Previous in Forum: Hot Water Heater Question   Next in Forum: Tankless Water Heater Hazard
18 comments
Solution to Equation
10/04/2015 1:12 PM
There sirs, I am problematic, I do not knowing what are the solution to my problem
N(i-1) εd2i = 0
What is the value of i, I am confused too much
Thanx very many
Re: Solution to Equaton
10/04/2015 2:07 PM
We don't do homework here.
This site will help you: Brainly.com
I usually don't answer questions from anonymous posters.
10/04/2015 2:39 PM
I've found that when doing math using the numerical system exclusively rather than the alphabet or trying to mix and match them works best.
Like 1 + 5 = 6
Where as A + 6 = Potato doesn't really solve much. Sure it looks clever to the uneducated but really it doesn't solve anything.
10/04/2015 2:37 PM
You need a math tutor....and English too....
http://math.tutorvista.com/
10/04/2015 5:18 PM
Forget about i for a minute.
Ask yourself what value of N or d will balance the equation.
10/04/2015 5:21 PM
One potato, two potato, three potato, four?
He'll find the value if he just tries.
10/04/2015 6:40 PM
∀ i : N=0, ε=0, d=0 are solutions.
Re: Solution to Equation
10/04/2015 8:26 PM
Use excel, then tabulate formula and drag that thing until you find zero (whatever your N and d values are) it goes something like this
or you may study logarithmic properties. But above is easier.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
10/05/2015 1:02 AM
sqrt(i)=-1
10/05/2015 6:52 AM
How about sqrt(-1)=i instead?
Good moaning!
Good Answers: 137
10/05/2015 9:16 AM
That's better! sqrt(i) = (1 + i)/√2
10/05/2015 9:41 AM
No, it's i=sqrt(-1) (you forgot to italicize i )
Good Answers: 183
10/05/2015 7:07 AM
If you think about imaginary values then i= sqrt(-1) so that the relationship is i²=-1.
At least it is what I remember from what I learned many many years ago.
But may be I am wrong.
There are sooo many new things in mathematics that the old I learned could be not any more valid.
10/05/2015 12:21 PM
No, you, (and Crabtree, and Codemaster) are right and I had it backwards!
10/05/2015 12:56 AM
Where did you find this equation?
10/05/2015 8:24 AM
It's tough when his professor tells him
Good Answers: 137
10/05/2015 8:12 AM
You certainly are problematic . How do you expect to solve an equation which has 4 unknowns? Conventionally i is defined as √-1 (though it need not be in your case).
If it helps, N(i-1) = Ni*N-1 = Ni/N and d2i = (d2)i = (di)2.
Good Answers: 203
10/05/2015 11:36 PM
Being an solutionmatic I have found that when the equation requires a number larger than 10 you can double your capacity by taking off your shoes and counting with the fingers and toes, not just the fingers. If you want to be inconspicuous about it, wear sandals and no socks.
If this doesn't work with larger formulas, invite some friends to help you solve it. Every additional person is an increase in the possible answer by 20. Don't invite anyone who has had some fingers or toes amputated. This will automatically give you a wrong answer. Also don't forget to count the pointer finger which is counting the other digits.
Good Luck, Old Salt
10/06/2015 12:47 AM
Higher math...
Reply to Forum Thread 18 comments
Codemaster (2); Crabtree (1); JohnDG (1); Legolaz (2); lyn (2); Mikerho (4); nick name (1); old salt (1); SolarEagle (2); tcmtech (1); Usbport (1)
