Previous in Forum: Centrifugal Pump - Unique Venting Arrangement   Next in Forum: Colored Black Spectrum
10 comments
Welding to Sock-o-let After Hydro Test
07/13/2015 1:23 PM
I am working on a pressure vessel designed in accordance with ASME section 8 division 1. The client wants to change thread-o-let to sock-o-let connections on the vessel for vent and drain connections. For the hydrotest i added a nipple, coupling, and threaded plug so the sock-o-let hole can be plugged. After the hydro test, the nipple + coupling + plug would be removed. Since this means the client would have to weld a new connection to those sock-o-lets would that mean they need to re-hydrotest the vessel? Is the sock-ol-let considered part of the Pressure vessel or can the client weld new fittings/connections to that sock-o-let with no issue just like other fittings and pipe with threaded or flanged connections can be changed with no effect to the vessel.
I appreciate the input! Let me know if more information is required.
Good Answers: 70
Re: welding to sock-o-let after hydro test
07/13/2015 1:31 PM
Wait a minute, are you saying "Your Client" came to you asking this question and now your asking us??
Do we get a percentage of "Your Fees?? Nothing in life is free, my friend
07/13/2015 1:55 PM
DJ95401 yes you are right, didn't even think about that. No worries though I completely understand I have plenty of other sources to look from just thought i'd see if anyone here knew the answer off the top of their head. I'll update with the answer once i find it for other users in the future.
Good Answers: 26
07/13/2015 2:43 PM
the client would have to weld a new connection to those sock-o-lets would that mean they need to re-hydrotest the vessel?No. the new connection is not part of the vessel. I have run into this problem in the past.
07/13/2015 2:55 PM
Correct, Just spoke with an ASME AI. Code only covers up the first joint which would be the sock-o-let thus anything after that is cut or welded would not affect the code calculation. Thanks!
07/14/2015 2:48 AM
The issue is not code or standard. The point that you have made a new weld and this weld needs to be tested either by an NDT method or hydrotest , you cannot just leave it like that.
Good Answers: 26
07/15/2015 8:41 AM
As stated i ran into this question many years ago. I suggested to the client that we weld a cap onto the fitting and then xray the weld and they accepted as well as the inspector. Additional piping from a vessel falls into the piping code and not pressure vessel. If you exceed the requirements and retain the records then it will usually be accepted.
08/10/2015 5:50 PM
CR4 ADMIN: Deleted Post
Spam:
This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Good Answers: 70
08/10/2015 6:09 PM
WTF ??? Reported- Read the Rules before posting on CR4® Good bye
Good Answers: 61
Re: Welding to Sock-o-let After Hydro Test
07/14/2015 12:57 PM
bntm,
You might want to consider machining out the threads of the o-let fitting thus converting it to a Sock-o-let.
Do it once and do it right
07/14/2015 3:39 PM
Modifying an inspected and certified vessel surely invalidates the inspection and certification!
If title to the vessel has not yet passed into the ownership of the Client, then modifications, retesting and certification is chargeable. If that is the case, then prepare a quotation and a timeline, and await further instructions. Make sure there is a deadline on the quotation, and laugh all the way to the bank.
Register to Reply 10 comments
Anonymous Poster (1); bntm (2); dj95401 (2); MKA (1); PennPiper (1); PWSlack (1); texasron (2)
