Previous in Forum: Insulation Resistance Test Voltage   Next in Forum: Star and Delta Connection Difference in Motors
Neutral Inversion
06/20/2015 10:44 AM
What is neutral inversion in ungrounded system?
Good Answers: 42
Re: neutral inversion
06/20/2015 12:35 PM
Julius
Re: Neutral Inversion
06/20/2015 7:36 PM
06/22/2015 1:24 PM
It is a good phrase to enter into an internet search engine prior to performing a search on the topic. Good luck.
07/10/2015 6:38 AM
Neutral Inversion is a phenomenon in which the neutral of an ungrounded three phase system falls out of the voltage triangle. This usually occurs in a three phase system which is not earthed and where a single transformer is used in a voltage-based earth-fault sensing system. The transformer may be connected to one of the phases and the ground. This transformer needs to be provided without sufficient resistance loading. The no-load or exciting impedance of the transformer is in parallel with the line capacitance of the phase to which the transformer is connected.
Register to Reply 4 comments
7anoter4 (1); msajaa (1); PWSlack (1); SolarEagle (1)
