Previous in Forum: Pluto Flyby Tonight   Next in Forum: Need Help Finding the Meaning of a Drawing Symbol
21 comments
Hobbies - CNC - New Member
What is This?
07/14/2015 1:12 PM
What is this? No cheating please!
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Re: What is this?
07/14/2015 1:13 PM
Levitating Hoverboard
Re: What is this?
07/14/2015 2:10 PM
It kinda sucks when the first person to reply nails it!
Good Answer there BD.
Since you got it, here's a follow up.
Who made it?
Re: What is this?
07/14/2015 2:50 PM
Doc Brown?
Lyndoor IndustriesTM?
KrisDelTM?
Go on. Do tell!
Re: What is this?
07/14/2015 3:31 PM
Here is the article. A hover board that uses magnetic levitation,and liquid nitrogen cooled superconductors and permanent magnets.
Re: What is this?
07/14/2015 1:17 PM
Pepto-Bismol powered Life raft??
Re: What is this?
07/14/2015 1:21 PM
LOL...
I like this one better...
Re: What is this?
07/14/2015 1:26 PM
That looks like an electric headband charger with the optional E-Stop attachment!
Re: What is this?
07/14/2015 1:31 PM
Looks like a high tech fly zapper to me....
Good Answers: 97
Re: What is this?
07/14/2015 2:19 PM
Audi vacuum aperture grommus?
CRTL-Z
Good Answers: 18
Re: What is this?
07/16/2015 12:24 PM
Whatever it is it is made by Audi.
Re: What is this?
07/14/2015 1:31 PM
a soapdish filled with dry ice
Good Answers: 918
Re: What is This?
07/14/2015 5:10 PM
An overexposed photograph.
Good Answers: 97
Re: What is This?
07/14/2015 5:26 PM
What the heck is this her jar then?
CRTL-Z
Re: What is This?
07/14/2015 5:48 PM
Oil?
Re: What is This?
07/14/2015 7:39 PM
It's an Ampco Lubricator for adding lubrication to the valve seats on dry fuel source engines,,,,,.
http://ampcolubes.com/home
Good Answers: 97
Re: What is This?
07/15/2015 9:06 AM
Bingo! Sometimes called a "Top oiler" or "Induction oiler". I had one on an old Volvo, which is probably why it kept getting older.
It was said, that you could use brake fluid for higher performance.
CRTL-Z
Re: What is This?
07/14/2015 5:52 PM
That's a water separation device for fuel supply on an old hot rod....
Good Answers: 122
Re: What is This?
07/14/2015 6:12 PM
Aftermarket fuel over-pressurization trap on an old Ford flathead V-8?
Good Answers: 225
Re: What is This?
07/14/2015 6:49 PM
All Veteran and some vintage cars benefit from a fuel additive to change the octane rating and often to add upper cylinder lubricant as well. A common additive is called Flash Lube
It can be premixed with the fuel in the tank or, as this one appears to be (albeit home made), drawn in via a carburetor vacuum port as you drive.
If it were, as has been suggested, a water separation device, you would note an incoming pipe as well as the outgoing one, and there would be no breather.
Below is a pic of a genuine unit.
Re: What is This?
07/15/2015 9:11 AM
AS BD said.
And it's a Lexus to boot!
Re: What is This?
07/15/2015 10:53 AM
Some sort of new Kotex, with only seven amazing absorbent fibers, and you can ride it to work, hovering over the sidewalk?
Register to Reply 21 comments
Anonymous Hero (1); BDThompson (1); Fredski (1); James Stewart (1); Massey (1); Original_Macgyver (4); PWSlack (1); rashavarek (1); SHOCKHISCAN (1); SolarEagle (4); spades (1); SWB123 (1); Unredundant (3)
