Previous in Forum: Energy Measurement   Next in Forum: Transformer Coil Windings
33 comments
Breaker Size
06/23/2015 12:30 PM
I have diesel heater, and I have a data sheet with that heater, but I am not sure which data should I use to calculate a breaker size.
Air Top Evo 5500
Heat power (kW) 1.5 - 5.0 (5.5*)
Fuel Diesel
Fuel consumption (l/h) 0.17 - 0.60 (0.66*)
Rated voltage (V) 15 - 95 (130*)
Air flow against 0.5 mbar (m3 /h) 200 (220*)
Re: breaker size
06/23/2015 12:34 PM
The data you should use is that appertaining to the wiring. You do realise it is the wiring that the breaker is thereto protect, don't you?
Good moaning!
Re: Breaker Size
06/23/2015 12:36 PM
your breaker really only has one job...to protect your wire from carrying too much current to the point it heats up and burns. size the wire right and you'll be fine
Re: Breaker Size
07/09/2015 1:25 AM
according to your post, I don't need breaker if I have a proper gauge wire. I might need breaker for inrush current which will cause to heat up the wires, correct?
Re: Breaker Size
06/23/2015 12:50 PM
You would size the wiring and breaker at the maximum amperage draw + 25% or the closest fuse size available over the max draw, and the wire sized accordingly...You always want the fuse over the max amp draw, and you always want the wire size above the fuse rating by a comfortable margin....
  • Rated Current: 1.3 - 7.9 Amp (12 Volt DC) / 0.6 - 4.0 Amp (24 Volt DC)
http://www.defender.com/product.jsp?path=-1%7C2276179%7C2061078%7C2061089&id=1291962
Re: Breaker Size
06/23/2015 2:19 PM
thanks for answer. Is the rated current 7.9 amp consider as a max amperage. 25% addition to max amperage draw, is that percentages implemented to all dc equipment. Can I use this percentages for other AC equipment.
Regarding the fuse size would be over max amp draw by how much percentages.
Re: Breaker Size
06/23/2015 4:40 PM
7.9 amps 12v would be the max....a 15 amp circuit would probably work well....then you need to determine the length of the wire, if it's under 10 ft, a #10 copper wire size would work fine....always check the amp draw on the circuit with an ammeter after completion....I like to use a little conductive grease on wiring connections to keep corrosion at bay....
http://www.solar-electric.com/wire-loss-tables.html
Re: Breaker Size
06/23/2015 9:17 PM
thanks for your answers and for your help
Re: Breaker Size
06/24/2015 1:10 AM
You posted "....always check the amp draw on the circuit with an ammeter after completion...."
What reason needs to check by ammeter, to check continues current or max current?
Re: Breaker Size
06/24/2015 12:00 PM
You check the amp draw to determine if the unit is working to spec....this is basic for any new electrical installation...
Re: Breaker Size
06/23/2015 2:23 PM
May I ask you, regarding same link that is in your answer, what purpose of providing output BTU, and Fuel Consumption. Is that something to do in designing wiring circuitry for the heater.
Re: Breaker Size
06/23/2015 4:44 PM
No, that's how much heat it puts out and how much fuel it takes to do that....
Re: Breaker Size
06/30/2015 5:17 PM
Can I connect two or three equipment to one breaker only to protect those three equipment. Please correct me if I am wrong, in order sharing equipment to one breaker, I need to add up the max load of each equipment,
the total of max load of three equipment x 25% = the size of breaker
equipment could be Navigation system, VHF system, or lights
Good Answers: 70
Re: Breaker Size
06/30/2015 5:36 PM
You seem to know enough to be a Darwin Awards Candidate! And, I'll be happy to nominate you for it
Re: Breaker Size
06/23/2015 1:01 PM
Did you read the instructions that came with it, Mildred? That's where I'd look, then, I'm funny that way.
Good moaning!
Re: Breaker Size
06/24/2015 9:10 AM
Did we arrive in the same clown car this morning? Because I'm funny in that exact same way too.
"When in doubt, Read The Funny Manual. (RTFM)" Why don't they teach kids this in school? It would save a ton of problems later on in life.
