Previous in Forum: Average Number of Cloudy Days   Next in Forum: Shaft Current In VFD Operation - Insulation Bearing
16 comments
Alternator
08/06/2015 12:38 AM
Can i run alternator disel engine to motor which connected to output of alternator it work or not n why
Pathfinder Tags: alternator
Good Answers: 444
Re: Alternator
08/06/2015 12:45 AM
You can run an electric motor from the alternator if they're the same voltage, etc., but if you're thinking that you can use that motor to turn an alternator whose output turns the same motor, you can't.
Re: Alternator
08/06/2015 1:17 AM
MMay i know y
Re: Alternator
08/06/2015 1:47 AM
Because it would take two alternators instead of one to no other benefit than more components to look at to turn the same diesel over for a start.
Usually the second alternator is replaced by a battery for means of energy storage for the next start.
Re: Alternator
08/06/2015 2:04 AM
Not if you can't be troubled to write out complete words. Your post is a prime example of a certain mindset that, despite sound, proven science that says basically "you can't get something from nothing", "There's no such thing as a free lunch", and "100% efficiency cannot be attained in a system that can never be "closed"".
And here you are wanting to expend very little energy (I call it laziness) to get a "free answer on the internet".
You are suffering from magical thinking. May the quality of answers to your questions equal the quality of your questions.
Re: Alternator
08/06/2015 3:06 PM
Because of the three Laws of Thermodynamics:
  1. One cannot win.
  2. One cannot break-even.
  3. This is the only game in town.
Re: Alternator
08/07/2015 10:45 AM
Since 'the only game in town' still implies a choice (you can play, or you can sit at home), I prefer the following description
  1. You can't win.
  2. You can't break even.
  3. You can't quit.
Succinct and unambiguous.
You try to make a perpetual motion machine, an 'over-unity amplifier,' or free energy:
Re: Alternator
08/09/2015 6:42 AM
Not guilty.
Re: Alternator
08/10/2015 9:27 AM
Sorry, the second part of that was for the OP.
Good Answers: 804
Re: Alternator
08/06/2015 3:45 PM
One word...
Losses.
Re: Alternator
08/06/2015 1:45 AM
Alternator has two outputs:
1. Mechanically as motor starter
2. electrically as battery charger/electrical supply.
Which output do you want to connect and why?
Good Answers: 102
Re: Alternator
08/06/2015 10:31 PM
What?!!
Re: Alternator
08/18/2015 3:52 AM
Never mind! Did I really say that? Its on par with the posed question!
Re: Alternator
08/06/2015 2:18 AM
You may. You have my full permission. Come back here when you can't get it to work.
Good moaning!
Good Answers: 102
Re: Alternator
08/06/2015 10:33 PM
What is your question?
Re: Alternator
08/07/2015 1:00 AM
We apparently have several problems here:
1. Translation problems from one language to another: The word order of your sentence does not make sense in English. Why would you connect a diesel engine to a motor? This implies that the diesel engine is applying power to a motor, but a motor is a device that is intended to use electricity to produce rotation. The starter motor does just that, but for only a short time, until the diesel engine is running, and producing far more power than the motor.
I suspect that what you want to do is to use the diesel engine to run the alternator, and use the output of the alternator to run the motor. That is exactly what diesel 'gensets' do. There is no reason why not, as long as the diesel engine produces more power than the alternator requires, and the alternator produces more power than the motor requires to do its assigned task.
Find someone whose NATIVE language is English, but also speaks yours, and have them help you translate your questions into correct English.
2. Possible generation gap problem. Most of the regulars here are either semi-retired or completely retired. Most of us mature folks do not appreciate incomplete words and incomplete sentences. As at least one other person said, f u cnt wrt fll sentences, u r be'n lazy! Ask correct questions using complete words and sentences, and you are much more likely to get an appropriate answer. Don't try to use a phone as a substitute for a computer!
3. As Jraef said, losses. Every device that transforms energy from one form to another wastes some of that energy. That's why I said the engine must produce more power than the alternator needs, and the alternator must produce more power than the motor needs. At least a couple of the replies prior to mine think that you are trying to use the output of the motor to run the alternator, and use the output of the alternator to run the motor. That would be impossible, due to the losses (mostly in the form of heat). Even if you could somehow eliminate all losses, which you can't, you still would not have a useful device. If you tried to get that imaginary 100% efficient motor to do something useful other than spin that imaginary 100% efficient alternator, there would no longer be enough power to keep the alternator spinning, and the system would collapse.
Re: Alternator
08/07/2015 10:51 AM
Cn U rite n cmplte wrds plz?
It wll sho U hve a brian.
Whn U rite n leet, it mks us wnt U 2 DIAF.
Jst tryn 2 hlp U owt.
kthnxbai
Register to Reply 16 comments
adreasler (2); Anonymous Poster (1); Crabtree (1); dkwarner (1); IdeaSmith (3); JRaef (1); Mikerho (1); prasad1685 (1); PWSlack (2); RAMConsult (1); Wal (2)
