Previous in Forum: Bypass Arrangement for Busbars in Substation   Next in Forum: Optimum Binary Signal One Can Transmit on a 1 Hz Frequency
Running A 11KW 2 Pole Inverter Duty Motor At Low Speed
08/10/2015 7:34 AM
Dear Friends;
We have 11KW, 2pole, 400V inverter duty motor working at a take up conveyor of a single facer unit of a Corrugator machine. A separate cooling fan is with the motor. Normally motor works within 1700-2300rpm. For some reasons, we want to run the motor at 300-450rpm for some days. Kindly suggest if it is okay to run a 2pole motor at low speed? Normally motor current remains at 60%.
Hobbies - CNC - New Member
Re: Running A 11KW 2 Pole Inverter Duty Motor At Low Speed
08/10/2015 9:25 AM
I don't see any real issues with the speed reduction but I do have a few questions:
  • What is the motor RPM on the data plate?
  • Is the motor overheating?
  • Is the inverter overheating?
  • Is this a common practice of using the motor VFD to switch from ~2000 RPM to ~ 325 RPM?
Good luck
Bryan
Good Answers: 804
08/10/2015 1:31 PM
Well, it says in the title that it is 2 pole, then 400V which implies 50Hz, so the synchronous speed would be 3000RPM, slip speed probably around 2750.
With a separately cooled motor, I see no issue whatsoever. That's exactly what VFDs are for.
08/10/2015 7:54 PM
And even more so, that is what the separate cooling fan is for.
08/10/2015 11:10 PM
You may need to see you data sheets regarding torque for that motor, 300rpm about 5Hz may not be able to deliver the same torque at 50Hz.
08/10/2015 11:26 PM
Good point; on a conveyor, full (or nearly full) torque will be needed even at low speed. Some motors and VFDs can do that, but not all.
08/11/2015 8:47 AM
use a two speed transmission to slow down speed when needed.
08/11/2015 8:54 AM
Maybe, or maybe not.
Register to Reply 7 comments
eltech (1); JRaef (1); Original_Macgyver (1); setlock77 (1); Tornado (3)