Re: Breaker Size
06/24/2015 10:44 AM
you don't have to read all the posts. I am new for this things and I want to make sure I am doing the proper thing.
Good Answers: 70
Re: Breaker Size
06/24/2015 12:09 PM
Then do the proper thing and hire a qualified electrician before you do some proper damage that you'll regret later.
Re: Breaker Size
06/23/2015 9:22 PM
What does a diesel heater do?
Are you saying its a generator powering a electrical heating element?
If this is not a off the shelf construct I strongly advise to get an electrician to look at your installation. Otherwise there should be a breaker already so why not RTFM?
Re: Breaker Size
06/24/2015 1:05 AM
for provide air to boat's cabins. It is economical on fuel and power. Not most manuals for equipment provide the fuse size and breaker size, so I have to make calculations and choose also a proper wire size.
Re: Breaker Size
07/05/2015 10:30 PM
Thats where the electrician will help you.
How are you grounding your system? Just asking. On a boot it does not seem to be trivial.
Re: Breaker Size
07/09/2015 1:33 AM
I will share grounding of heater with other dc equipment, just like automotive, how electrical system is grounded.
Re: Breaker Size
06/24/2015 11:10 AM
<...What does a diesel heater do?...>
One of the possibilities is that it heats diesel.
Re: Breaker Size
07/05/2015 10:28 PM
Ha, I did not think of that!
Now I hear it supplies air to cabins. I am unsure how to proceed. I have the feeling the air will smell like diesel . . .
Re: Breaker Size
07/09/2015 1:30 AM
No it does not smell like diesel. In fact, some countries, not in US still use diesel heater. People had no complain about the smell of the heater.
Re: Breaker Size
07/16/2015 1:10 AM
Did you hire an electrician?
In case of a fire with a diesel heater on board there will not be a lot of options to run. You better get this right.
Re: Breaker Size
07/16/2015 1:19 AM
No I did not hire an electrician.
There will be no fire because I used a proper breaker size and wire size.
Good Answers: 70
Re: Breaker Size
07/16/2015 11:34 AM
We'll never really know what happens to this guy, being an Anon Poster. From what this AP has expressed about his electrical knowledge, all we can do is hope this wasn't his fishing boat !
Good Answers: 70
Re: Breaker Size
06/24/2015 1:07 AM
RTFM On page 22 of the installation instructions, there's a square box (figure 26) that says, F= 20 amp (12volt) or F= 15 amp (24volt) So, depending on which voltage your going to use, select the proper wire size for that fuse. Real simple if you RTFM
Re: Breaker Size
06/24/2015 1:14 AM
Thanks for your indication, but I need those type of information for other equipment. I have to know the right fuse and breaker when manual does not mention it.
Good Answers: 70
Re: Breaker Size
06/24/2015 3:17 AM
The installation/ operation manual does tell you the size of fuse to use on page 22.
In your original post/ question you stated " Rated voltage (V) 15 - 95 (130*), that's the output wattage and not the voltage. Also, I didn't not see anything about using a circuit breaker in place of the on-line fuse. The instructions also said to use the supplied "weather's proof fuse holder".
For your own safety and others, you should follow the instructions to the letter. A fire on board while under way is not good for anybody. If you feel compelled to modify the manufacturer's wiring, then you should get an approval from the manufacture, otherwise the warranty is void and if somebody is hurt or killed as a result of the heater, your the one liable for damages.
Re: Breaker Size
07/09/2015 1:43 AM
I followed manufacture requirements for fusing size. The fuse was to protect the electrical device, but beside the fuse, I have a breaker to protect the wires. Is just like in your home, there is a breaker panel separate installed somewhere, in addition there is an internal fuse to protect electrical device.
Good Answers: 70
Re: Breaker Size
07/09/2015 2:43 AM
You really need to stop playing around and get some professional help for your heater and yourself.!
Re: Breaker Size
06/24/2015 9:36 AM
Hire a qualified Electrician to install it. Then, calculation would be unnecessary.
Reply to Forum Thread 33 comments
adreasler (1); Anonymous Poster (13); Crabtree (2); dj95401 (6); Fredski (1); IdeaSmith (4); PWSlack (2); SolarEagle (4)
