Previous in Forum: A Billion Here a Billion There, It Adds Up   Next in Forum: 1985 Mercedes 300 SD Climate Control
11 comments
Do You CAN?
09/21/2015 9:35 AM
most have little if any idea about Can Bus communication in cars like Tesla uses. you might want to take a peek....its already all over the placehttp://www.aa1car.com/library/can_systems.htm
Good Answers: 918
Re: do you CAN?
09/21/2015 9:48 AM
It ought to be all over the place. CANbus is about 30 years old.
Re: do you CAN?
09/21/2015 10:40 AM
it is but the average shade-tree mechanic has no idea its right under their nose. I never learned of it until I dug into how Tesla charges its batteries. I wanted to know how the car knew how to accept the range of voltages it accepts from the same charging port. it will except from 110VAC all the way to 500(actually 480)VDC when using a Chademo charging adapter
Good Answers: 444
Re: do you CAN?
09/21/2015 12:20 PM
You fell for the common misconception that the SAE J1772EV charging station plug puts DC into the battery. Actually the charging station electronics monitor the AC source, connection to the vehicle for voltage, current and provide ground fault protection for the user via a data link between the units; all the DC conversion and control of the charging process takes place inside the vehicle.
Re: do you CAN?
09/21/2015 1:02 PM
actually I did not. I didn't learn about Can Bus until I was researching DC fast charging. the car can direct DC directly to the batteries and bypass the onboard charger(s) if the Can Message asks the car nicely to open the door to the battery pack.
Re: do you CAN?
09/22/2015 1:42 AM
I did not get that impression from what he wrote......
Good Answers: 444
Re: do you CAN?
09/21/2015 10:33 AM
According to Wikipedia CAN is also available on bicycles for controlling mountain bike shifters!
http://www.bikeradar.com/us/mtb/news/article/shimano-xtr-di2-electronic-shifting-comes-to-mountain-bikes-41184/
Re: do you CAN?
09/21/2015 2:26 PM
Some history: Hughes Aircraft Company actually looked into the potentials of using CAN-bus in some of their missiles in an attempt to standardize communication protocols amongst their many different USAF, USN, foreign, missile products.
Good Answers: 444
Re: do you CAN?
09/21/2015 3:00 PM
...and the Process Control industry uses it under the name Fieldbus.
Re: do you CAN?
09/21/2015 4:59 PM
"...and the Process Control industry uses it under the name Fieldbus."
Thank you, now I understand what everyone is talking about
Re: Do you CAN?
09/22/2015 1:38 AM
I CAN!
Re: Do You CAN?
10/06/2015 12:15 PM
For vehicle networking CAN is today's standard, but as vehicles get more complicated there is a movement to replace it with twisted-pair Ethernet.
Keep Your Diodes Forward and Your Emitters Grounded.
Register to Reply 11 comments
70AARCuda (1); Andy Germany (2); Anonymous Hero (1); BillGEE (1); Fredski (2); JAlberts (1); RAMConsult (3)
