Previous in Forum: Spaced Out Food   Next in Forum: Tablets
21 comments
What is This?
08/11/2015 12:21 AM
first photo shows quite clearly it is a prototype miniature robot that after a careful selective breeding program , later went on to give birth to R2D2 of Star Wars fame......
( not )
It was found in a box of tools at a garage clean up
So what is it and who used one recently ?
Re: What is this ?
08/11/2015 12:28 AM
Whatever it was, it's a back scratcher now.
Good Answers: 19
Re: What is this ?
08/11/2015 1:18 AM
internal bearing puller/slide hammer.
Good Answers: 97
Re: What is this ?
08/11/2015 12:26 PM
I agree,
Looks like the thing you use to pull the bushing thing in the crankshaft thing that supports the pointy end of the transmission thing. You can also use a wooden dowel, some grease and a hammer or rock.
Regards,
Sky Pilot Bushing..
CRTL-Z
Re: What is this ?
08/11/2015 2:12 AM
Adjustable nail puller.
I attend work so my dogs can have the good life.
Re: What is this ?
08/11/2015 6:59 AM
First impression was same as Doggonit, but there seems no thinning to lead in nail heads.
Had an uncle once who commented that anything solid with mass when at hand could be used as a surrogate for a hammer.
So i think it's a possible hammer! (Though I know it's not.)
Re: What is This?
08/11/2015 9:23 AM
It appears that it is meant to be turned with the sleeves and the part on top to put a handle through. My guess is it is a tool to square off the bottom of a drilled hole (a reamer).
Re: What is This?
08/11/2015 9:25 AM
I think it is a home made tool for making inside threads in something. Those 2 "feet" on the bottom of the robot look like cutters to me.
Hobbies - CNC - New Member
Re: What is This?
08/11/2015 9:50 AM
I'm pretty sure that Wrench Twirler got it. It looks like a shop made tool for removing bearing races or seals.
  • Possibly able to use it like a slide hammer?
  • Shorten it to get into smaller places?
  • It looks custom made so it probably had one particular use and was tossed in the old tool box of horrors?
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
Re: What is This?
08/11/2015 10:45 AM
thread chaser/broach for internal threads?
Nothing is fool-proof to a talented fool
Good Answers: 27
Re: What is This?
08/11/2015 1:49 PM
It's a pilot bearing puller. turn the knob and the fingers spread to grab it. then give a yank. Sometimes called a blind hole puller.
Good Answers: 27
Re: What is This?
08/11/2015 2:33 PM
Correction, As I was typing one of our "grey beards" saw the pic and just showed me the one in his tool box. It is an Hydraulic valve lifter tool(slide hammer type),His looks identical.
Re: What is This?
08/11/2015 10:35 PM
Odd that you get a GA for an incorrect answer and none for a correct answer. So i gave you 1.
Re: What is This?
08/11/2015 2:55 PM
K-D 2079 Hydraulic Valve Lifter Remover Tool With Slide Hammer
Re: What is This?
08/11/2015 4:14 PM
Isn't that a valve SEAT remover?
Good Answers: 97
Re: What is This?
08/11/2015 4:27 PM
Unless you have sasquatch fingernails, hydraulic lifters are difficult to get out.
CRTL-Z
Re: What is This?
08/11/2015 4:30 PM
Very true.
Re: What is This?
08/11/2015 5:54 PM
No,,,,.
Here's another one....$14 on Ebay
Re: What is This?
08/11/2015 8:32 PM
Good answer , the previous owner thought it was an oil seal remover but that didn't sound right based on the claw movement range . Hydraulic lifter puller it is. :-)
Re: What is This?
08/12/2015 5:52 AM
It's an aftermarket hydraulic valve lifter removal tool. I have one in my tool box but it's many years since I needed to use it. The claws spread into the groove in the end of the lifter and screwing the shaft tighter, expands the claws to hold the lifter.
Robert A. Heinlein (1907-1988) "There is no worse tyranny than to force a man to pay for what he does not want merely because you think it would be good for him."
Re: What is This?
08/12/2015 2:58 PM
Bluebelly: you should really remove your E-Mail address from your signature line, unless of course you enjoy being bombarded by spam.
Re: What is This?
08/12/2015 4:53 PM
Thanks, Randall. I never realized it was there.
Register to Reply 21 comments
bluebelly (2); Doggoneit (1); harley (1); JIMRAT (1); Just an Engineer (1); lonster (3); Nothing is Impossible (1); Original_Macgyver (3); Randall (1); Rixter (1); SolarEagle (2); Tornado (1); Unredundant (2); Wrench twirler (1)
