Previous in Forum: spherical tank   Next in Forum: Cost of Corrosion
13 comments
cnversion of velocity to pressure....
07/20/2007 11:49 AM
hello friend, is there any way to convert kinetic energy to pressure other than the use diffusers...
Re: cnversion of velocity to pressure....
07/20/2007 1:05 PM
What is moving?
Gordie
07/21/2007 4:37 AM
hi,take the moving element as air...
07/20/2007 4:31 PM
Is my understanding wrong? Whatever the thing moving bumps up against is going to feel presure at the bimped spot?
Is that not a direct conversion of one form of energy to another?
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
07/20/2007 4:36 PM
What are you trying to do? Are you looking for a unit conversion, or are you looking for a particular type of device that converts kinetic energy into pressure? Answering these questions will probably generate more questions, but that is sometimes necessary to determine the details of the situation.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
07/21/2007 4:39 AM
i want the device which converts kinetic energy to pressure.......
Re: conversion of velocity to pressure....
07/21/2007 1:16 AM
My be you need to know how we convert the wind velocity at different levels above the ground to wind pressure to calculate the forces affecting on the structures. Is that your question?
07/21/2007 4:41 AM
yes some what it relates...
Good Answers: 114
07/21/2007 3:21 PM
what are you trying to pressurize? fluid 0r gas
What form of kinetic energy
Good Answers: 19
07/22/2007 6:15 AM
How can you convert velocity into pressure? They are both separate. An increase/decrease in velocity corelates with pressure increase/decrease.
In other words, its a flow corelating with pressure.
Good Answers: 247
07/22/2007 2:31 PM
You may need to supply more details re exactly what you want. A flat sheet (of plywood, for example) will convert velocity to pressure in this sense: the sheet has a Cd (coefficient of drag) and an area. (Actual Cd for a flat sheet is generally considered 1). For a given wind velocity, there will be a given drag force. Divide that force by the area of the sheet, and you get an average pressure.
07/26/2007 10:38 AM
my case is while moving in a 4 wheeler with very high speed,can we convert the kinetic energy of opposing air into pressure (high velocity to high pressure air) energy to use some other purpose?
Good Answers: 247
07/26/2007 2:36 PM
Yes, you can. That is the principal of "ram air" induction. However, this effect is much more subtle than you might expect. If it were more significant, you would see hood scoops on virtually all cars -- it would be a very inexpensive way to get supercharging. As it happens, for an aerodynamically efficient car (a Prius, for instance) the slight hp gain from ram air would be more than offset by the loss in aerodynamic efficiency.
To give you an idea of the forces involved: A 2000 pound airplane will have a wing area of about 100 square feet. 100 x 144 = 14,400 square inches. So the pressure available, on average, is about .14 psi: not enough to run many energy consumers.
So, yes, it is possible, but not usually practical.
07/27/2007 7:02 AM
thank u sir....
Register to Reply 13 comments
3Doug (1); Abdel Halim Galala (1); Anonymous Poster (4); Blink (2); ducon (1); Garthh (1); rajkumar (3)
