Assume that a solar powered spaceship was built. It is fired in a trajectory similar to that of a comet. As it comes closer to the sun it reaches 80% light speed. It is then aimed at a big planet and catapulted back to the sun and reaches the speed of light before passing the sun (on a safe distance)
The question is how will the power output of the solar panel change over time on approaching and running away at light speed or slower.
Assume that the measurements are taken at the same distance from the sun.
