Previous in Forum: Liquid Nitrogen   Next in Forum: Surface Coating on Immersion Heaters
17 comments
Measuring Temperature in Small Silver or Bronze Melts
09/03/2015 1:25 PM
I'm looking for recommendations for insturmentation for measuring the temperature of small (<100ozt) silver & bronze melts for jewelry making. I'm using a torch & crucible for the melt. I underastand that IR pyrometers are not recommended due to the emissivity & reflection properties of silver & bronze. Are there thermocouple/thermowell products that are used by the small scale jewelry maker? I have been quite successful judging when to pour "by eye", but, being an Engineer, I'd like to measure it. All advice is appreciated! Thank You.
Good Answers: 151
Re: Measuring Temperature in Small Silver or Bronze Melts
09/03/2015 1:42 PM
Check Omega Engineering The provide a broad selection of thermocouples and measurement instruments. One consideration is the compatibility of the thermocouple alloys with the alloys that you are working with.
09/03/2015 2:36 PM
Thanks for the quick suggestion! I have perused Omega, and chatted with their online reps, but do not find anyting for a small scale 1000C melt.
09/03/2015 2:49 PM
Maybe a general search on "pyrometry" could help.
09/03/2015 2:58 PM
Seach for "laser thermometer". You can get one these days for less than fifty quid.
Good moaning!
Good Answers: 122
09/03/2015 7:05 PM
I vote with Crabtree.
Try a hand held laser unit.
They are cheap and close enough for what you are doing unless you are trying to automate the process.
09/04/2015 1:02 AM
Laser thermometers are actually infrared thermometers. :)
Read more : http://www.ehow.com/how-does_4962575_laser-thermometers-work.html
So, back to square one !
09/04/2015 1:38 AM
Good catch, so GA! I caught it too. Looks like somebody has oeuf sur son visage.
Good Answers: 122
09/04/2015 6:08 PM
Yes but they provide a laser dot for focusing the sensor in the correct position to give the most accurate reading.
09/04/2015 1:32 AM
Hi gk1248,
Some here have mentioned "laser thermometers". I looked it up, and "laser thermometers" are simply infrared thermometers (IR pyrometers) using a laser pointer for, er well pointing.
Based on Ag, your melts are ~ 270 mL in volume, requiring an estimated 500mL vessel, presumably ceramic.
A primary question is "how long between when you sense the temperature until an action must take place?"
I'm thinking a fine-wire Type K thermocouple (TC) housed by an appropriately-sized ceramic tube, acting as the thermowell (TW). This would be placed in the melt from the open top of the crucible. Electronics can be had fairly inexpensively. I have some specific ideas about exactly how to do this, and I'll try to post them later.
Mike
09/04/2015 10:07 AM
Flir is also not cheap. Simple thermocouple or RTD will do. Search the internet.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
09/04/2015 10:21 AM
Yes, Mike; that is the configuration I thought might work. I hope to discover if there are any members with experience with such a setup on as small a scale as mine. Alternately, I have considered drilling a small hole horozontally halfway through the base of the crucible, below the level of the insde bottom. (The crucible is .7" thick at the bottom.) The thermocouple & it's ceramically insulated wires would slip-fit into the hole; it's wires would run up the metal crucible handle to a small box cotaining either a millivolt meter or a small circuit board with an AD595 Thermocouple amplifier, a Microchip processor, appropriate firmware, and a digital readout. <Ah, dreams of glory!> I would of course not be reading the temp of the melt, but that of the inside of the crucible, which would act as it's own thermowell. I could perhaps find the temp correlation. Has anyone tried something like this? All suggestions are welcome - thnaks all for your comments!
09/04/2015 6:37 PM
Yes! I have used the AD595. With an output of 10mV/ºC, you could get by with a 10VDC supply for the IC, but I would go with 15VDC so you're not bumping the upper limit. You can output the voltage from the AD595 directly to a standalone voltmeter with an LED display. When I get home, I'll send a schematic and pictures.
By the way, when someone gives you some pertinent help, it's good form to give them a Good Answer. Click on <Rate>.
More later!
Good Answers: 32
09/04/2015 10:58 AM
I had great success with a Fluke Multimeter using Type K thermocouples.
Try http://www.fluke-direct.com/product/fluke_51_ii_digital_thermometer
The type 51 was the one I used and found them economical. The infrared needs a clean surface and any dross or slag on the surface screws it up.
It's reasonably priced. I used Richardson Thermocouples with mine but some people would use RTD wire and cut off the ends when they got bad and re-twisted the wire for a new end. The thermocouples may be a bit too large for your application.
Spinco
09/04/2015 12:08 PM
link
Here is a link to a jewelry tools company with thermocouples for a well in your crucible. page 544 has what you need. You Might enjoy the rest of the catalog too.
09/04/2015 3:50 PM
Thak you all! I will try the "drill a well into the cricible itself" route with one of the suggested type K thermocouples+readouts that have been suggested. Tnx again!
Good Answers: 151
09/04/2015 3:56 PM
Now you got me thinking. Given that you are doing investment casting, you may have everything you need at hand to make a miniature thermocouple probe.
What you will need:
2 hole ceramic tube McMaster #87175k83 for 3/16 OD (smaller diameters are available) rated for 3000 F
Type K thermououple wire (from Omega)
An oxy-fuel torch to weld the thermocouple junction
Investment ceramic to coat the thermocouple junction and seal the ceramic tube and a kiln to fire the investment.
09/05/2015 1:06 PM
Mikerho: I mean to continue persiung the AD595 route. I welcome any schematics you may have on its use. Tnx!
Register to Reply 17 comments
Crabtree (1); gk1248 (4); gringogreg (2); ida01ro (1); Legolaz (1); Mikerho (3); SHOCKHISCAN (2); silvCrow (1); Spinco (1); Tornado (1)
