Previous in Forum: 2 Way Modulating Valve in AHU   Next in Forum: High Vibration of Boiler Feed Pump
9 comments
Induced Draft Counter Flow Cooling Tower Problem
07/07/2015 3:05 AM
Dear All,
We are facing a problem of High Cold water temperature from Induced draft counter flow cooling tower for 600 MW unit with CW Flow - 67500 m3/hr.
Actual parameters are as below:
Range - 10 C against design 10 C
CWT - 36 C against design 32 C
CT Airflow - As per design
Dry Bulb Temperature - 44 C against design 32.7 C
Wet Bulb Temperature - 27 C against design 28 C (As WBT is less than design, tower should perform as per design)
Humidity - 27 % against design 70 %
Please help me to identify possible causes of High Cold water temperature
Regards,
Gaurav
Re: Induced draft counter flow cooling tower problem
07/07/2015 5:02 AM
Tower too small.
Good Answers: 120
07/07/2015 6:23 AM
This degradation seems to be caused by high input air temperature of 44C (11.3 C degrees higher than design), which leads to the cold water being 4 degrees higher. Doubtless due to the record breaking high temperatures in your area, which cause a reduction of the ability of the tower to cool the water down. The humidity is low, or the problem would be exacerbated.
The tower is too small at the extreme temperatures encountered lately. The only fix is a supplemental tower to be used on the bad days to give added cooling. Some of these links might offer suggestions
cooling tower degradation
Per Ardua Ad Astra
Good Answers: 225
07/07/2015 7:09 AM
You don't mention the incoming temperature, if that is higher than design limits then you will get higher outlet temps.
You do say that the range of 10°C is within design parameters, so the tower is achieving the temperature reduction that it is designed to do, so the problem is most likely incoming temperature or total heat load.
Re: Induced Draft Counter Flow Cooling Tower Problem
07/07/2015 8:20 AM
it is working as designed, just stop hitting it with high inlet temps, DUH
Good Answers: 122
07/07/2015 8:44 AM
Are you sure the direction of air flow for all fans is correct? If you have one or more fans running in the wrong direction, the temperature will be affected.
07/07/2015 9:29 AM
Inspect your cooling tower fill also. It should be breaking the water into fine droplets. If you are getting pouring water you could try to add more fill or decrease flow.
I saw a problem once where the scrubber balls from the condenser were plugging the holes in the deck causing water to cascade over the side or stream out in thick columns that wouldn't break sufficiently.
I hope your operators are sufficient to ensure fan direction is correct, you might be able to change the pitch of the blades to get a bit more air flow, but if the weather is a temporary issue it would be better to leave them.
Drew K
07/07/2015 10:58 AM
Please check your fill it might have scaled and also check the air flow it may be reduced due to the choking of fills
enervac
07/07/2015 1:31 PM
Dear Mr.gaurav sharma,
You have not mentioned no. of cells. You have told some parameters as per design.
You have also mentioned Wet Bulb Temperature - 27 C against design 28 C. A lower Wet-Bulb temp should give a better performance than the design value since the Cooling Tower Efficiency is given by the equation (Thot-Tcold)/(Thot -Twet)
You have also mentioned that the Actual Relative Humidity is 27% as against 70%, which should result in a better performance since lesser Relative Humidity Air will absorb more water vapour to reach to Saturation Level, thus removing more heat from the hot water.
But it is not so in your case. I suspect the air flow is disturbed and required quantity is not flowing. To check this pl. verify the following.
From design aspect - What is the MERKEL RATIO in the design and what is the actual ratio when you face the problem. In other terms what is the Design L/G ratio and actually observed. I have a doubt the Air flow is reduced may be due to blade angle change.
What is the power absorbed by the Fan Motor(s) - it should be loaded to 80% and more. If less, the Air flow is reduced.
Pl. read the subject from the following links and you may find a solution for your problem.
DHAYANANDHAN.S
https://www.google.ca/search?q=cooling+tower+degradation&oq=cooling+tower+degradation&aqs=chrome..69i57.11662j0j8&sourceid=chrome&es_sm=93&ie=UTF-8
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CDEQFjAD&url=http%3A%2F%2Fclasses.engineering.wustl.edu%2Fche473%2Fhandouts%2Fcooling%2520tower%2520performance.pdf&ei=JgKcVd62GOHfmgXvsIG4BA&usg=AFQjCNG7yg3qRNw2JxnKMx3KLO2M88OyvA&bvm=bv.96952980,d.dGY
https://books.google.ca/books?id=6j5nuvAd44QC&pg=PA378&lpg=PA378&dq=cooling+tower+degradation&source=bl&ots=HHBQK_aj_R&sig=8z_S323lArxigoFI4GwfAOJUOYA&hl=en&sa=X&ei=rgScVeu4LObGmAXuyIPQAw&ved=0CFcQ6AEwBQ#v=onepage&q=cooling%20tower%20degradation&f=false
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=13&cad=rja&uact=8&ved=0CGIQFjAM&url=http%3A%2F%2Fnaabzist.com%2Fpdf%2FCooling%2520Tower%2520Thermal%2520Design%2520Manual.pdf&ei=JgKcVd62GOHfmgXvsIG4BA&usg=AFQjCNE8SS278wJjZ1nrh4 YxP3GrHE0Qnw&bvm=bv.96952980,d.dGY
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=12&cad=rja&uact=8&ved=0CCIQFjABOAo&url=http%3A%2F%2Fwww.kgogroup.com%2Fwp-content%2Fuploads%2FCooling-Tower-Basics-and-Common-Misconceptions1.pdf&ei=kwacVY2LBsTGuATmi4PYCg&usg=AFQjCNHJkoxBWUZwUtQoxvwwbl3uXqAbWA&bvm=bv.96952980,d.dGY
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=14&cad=rja&uact=8&ved=0CD0QFjADOAo&url=http%3A%2F%2Fwww.ijsrp.org%2Fresearch_paper_feb2012%2Fijsrp-feb-2012-33.pdf&ei=VwWcVfuFOoilmQWn-4ioAw&usg=AFQjCNHWJuGH1dYqbnh4VcIaVA0SGcinCQ&bvm=bv.96952980,d.dGY
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=16&cad=rja&uact=8&ved=0CEcQFjAFOAo&url=http%3A%2F%2Fxa.yimg.com%2Fkq%2Fgroups%2F10603698%2F137609219%2Fname%2FNDCT&ei=VwWcVfuFOoilmQWn-4ioAw&usg=AFQjCNH3dCxmNjOAQqFgPANskPaOy2c01Q&bvm=bv.96952980,d.dGY
06/23/2023 7:34 AM
What does <...High...> actually mean (rhetorical question - NNTR)?
The water temperature can never go lower than the wet-bulb temperature of the air passing through it, for it is this that determines whether any evaporation takes place. With the given figures, if the wet-bulb is <...27 C...>, then that is the minimum achievable cooling water supply temperature, and in practice it will be a bit warmer than that.
If cooler heat transfer fluid temperatures are required, then a refrigeration loop is needed downstream of the tower to provide those temperatures, and that's all there is to it.
If in doubt, consult a qualified Heating, Ventilation and Air Conditioning Engineer.
Register to Reply 9 comments
aurizon (1); dhayanandhan (1); Drew K (1); enervac (1); Fredski (1); PWSlack (1); SHOCKHISCAN (1); spades (1); Tornado (1)
