Previous in Forum: ETAP UDM   Next in Forum: Cold and Hot Start of a Motor
13 comments
What is a Varistor?
07/29/2015 5:01 AM
Dear sir
Good afternoon . I about the electrical varistor and which is the use place .
thanks
Nur islam
Re: What is a Varistor?
07/29/2015 5:19 AM
07/29/2015 5:22 AM
Geez! Snipping tool resolution is CRAPPY!
Hobbies - CNC - New Member
07/29/2015 9:30 AM
Getting a bit SNIPPY huh?!?!
07/29/2015 6:45 PM
Eeeeaaarrrppp!! There, I'm better now.
Good Answers: 50
07/29/2015 11:20 AM
GA, Metal Oxide Varistor would be the full correct name, i.e. MOV.
ignator -
07/29/2015 1:39 PM
Unless, of course, the material was not Metal Oxide.
Silicon Carbide comes to mind...
...there are others
common knowledge...less common than common sense
Good Answers: 804
07/30/2015 8:18 AM
Ummm... Last I looked, silicon is a metal...
07/30/2015 11:56 AM
Not a quite metal:
Metalloid (or "semi-metal" or "poor metal"). The metalloids are B, Si, Ge, As, Sb, Te, and Po. They sometimes behave as semiconductors (B, Si, Ge) rather than as conductors.
from http://periodic.lanl.gov/metal.shtml
08/04/2015 11:53 AM
Silicon Carbide Varistors are not Metal Oxide Varistors. MOV's are primarily made of zinc oxide. MOV's have a specific content with a generic-sounding name.
The most important part there would be the oxide, whereas Silicon carbide is a carbide.
07/29/2015 1:57 PM
  • It is an excellent topic for an internet search engine to process.
  • It is an excellent keyword for Wikipedia to process.
  • Etc., etc.
What is an Anonymous Poster?
07/29/2015 2:32 PM
Reply Score 1 for Off Topic
08/04/2015 11:55 AM
numbskull obviously doesn't get the anonymous part of that response.
09/25/2015 1:36 AM
First of all it is a recommended to understand the working principle of a varistor and by understand the working principle of the varistor then you will then understand how and what the varistor is use for.
A varistor is an an electrical resistance that varies with the applied voltage. At low voltage it has a high electrical resistance which decreases as the voltage is raised.
Varistors are used as control to provide optimal operating conditions or to protect against excessive transient voltage. When used as protection devices, they shunt the current created by the excessive voltage away from sensitive components when triggered.
Example: Varistor are connected across the Relay Coil to protect against excessive transient voltage during the relay coil is energies or during de energize.
ignator (1); JRaef (1); Mikerho (4); Original_Macgyver (1); PWSlack (1); Simon Wan (1); The.Tinkerer (4)
