) (1); bob c (2); len (1); lyn (1); merc600sec (1); ozzb (1); phoenix911 (2); possum (1); PWSlack (2); SolarEagle (1); tonyhemet (2); Tripper (2); Wrench twirler (1)
